Arduino mkr gsm 1400 SSH/TLS communication via SARA U201
Hello, so my issue is as follows. I am trying to communicate over SSH/TLS with my Arduino MKR GSM 1400, for this to happen a private key (rsa in .der format) needs to be saved in the memory of the cellular module - SARA-U201-03B. Which by all counts seems impossible for me, I have contacted local u-blox support and received the EasyFlash tool together with the SARA-U201-04B.dof file for the firmware update.
I have tried uploading the file via Python script and updating via AT commands(no result the file is too big to be saved in the memory). I have adjusted the port settings on my pc to correspond with the baud rate for the EasyFlash upload and tried the com-ports and usb update during boot, unfortunately the cellular module has no feature to be directly powered off as it is a part of the Arduino, so I get all those errors without even being sure that I can establish a connection with the SARA U201 module.
Please TURN OFF the device and press 'Start' to install the firmware
Using dof file : D:/EasyFlash/SARA-U201-04B-00_FW23.60_A01.06_IP_bsc.dof
Using USB port
LogFilePath :
D:\EasyFlash\EASYFLASH_output_c1_20250131_223139.log
Waiting for synchronization...
Please TURN ON the device and don't disconnect power supply
Process time was 50.0 sec.
Error occured!
STOPPING...
[USB Boot Timeout]
Using USB port
LogFilePath :
Error occured!
STOPPING...
[USB Boot Timeout]
LogFilePath :
Error occured!
STOPPING...
[Timeout waiting for boot acknowledge code.]
Welcome to the forum
You started a topic in the Uncategorised category of the forum when its description explicitly tells you not to
Your topic has been moved to a relevant category. Please be careful in future when deciding where to start new topics
Ok, I overlooked. Thank you for that.
What are you trying to achieve?
Firmware update of the modem or ssh connection?
If ssh: To where? There is no ssh server nor OS. Purpose, idea?
