Hello,
I just got my first arduino a couple days ago, and am very excited in trying to make my own MIDI controller. I'm using an Arduino Micro with Mac OS X and Arduino 1.8.5.
My problem is that the I am getting this error message:
Arduino: 1.8.5 (Mac OS X), Board: "Arduino/Genuino Micro"
/Users/jeff/Documents/Arduino/TestController/TestController.ino: In function 'void buttons()':
TestController:97: error: 'MIDI' was not declared in this scope
MIDI.sendNoteOn(note + i, 127, midiCh); // note, velocity, channel
TestController:109: error: 'MIDI' was not declared in this scope
MIDI.sendNoteOn(note + i, 0, midiCh); // note, velocity, channel
/Users/jeff/Documents/Arduino/TestController/TestController.ino: In function 'void potentiometers()':
TestController:154: error: 'MIDI' was not declared in this scope
MIDI.sendControlChange(cc + i, midiCState*, midiCh); // cc number, cc value, midi channel*
/Users/jeff/Documents/Arduino/TestController/TestController.ino: In function 'void noteOn(byte, byte, byte)':
/Users/jeff/Documents/Arduino/TestController/TestController.ino:175:42: warning: narrowing conversion of '(int)(channel | 144u)' from 'int' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing] - midiEventPacket_t noteOn = {0x09, 0x90 | channel, pitch, velocity};*
/Users/jeff/Documents/Arduino/TestController/TestController.ino: In function 'void noteOff(byte, byte, byte)':
/Users/jeff/Documents/Arduino/TestController/TestController.ino:180:43: warning: narrowing conversion of '(int)(channel | 128u)' from 'int' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing] - midiEventPacket_t noteOff = {0x08, 0x80 | channel, pitch, velocity};*
/Users/jeff/Documents/Arduino/TestController/TestController.ino: In function 'void controlChange(byte, byte, byte)':
/Users/jeff/Documents/Arduino/TestController/TestController.ino:185:41: warning: narrowing conversion of '(int)(channel | 176u)' from 'int' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing] - midiEventPacket_t event = {0x0B, 0xB0 | channel, control, value};*
exit status 1
option enabled in File -> Preferences.
I have already done a good amount of research/troubleshooting in trying to fix the problem "'MIDI' was not declared in this scope". I've tried reinstalling the MIDIUSB Library through two different methods:
1. Adding the library through the arduino program (i.e. Sketch > Include Library > Manage Libraries) and then adding the MIDIUSB Library.
2. Adding the zip file from here: GitHub - FortySevenEffects/arduino_midi_library: MIDI for Arduino
Additionally, I have tried editing the code a little bit since there are many slashed out lines that are relevant to the model of the arduino I am using.
Attached is a copy of the code I am using from Nerd Musician.
Thank you,
Jeff
TestController.ino (6.49 KB)
