arduino melody
Hey guys, so I've been trying to write a song on arduino using a piezo buzzer. I successfully wrote the song for 1 piezo but I've been trying to have another piezo buzzer play at the same time with a different melody. I tried a bunch of things but still can't do it. I need a different melody and duration for the second piezo. Both need to be playing simultaneously. Any help is appreciated. Thank you!! I've post my code below.
#include "pitches.h"
const int piezoPin = 12; //piezo
const int piezoPin2 = 10; //piezo for second sound
const int pPin = 2; //pushbutton
int ledState = 0;
int ledOn = false;
// notes
int melody[] = {
NOTE_E5, NOTE_G5, NOTE_F5, NOTE_E5, NOTE_D5, NOTE_C5, NOTE_E5, NOTE_D5, NOTE_C5, NOTE_B4, NOTE_A4, NOTE_B4, NOTE_C5, NOTE_G4,
NOTE_A4, NOTE_C5, NOTE_C5, NOTE_B4,
//chorus
NOTE_E5, NOTE_G5, NOTE_G5, NOTE_D5, NOTE_C5, NOTE_E5, NOTE_E5, NOTE_B4, NOTE_A4, NOTE_C5, NOTE_C5, NOTE_G4,
NOTE_A4, NOTE_C5, NOTE_C5, NOTE_B4, NOTE_E5, NOTE_G5, NOTE_G5, NOTE_D5, NOTE_C5, NOTE_E5, NOTE_E5, NOTE_B4, NOTE_A4, NOTE_C5, NOTE_C5, NOTE_G4,
int melody2[]{
// durations: 2 = half note, and 8/3,4,6,8,12. It appears that 8/2.9 is more accurate than 8/3.
float noteDurations[] = {
2, 8, 8, 8, 8, 2, 8, 8, 8, 8, 4, 4, 4, 4, 4, 4, 4, 2,
//chorus
8, 8, 4, 2, 8, 8, 4, 2, 8, 8, 4, 2, 8, 8, 4, 2, 8, 8, 4, 2, 8, 8, 4, 2, 8, 8, 4, 2, 8, 8, 4, 2
// calculates the number of elements in the melody array.
int musicLength=sizeof(melody)/sizeof('NOTE_F5');
pinMode(pPin, INPUT);
int pPinState=digitalRead(pPin);
if(pPinState==HIGH) {
ledState = 1;
if (pPinState==LOW and ledState ==1) {
ledState = 2;
ledOn = not ledOn;
if (ledOn && pPinState!=HIGH) {
for (int thisNote = 0; thisNote < musicLength; thisNote++) {
// blink the three LEDs in sequence
// calculate the note duration. change tempo by changing 2000 to other values
int noteDuration = 2000/noteDurations[thisNote];
tone(piezoPin, melody[thisNote],noteDuration);
// to distinguish the notes, set a minimum time between them.
// the note's duration + 30% seems to work well
float pauseBetweenNotes = noteDuration * 1.40;
//split the delay into two parts and check to see
//whether the pushbutton is pressed to turn off
//the sound and light
delay(pauseBetweenNotes/2);
if(digitalRead(pPin)==HIGH) {
hmvu:
You are missing tons of things.
For example this one: The Arduino tone() function can play either one or none tone on one pin at the same time.
The Arduino tone() function cannot play two tones on two pins at the same time.
So at first place, forget about the melody and just explain: How do you want to play two tones on two different pins at the same time? Which function or which library do you want to use for that?
I'd like to suggest: If you can play two different tones on two different pins at the same time, then let's discuss further about playing melodies. And maybe improving your somewhat less than perfect way of musical notation in the source code within the sketch.
First thing is, there is no such thing as simultaneously in Arduino.
You can do things one after the other very fast, so they seen to be simultaneously, but it actually isn't.
By understanding that, you start to understand that you can't do anything during a "delay" so, you should avoid using delays since it blocks (stops all) your code for that amount of time. So on your actual code you are using delays, you need to change that to millis calculations to check if the amount of time you wanted have passed.
As Delta_G already mentioned the Blink Without Delay will be your greatest friend on this project, you need to understand it and implement on your program.
