Solution:
The testsketch i uploaded always overwrote the bootloader. what you have to do is: burn the bootloader from sparkfun, and dont upload any program via iscp again. then you can use it via usb. nice! ![]()
ive got some issues with my arduino micro pro. I bought if from ebay, the cheap 5V version.
First my cable was not working and i wondered, why windows doesnt recognize it at all. The cable only had power supply i found out later.
Thatswhy i used my uno to programm it. i also burned the bootloader again. (software from sparkfun, 5V version) everything worked well, just via the uno. i programmed a little blink sketch with pin number 8.
Now i connected the micro to my pc via the usb cable. I installed the drivers and selected the micro pro from sparkfun in the ide.
I follow this instruction: Pro Micro & Fio V3 Hookup Guide - SparkFun Learn
But if i try to upload the code i get this error:
Binary sketch size: 6,244 bytes (of a 28,672 byte maximum)
Forcing reset using 1200bps open/close on port COM15
PORTS {COM1, COM7, COM8, COM10, COM11, COM12, COM13, COM14, COM15, COM20, COM21, COM22, } / {COM1, COM7, COM8, COM10, COM11, COM12, COM13, COM14, COM15, COM20, COM21, COM22, } => {}
PORTS {COM1, COM7, COM8, COM10, COM11, COM12, COM13, COM14, COM15, COM20, COM21, COM22, } / {COM1, COM7, COM8, COM10, COM11, COM12, COM13, COM14, COM20, COM21, COM22, } => {}
PORTS {COM1, COM7, COM8, COM10, COM11, COM12, COM13, COM14, COM20, COM21, COM22, } / {COM1, COM7, COM8, COM10, COM11, COM12, COM13, COM14, COM20, COM21, COM22, } => {}
processing.app.debug.RunnerException: Couldn’t find a Leonardo on the selected port. Check that you have the correct port selected.  If it is correct, try pressing the board's reset button after initiating the upload.
at processing.app.debug.AvrdudeUploader.uploadViaBootloader(AvrdudeUploader.java:153)
at processing.app.debug.AvrdudeUploader.uploadUsingPreferences(AvrdudeUploader.java:67)
at processing.app.Sketch.upload(Sketch.java:1671)
at processing.app.Sketch.exportApplet(Sketch.java:1627)
at processing.app.Sketch.exportApplet(Sketch.java:1599)
at processing.app.Editor$DefaultExportHandler.run(Editor.java:2380)
at java.lang.Thread.run(Thread.java:619)
As you can see after a while the com 15 (the arduino) disconnects from my pc. but the rx and tx led still continue to blink like crazy. then i have to disconnect the cable.
I tried another usb port, i tried restarting my pc, i tried resetting the arduino with a tab and double tab and all that stuff, i tried to start the ide with admin privilegs, i tried older versions of the micro pro software addon, but they didnt work at all. im using the current ide 1.0.5-r2
I also tried the 3v version and the normal micro. not working. im not sure, the datasheet sais i have to close j1 for 5v. but i bought a 5v version and its not closed. not sure if they ignored that, its a china version. i also tried to connect it with a cable, doesnt help too.
I read through forums and so on, but i couldnt find anything that would help. but my blinking programm at pin 8 is still working...
what should i do now? (i dont wanna remore all wires from my uno and reprogramm it. but if needed i have to... but not sure if this would help me)
