I just acquired an Arduino Mega. It's a made in China version with a CH340G USB to serial interface.
After a brief diagnostic I came to the conclusion that it has been sold to me faulty.
Burn bootloader from external programmer... OK
Upload sketch using tx/rx on DIO pins... OK
Upload sketch using USB interface... FAIL
Clearly something is wrong with the USB-serial interface.
We have been using the CH340G with other devices maybe around ten thousand times and do this every day. So driver issues are not the case here.
Before I savage the card by trying to replace the 12mhz crystal and/or the CH340 itself has anyone been confronted to the same problem? If so did you find a hardware fix for it?
(I liaising with whoever sold this to me as well of course).
My hardware solution is to buy at least two and hope that at least one works and throw the bad one in the trash. Overall, it's still cheaper than buying one of the official Arduino Megas.
They crank out those boards by the thousands/month (maybe more). The micro is pre-programmed with blinky, so if the LED blinks, I guess they consider the whole board to be good.
the manual reset gets nowhere. Good thinking though. Thanks.
Monitoring the serial output using a FTDI232 adaptor connected on tx/rx DIO works really solid (as expected).
On the USB interface however I get the first second of output then nothing (just using a sketch that output every seconds). Somehow the CH340 can not cope.
Probably not an issue with the crystal then otherwise it would not work at all.
Yes I am in contact with the seller. However if I find a quick way to fix it that would do me as I can't be bothered waiting another week to get a new board and work on the project.
When you buy cheap... you get cheap. I know.
