Hi everyone,
I’m working on a project which involves getting data from a Tracer 4215BN MPPT solar charge controller. I’ve connected it up to a rs485 to TTL converter and to the Arduino.
I’m using the ModbusMaster Modbus library for Arduino. The documentation can be seen here: ModbusMaster: Main Page
You can see he MODBUS specs for this model here: https://www.developpez.net/forums/attachments/p196506d1451307310/systemes/autres-systemes/automation/probleme-com-modbus-pl7-pro/controllerprotocolv2.3.pdf/
I’m not familiar with MODBUS, however, I’ve managed to get it mostly working. The issues are that for some reason, not all of the code works!
Here is my code:
<code
#include <ModbusMaster.h>
#define MAX485_DE 3
#define MAX485_RE_NEG 2
ModbusMaster node;
void preTransmission()
digitalWrite(MAX485_RE_NEG, 1);
digitalWrite(MAX485_DE, 1);
void postTransmission()
digitalWrite(MAX485_RE_NEG, 0);
digitalWrite(MAX485_DE, 0);
pinMode(MAX485_RE_NEG, OUTPUT);
pinMode(MAX485_DE, OUTPUT);
// Init in receive mode
// Modbus communication runs at 115200 baud
// Modbus slave ID 1
node.begin(1, Serial);
// Callbacks allow us to configure the RS485 transceiver correctly
node.preTransmission(preTransmission);
node.postTransmission(postTransmission);
uint8_t result;
result = node.readInputRegisters(0x3100, 15);
if (result == node.ku8MBSuccess)
Serial.println(" - - - - - - - - - - - - - - ");
Serial.println(“MAIN DETAILS:”);
Serial.print("Input Voltage: ");
Serial.println(node.getResponseBuffer(0x00) / 100.0f);
Serial.print("Input Current: ");
Serial.println(node.getResponseBuffer(0x01) / 100.0f);
Serial.print("Input Power: “);
Serial.println((node.getResponseBuffer(0x02) +
node.getResponseBuffer(0x03) << 16) / 100.0f);
Serial.print(”-: “);
Serial.println(node.getResponseBuffer(0x04) / 100.0f);
Serial.print(”-: ");
Serial.println(node.getResponseBuffer(0x05) / 100.0f);
Serial.print("Charging Power: “);
Serial.println((node.getResponseBuffer(0x06) +
node.getResponseBuffer(0x07) << 16) / 100.0f);
Serial.println(node.getResponseBuffer(0x08) / 100.0f);
Serial.println(node.getResponseBuffer(0x09) / 100.0f);
Serial.println(node.getResponseBuffer(0x0A) / 100.0f);
Serial.println(node.getResponseBuffer(0x0B) / 100.0f);
Serial.print("Load Voltage: ");
Serial.println(node.getResponseBuffer(0x0C) / 100.0f);
Serial.print("Load Current: ");
Serial.println(node.getResponseBuffer(0x0D) / 100.0f);
Serial.print("Load Power: ");
Serial.println((node.getResponseBuffer(0x0E) +
node.getResponseBuffer(0x0F) << 16) / 100.0f);
node.clearResponseBuffer();
delay(1500);
result = node.readInputRegisters(0x3110, 4);
Serial.println(“TEMPERATURES:”);
Serial.print("Battery Temperature: ");
Serial.print("Temperature Inside Case: ");
Serial.print("Battery SOC: ");
Serial.println(node.getResponseBuffer(0x02) / 100.0f);
Serial.print("Remote Battery Temperature: ");
Serial.println(node.getResponseBuffer(0x03) / 100.0f);
Serial.print("Battery Real Rated Power: ");
delay(1500);
result = node.readInputRegisters(0x3200, 2);
Serial.println(“STATUS:”);
Serial.print("Battery Status: ");
Serial.println(node.getResponseBuffer(0x00));
Serial.print("Equipment Status: ");
Serial.println(node.getResponseBuffer(0x01));
Serial.print("Discharging Equipment Status: ");
Serial.println(node.getResponseBuffer(0x02));
delay(1500);
result = node.readInputRegisters(0x3300, 24);
Serial.println(“STATISTICS:”);
Serial.print("Max. PV Today: ");
Serial.print("Min. PV Today: ");
Serial.print("Max. Battery Voltage Today: ");
Serial.print("Min. Battery Voltage Today: ");
Serial.println((node.getResponseBuffer(0x04) +
node.getResponseBuffer(0x05) << 16) / 100.0f);
Serial.print("Consumed Energy Today: ");
Serial.print("Consumed Energy This Month: ");
Serial.println((node.getResponseBuffer(0x08) +
node.getResponseBuffer(0x09) << 16) / 100.0f);
Serial.print("Consumed Energy This Year: ");
Serial.println((node.getResponseBuffer(0x0A) +
node.getResponseBuffer(0x0B) << 16) / 100.0f);
Serial.print("Consumed Total Energy: ");
Serial.println((node.getResponseBuffer(0x0C) +
node.getResponseBuffer(0x0D) << 16) / 100.0f);
Serial.print("Generated Energy Today: ");
Serial.print("Generated Energy This Month: ");
Serial.println(node.getResponseBuffer(0x10) / 100.0f);
Serial.print("Generated Energy This Year: ");
Serial.println((node.getResponseBuffer(0x11) +
node.getResponseBuffer(0x12) << 16) / 100.0f);
Serial.print("Generated Energy Total: ");
Serial.println((node.getResponseBuffer(0x13) +
node.getResponseBuffer(0x14) << 16) / 100.0f);
Serial.print("Battery Voltage: ");
Serial.println(node.getResponseBuffer(0x15) / 100.0f);
Serial.print("Battery Current: ");
Serial.println((node.getResponseBuffer(0x16) +
node.getResponseBuffer(0x17) << 16) / 100.0f);
delay(1500);
The response I’m getting is in the attachment. I don’t understand why the statistics section is completely ignored. I also don’t knwo what the garbled text is before the ‘- - - - - -’. Does anyone who is more familiar with this know what is going on here?
Thanks in advance, Antony…
