I connected my Arduino Mini to a USB2Serial (original from Arduino) connecting just:
RX->TX
TX->RX
power supply and GND from USB2Serial direclty.
Reset of Arduino connected to +Vdc through resistance 10K. (avoidning having it floating)
I tried to add a led 1/4W with a resistance of 333 ohm to the pin 13 but I can't see nothing.. when I press reset button the led still off.
When I try to upload a program (e.g. blink) it builds but is not able to connect to the "programmer":
avrdude: Version 6.0.1, compiled on Apr 3 2014 at 23:12:16
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino/hardware/tools/avr/etc/avrdude.conf"
Using Port : COM25
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x01
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x01
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x01
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x01
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x01
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x01
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x01
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x01
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x01
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x01
the speed od serial port 25 in my pc is 115200 as required by Arduino IDE..
I have some doubts:
why "using programmer" is arduino? It seems that it's trying to upload through another Arduino when I'm uploading through USB2Serial..
RX, TX, Reset, are equal in the Arduino? There are 2 pins for both..
how to handle reset: better to have it disconnected and the button it's enough? I should connect the pin in order to avoid it floating?
bootloader: how to know if it's there? Led 1/4W + 333ohm is ok to see it flashing?
in case there isn't bootloader, I should buy another device to download it? USB2Serial is not enough, right?
any suggestion?
The Arduino MINI 05 is new.. bought from RS-components.
Waiting someone that can help me.. answering all (or part of them) my questions doubts, I have an additional question:
Can I download bootloader using a raspberry?
I have one, so..
as I wrote, I connected USB2Serial directly to Arduino Mini:
TX->RX
RX->TX
5Vdc -> 5Vdc
GND->GND
The power is from USB..
I tried to connect reset (ext) from USB2Serial directly to reset input of Arduino..
I tried to connect reset of Arduino to 5Vdc through resistance 10Kohm
I tried using the reset button
Please, help me to understand:
Ho I can recognize if the bootloader is correctly installed? I found different opinion on the web, someone wrote that is enough to see power led on, someone else checking pin 13 with resistance and a led, it should blink after pressing reset button.. so.. what is the best test?
In case the bootloader is not there.. can I download it just using the USB2Serial adapter or using a Raspberry PI B+?
Press reset just before the upload actually starts to initiate the bootloader. I know how to wire up a pro mini... but can't see the pinout of that board to tell you where to connect the reset to.
Hello,
Ok.. but, I' sorry.. nothing new.
Can you go through my questions, my doubts to help me?
My question was: how to recognize if the bootloader is really there.
The pinout is easily found in this site, on board section.
In your experience.. even you never used Arduino Mini 05, do you see something wrong
in my conncetion? If you have to connect them, do you follow a different schema?
I don't have DTR.. it's the same of RESET in my case?
Can you tell me something about the bootloader?
how to check if it is saved inside my Arduino Mini?
