Arduino MKR 1010 wifi OTA
why is this code not working in Arduino iot cloud. I want to broadcast it over the air.
  Sketch generated by the Arduino IoT Cloud Thing "Untitled"
  https://create.arduino.cc/cloud/things/971ca962-22e2-4336-940a-0668a8cc1d6e
  Arduino IoT Cloud Variables description
  The following variables are automatically generated and updated when changes are made to the Thing
  - No variables have been created, add cloud variables on the Thing Setup page
    to see them declared here
  Variables which are marked as READ/WRITE in the Cloud Thing will also have functions
  which are called when their values are changed from the Dashboard.
  These functions are generated with the Thing and added at the end of this sketch.
#include "thingProperties.h"
#include <RTCZero.h>
#include <FastLED.h>
#define NUM_LEDS 12
#define DATA_PIN 8
#define COLOR_ORDER GRB
#define CHIPSET WS2812B
#define BRIGHTNESS 50
#define VOLTS 5
#define MAX_AMPS 500
CRGB leds[NUM_LEDS];
int Relay = 4;
RTCZero rtc;
// Removed the const keyword so the variables can be updated
byte seconds = 00;
byte minutes = 29;
byte hours = 5;
byte day = 4;
byte month = 12;
byte year = 23;
int OnTime = 330;
int OnTime2 = 1020;
int OffTime1 = 480;
int OffTime2 = 1380;
//5:30=330 min
//8=480 min
//17=1020 min
//23=1380 min
  // Initialize serial and wait for port to open:
  // This delay gives the chance to wait for a Serial Monitor without blocking if none is found
  delay(1500);
  rtc.begin();  // initialize RTC
  pinMode(Relay, OUTPUT);
  digitalWrite(Relay, LOW);
  rtc.setHours(hours);
  rtc.setMinutes(minutes);
  rtc.setSeconds(seconds);
  rtc.setDay(day);
  rtc.setMonth(month);
  rtc.setYear(year);
  FastLED.addLeds<CHIPSET, DATA_PIN, COLOR_ORDER>(leds, NUM_LEDS);
  FastLED.setMaxPowerInVoltsAndMilliamps(VOLTS, MAX_AMPS);
  FastLED.setBrightness(BRIGHTNESS);
  FastLED.clear();
  FastLED.show();
  // Defined in thingProperties.h
  initProperties();
  // Connect to Arduino IoT Cloud
  ArduinoCloud.begin(ArduinoIoTPreferredConnection);
     The following function allows you to obtain more information
     related to the state of network and IoT Cloud connection and errors
     the higher number the more granular information you’ll get.
     The default is 0 (only errors).
     Maximum is 4
  setDebugMessageLevel(2);
  ArduinoCloud.printDebugInfo();
  ArduinoCloud.update();
  // Your code here
  print2digits(rtc.getDay());
  Serial.print("/");
  print2digits(rtc.getMonth());
  Serial.print("/");
  print2digits(rtc.getYear());
  Serial.print(" ");
  print2digits(hours = rtc.getHours());  // We update the hours variable like this here
  Serial.print(":");
  print2digits(minutes = rtc.getMinutes());  // We update the minutes variable like this here
  Serial.print(":");
  print2digits(rtc.getSeconds());
  updateRelay();  // we update the relay here
void print2digits(int number) {
  if (number < 10) {
    Serial.print("0");  // print a 0 before if the number is < than 10
  Serial.print(number);
// moved the relay code to it's own function
void updateRelay() {
  int mOnTime = hours * 60 + minutes;
  if ((mOnTime >= OnTime && mOnTime <= OffTime1) || (mOnTime >= OnTime2 && mOnTime <= OffTime2)) {
    digitalWrite(Relay, HIGH);
    Serial.println("LIGHT ON");
    for (int i = 0; i < NUM_LEDS; i++) {
      leds[i] = CRGB::White;
      FastLED.show();
      delay(50);
    Serial.println("LIGHT OFF");
error:
/tmp/arduino-build-8B624260B310D30CEEC2B0CEA720CE7F/libraries/arduinoiotcloud_1_13_0/utility/time/objs.a(TimeService.cpp.o):/home/builder/Arduino/libraries/arduinoiotcloud_1_13_0/src/utility/time/TimeService.cpp:50: multiple definition of `rtc'
/tmp/arduino-build-8B624260B310D30CEEC2B0CEA720CE7F/sketch/objs.a(M28_dec06a.ino.cpp.o):/tmp/175576726/M28_dec06a/M28_dec06a.ino:33: first defined here
collect2: error: ld returned 1 exit status
Multiple libraries were found for "ArduinoECCX08.h"
Used: /home/builder/opt/libraries/arduinoeccx08_1_3_7
Not used: /home/builder/opt/libraries/rak5814_atecc608a_1_0_0
Multiple libraries were found for "FastLED.h"
Used: /mnt/create-efs/webide/6c/16/6c16139d93af413f0e0af98009fabefd:ulfer/libraries_v2/FastLED
Not used: /home/builder/opt/libraries/fastled_3_6_0
Multiple libraries were found for "SPI.h"
Used: /home/builder/.arduino15/packages/arduino/hardware/samd/1.8.13/libraries/SPI
Not used: /home/builder/opt/libraries/eventethernet_1_0_0
Multiple libraries were found for "WiFiNINA.h"
Used: /home/builder/opt/libraries/wifinina_1_8_14
Not used: /home/builder/opt/libraries/vega_wifinina_1_0_1
Error during build: exit status 1
rename your rtc instance.
how do you mean?
this code works in arduino web, it's almost the same as the one i want to send over the air.
#define NUM_LEDS 12
#define DATA_PIN 8
#define BRIGHTNESS 40
#define VOLTS 5
int Relay = 4;
int Relay2 = 7;
RTCZero rtc;
byte seconds = 00;
byte minutes = 48;
byte hours = 14;
byte day = 1;
byte month = 12;
byte year = 23;
  pinMode(Relay2, OUTPUT);
  digitalWrite(Relay2, LOW);
  rtc.setDay(day);
  rtc.setYear(year);
  FastLED.clear();
  FastLED.show();
  Serial.print("/");
  Serial.print("/");
  Serial.print(" ");
  Serial.print(":");
  Serial.print(":");
  if (number < 10) {
  if ((hours >= 14 && minutes >= 48) && (hours <= 14 && minutes <= 55) || (hours >= 16 && minutes >= 55) && (hours <= 16 && minutes <= 59)) {
    digitalWrite(Relay2, HIGH);
      FastLED.show();
      delay(50);
the name rtc is taken by the Cloud library. you have to use a different name for the RTC object
thanks
