Arduino Motor Control Code
Hello everyone! :waving_hand:
In this post, I’m sharing a simple yet effective motor control code for Arduino, ideal for controlling small robots or any project involving motorized movement. This code allows you to control your motors for basic movements: forward, backward, turn left, turn right, and stop, all while utilizing PWM (Pulse Width Modulation) for speed control.
The PWM allows for fine-tuned motor speed control, which is crucial for a variety of applications such as robot movement or driving DC motors efficiently. This code is simple enough for beginners to understand and use, yet flexible enough to adapt to various motor configurations and projects.
In this project:
  • Motor 1 (right motor) and Motor 2 (left motor) are controlled independently, allowing for directional movement as well as rotation.
  • You can adjust the speed using PWM values (from 0 to 255), and the delay() function controls the timing of the movements.
I hope this will be helpful for those starting their journey with motorized robots or anyone interested in learning motor control via Arduino.
Here’s the code:
Arduino Motor Control Code: Forward, Backward, Turn, and Stop with PWM
This code allows you to control a robot's motors to move forward, backward, turn left, turn right, and stop.
The speed of the motors is controlled using PWM (Pulse Width Modulation).
Each motor has two pins for direction control and one pin for speed control.
const int motorPinR1 = 7;    // Motor Right IN1
const int motorPinR2 = 8;    // Motor Right IN2
const int motorPinREna = 6;  // Motor Right ENA (Speed Control)
const int motorPinL1 = 9;    // Motor Left IN1
const int motorPinL2 = 10;   // Motor Left IN2
const int motorPinLEna = 11; // Motor Left ENB (Speed Control)
Function to control the movement of a motor (Left or Right).
direction: 1 for forward, -1 for backward, 0 to stop.
speed: The speed value (0-255) for PWM control.
void moveMotor(int motorPin1, int motorPin2, int motorPinEna, int direction, int speed) {
  if (direction == 1) {  // Move forward
    digitalWrite(motorPin1, HIGH);  // Set IN1 HIGH
    digitalWrite(motorPin2, LOW);   // Set IN2 LOW
  } else if (direction == -1) {  // Move backward
    digitalWrite(motorPin1, LOW);   // Set IN1 LOW
    digitalWrite(motorPin2, HIGH);  // Set IN2 HIGH
  } else {  // Stop (direction == 0)
    digitalWrite(motorPin1, LOW);   // Set both IN1 and IN2 to LOW
  // Control motor speed using PWM (analogWrite)
  analogWrite(motorPinEna, speed);
Move the robot forward.
Accepts speed (0-255) to set motor speed.
void moveForward(int speed) {
  moveMotor(motorPinR1, motorPinR2, motorPinREna, 1, speed);  // Move right motor forward
  moveMotor(motorPinL1, motorPinL2, motorPinLEna, 1, speed);  // Move left motor forward
Move the robot backward.
void moveBackward(int speed) {
  moveMotor(motorPinR1, motorPinR2, motorPinREna, -1, speed);  // Move right motor backward
  moveMotor(motorPinL1, motorPinL2, motorPinLEna, -1, speed);  // Move left motor backward
Rotate the robot to the right.
Right motor moves forward, left motor moves backward.
void turnRight(int speed) {
  moveMotor(motorPinR1, motorPinR2, motorPinREna, 1, speed);   // Right motor forward
  moveMotor(motorPinL1, motorPinL2, motorPinLEna, -1, speed);  // Left motor backward
Rotate the robot to the left.
Right motor moves backward, left motor moves forward.
void turnLeft(int speed) {
  moveMotor(motorPinR1, motorPinR2, motorPinREna, -1, speed);  // Right motor backward
  moveMotor(motorPinL1, motorPinL2, motorPinLEna, 1, speed);   // Left motor forward
Stop both motors.
void stopMotors() {
  moveMotor(motorPinR1, motorPinR2, motorPinREna, 0, 0);  // Stop right motor (set direction to stop and speed to 0)
  moveMotor(motorPinL1, motorPinL2, motorPinLEna, 0, 0);  // Stop left motor (set direction to stop and speed to 0)
Setup function runs once at the beginning to initialize motor pins.
  // Initialize motor pins as OUTPUT
  pinMode(motorPinR1, OUTPUT);
  pinMode(motorPinR2, OUTPUT);
  pinMode(motorPinREna, OUTPUT);
  pinMode(motorPinL1, OUTPUT);
  pinMode(motorPinL2, OUTPUT);
  pinMode(motorPinLEna, OUTPUT);
Main loop function runs repeatedly to perform the robot movements.
  // Move forward with speed 100
  moveForward(100);
  delay(2000);  // Keep moving forward for 2 seconds
  // Move backward with speed 100
  moveBackward(100);
  delay(2000);  // Keep moving backward for 2 seconds
  // Turn right with speed 100
  turnRight(100);
  delay(2000);  // Keep turning right for 2 seconds
  // Turn left with speed 100
  turnLeft(100);
  delay(2000);  // Keep turning left for 2 seconds
  // Stop both motors after completing all movements
  stopMotors();
  delay(1000);  // Wait for 1 second before starting the next iteration
`List item`
Explanation:
  • moveMotor() Function: This function controls the movement of one motor (left or right). It takes the direction and speed as inputs and uses digitalWrite() to set the motor direction and analogWrite() for speed control (PWM).
  • Movement Functions:
    • moveForward(): Moves both motors forward.
    • moveBackward(): Moves both motors backward.
    • turnRight(): Rotates the robot to the right (right motor forward, left motor backward).
    • turnLeft(): Rotates the robot to the left (right motor backward, left motor forward).
    • stopMotors(): Stops both motors by setting the direction to stop and speed to 0.
Customizations:
  • Motor Speed: Adjust the motor speed using PWM values (0-255) in the functions.
  • Motor Pins: Modify the pin numbers if needed to fit your hardware.
  • Movement Timing: You can change the delay() values to control how long the robot moves or turns.
Conclusion:
This code is perfect for controlling basic motor movements with speed adjustment using PWM. It’s great for beginners who want to get started with Arduino-based robot movement projects!
This appears to be AI generated spam.
I'm just using AI to explain.
Which Arduinos, motor drivers and motors have you tested that code with?
arduino uno, ZGA12 motor, L298 driver
Sorry for saying this, but your code is nothing more than the most trivial example of using motors, which is in any Arduino tutorial. Why did you post it?
The question is the same as in your another topic about the millis timer - how is your example different from hundreds of such on the Internet?
Then you should say so.
Also for code that controls hardware including a schematic is essential.
To a newbie motorpinL2 would be meaningless.
These were my own questions and I thought maybe someone would use them. Just because you don't use it doesn't mean no one should use it. These things I put up are mostly for robotics competitions, the sumo robot section.
I guess at least you should post in the Projects - Showcase or Projects - Tutorials category
Hello taha_zarif90
Here too, STRUCTs are your friends :slight_smile:
If motorPinL2 is not present, the left motor can only rotate in one direction.
I know that and you know that but a new person using your code has no idea what it is connected to.
My driver has nothing called motorpinL2 ot Left IN2.
I don't have much experience with structures, but I know they can help organize code better. That's why I didn't use it.
Thanks for your suggestion, I'll use the schematic.
May I know what driver you're using?
I don't see a much logic in this
A L293 driver
But I see.
Without a parts list and a schematic, I would not recommend your code to anyone new to Arduino.
