I came across the need to use Interrupts on digital Pins 2 and 3, but couldn't get my code to work. After extensive searching, I found out that I was NOT USING THE CORRECT INT number. I was using INT4 and INT5 for Pins2 and 3 respectively, when I should have been using INT0 and INT1 (I got the INT4 and 5 info from the MEGA2560 DATASHEET Pinout, but the INT0 and 1 required extensive searching. I finally found a discussion in 2017 on GITHUB).
My question, WHY is there still NO MENTION of this fact in the PINOUT diagrams of the DATASHEET (Digital I/O Pin 2, PWM, PE4, Pin6, labeled "(OC3B/INT4)PE4")? I know if i read the DATASHEET from cover to cover, I might find the answer (or at least figure it out), but my FIRST goto source is internet search, and second is a drawing (because it is a good overall reference, although not perfect). It just seems to me a tiny asterisk, with a note somewhere near the bottom could have saved me a lot of aggravation. Just venting by the way, and hoping that someone else finds this in their search for the true interrupt numbers.
You should look at the Arduino language reference at the attachInterrupt reference.
Use the digitalPinToInterrupt(pin)
function.
