Arduino Metal Detector Improvements?
  • You can play with the resonant frequency.
  • Another test would be, use a potentiometer on say A1 to adjust the code to produce a pulse train (green) around resonance.
    i.e. vary the green trace frequency about resonance.
  • Note to Santa, consider giving @kgray9 an oscilloscope for Christmas.
  • I quite like the LMV321 Low-Voltage Rail-to-Rail Output Operational Amplifier.
https://www.ti.com/lit/ds/symlink/lmv321.pdf?
  • These are very small.
Are you saying make the frequency of the Arduino's pulses externally adjustable to resonate the LC circuit perfectly? I could! I did calculate the capacitance already though to match the frequency of the Arduino rather than the other way around.
Haha thanks for sending him a note! I have one though... and I learned some skills from someone :wink: (Good Oscilloscope Projects for Beginners? / Skills Test / TDR - #49 by kgray9)
Do you have any idea whats going on here!? I only added a NPN transistor to discharge the capacitor!
The voltage at the capacitor is going to negative ~0.5V immediately after turning off the discharge transistor. :face_with_monocle:
  • Yes, as an experiment.
    However, your final circuit may not function as a metal detector with a resistance capacitor.
  • Hmm, capacitor when discharging generates negative voltage, a schottky diode should clip this better ?
  • Pink line is 0V for yellow capacitor waveform.
  • Draw a timing diagram, based on your code, showing capacitor discharge time overlay on green waveform.
Edit
  • R5 (10k) is not really needed, for now, drop it to 220R.
    5v / 30R = 166ma collector current constant current source.
  • Adjust trigger hold off ?
  • Trigger off the rising edge of the green trace.
  • Lengthen the discharge time.
  • What did you do different between these two ?
Okay! It was originally 5µs in that o'scope picture that I sent. In the original circuit (unmodified), it discharged for 20µs, so i changed it back to that.
Yeah! Do you know why it goes negative? I can't see how or why that would happen!
I added a Schottky diode as you showed in that schematic, and it does help a little, but that is it :man_shrugging:.
The diode helps a little! It still goes negative though :thinking:.
Here is what it looks like after I changed the 10kΩ gate resistor on the PNP transistor to 220Ω:
As you can see, the inductor and capacitor voltages are quite a bit higher! So i had to zoom out:
Exactly what I calculated it as! The 2n3906 I am using has a maximum collector current of 200mA.
The only difference is:
The first one has the Arduino switching the pinMode of the analog reading pin to OUTPUT, to drive the capacitor low.
The second one has a separate pin driving the capacitor to GND through a NPN transistor (2n3904).
What exactly do you mean? Something like this?
(All voltages shown are for trace 1 (yellow) )
Thanks again for the help @LarryD !
Also, I found this quite interesting:
This is the traces, when I remove the resistor between the Arduino pin and the PNP transistor gate, leaving the transistor unconnected completely.
  • Show us the changes to the schematic so we can visualize what’s happening.
  • Reviewing good images of the actual wiring helps us check things too.
  • Try to go back to where just the capacitor pin is used for both the analog input and discharge.
  • An NPN would only discharge the capacitor to VCE(sat), i.e. collector saturation voltage.
    Using just a GPIO pin (open Drain) or a logic level N channel MOSFET (open Drain configuration) would be recommended, or, as in your original circuit, the same analog input pin that reads the voltage.
  • Something like this:
The scope however is 1Megohm.
Leo..
Hello again!
Sorry, been very busy! So I'm back at it, and I think I have improved it almost as much as I possibly can with this type of idea.
I am now using a much larger coil (4 wraps, ~13inch diameter, 14.86µH) with a circuit that uses a P-channel MOSFET with a base transistor to drive the coil. A transistor is used to discharge the capacitor and a voltage divider is used to read the capacitor so it can work above 12V now.
Schematic_Metal Detector 2.pdf (53.6 KB)
I found i had to decrease the frequency from 134.4kHz to 47.8kHz to use this larger coil... the original higher frequency wouldn't work at all, nor would 13.3kHz that i tried!
I think my next move, is to make another circuit, but this one just uses a 555 timer to generate a specific frequency pulse, and a ESP32 (because of its faster processor) to read the frequency from the inductor. A change in frequency would correspond with interference in the magnetic field.
Does this sound like a good idea to anyone?
@kgray9 schematic;
Both of your BJTs need base resistors.
Tom.. :smiley: :+1: :coffee: :australia:
Thanks @TomGeorge !
Got it, ill add base resistors on the BJTs.
What did you all think of my next idea?
