Arduino Multi-function shield - Turn on an external led
Its possible to turn on a external led in the Arduino Multi-function shield ?
I need the led to be lit at the same time as the beep sounds
Under is the code i am using:
#include <MultiFuncShield.h>
// Countdown Timer
enum CountDownModeValues
  COUNTING_STOPPED,
  COUNTING
byte countDownMode = COUNTING_STOPPED;
byte tenths = 0;
char seconds = 0;
char minutes = 0;
  MFS.initialize();    // initialize multi-function shield library
  MFS.write(0);
  byte btn = MFS.getButton();
  switch (countDownMode)
    case COUNTING_STOPPED:
        if (btn == BUTTON_1_SHORT_RELEASE && (minutes + seconds) > 0)
          // start the timer
          countDownMode = COUNTING;
        else if (btn == BUTTON_1_LONG_PRESSED)
          // reset the timer
          tenths = 0;
          seconds = 0;
          minutes = 0;
          MFS.write(minutes*100 + seconds);
        else if (btn == BUTTON_2_PRESSED || btn == BUTTON_2_LONG_PRESSED)
          minutes++;
          if (minutes > 60)
            minutes = 0;
        else if (btn == BUTTON_3_PRESSED || btn == BUTTON_3_LONG_PRESSED)
          seconds += 10;
          if (seconds >= 60)
            seconds = 0;
    case COUNTING:
        if (btn == BUTTON_1_SHORT_RELEASE || btn == BUTTON_1_LONG_RELEASE)
          // stop the timer
          // continue counting down
          tenths++;
          if (tenths == 10)
            tenths = 0;
            seconds--;
            if (seconds < 0 && minutes > 0)
              seconds = 59;
              minutes--;
            if (minutes == 0 && seconds == 0)
              // timer has reached 0, so sound the alarm
              MFS.beep(50, 50, 3);  // beep 3 times, 500 milliseconds on / 500 off
          delay(100);
don't see where you attempt to control an LED, but you can certainly turn on/off an LED before/after sounding a beep.
i use a multi function shield but not the library code. its LEDS are on pins 10-13. configure a pin as OUTPUT and turn it on by setting it LOW using digitalWrite
