Arduino Nano 33 IOT mit Attiny84A-PU über einen nRF24L01 verbinden
Mein Ziel ist es mit einem Empfänger meherer Sender abarbeiten zu können. Die Attinys sind jeweils die Sender und der Arduino ist der Empfänger.
Der Sender Code schaut so aus:
#include <RF24Network.h>
#include <RF24.h>
#define CE PA2
#define CSN PA3
const int ledPin = PA7;     // Pin für die LED (PA7)
RF24 radio(CE, CSN);             // nRF24L01 (CE,CSN)
RF24Network network(radio);      // Include the radio in the network
const uint16_t this_node = 01;    // Address of our node in Octal format (04,031, etc)
const uint16_t base_node = 00;    // Address of the other node in Octal format
uint8_t deviceNumber_value = 3;
char ID[6] = "00001";
struct PayloadStruct {
  char message[6];  // only using 6 characters for TX & RX payloads
  uint8_t Dev;
  uint8_t counter;
PayloadStruct payload;
  pinMode(ledPin, OUTPUT);
  payload.message[5] = 0;
  radio.begin();
  network.begin(90, this_node); // (channel, node address)
  radio.setDataRate(RF24_250KBPS);
  memcpy(payload.message, ID, 5);  // set the outgoing message
  payload.Dev = deviceNumber_value;
  payload.counter = 0;
  network.update();
  RF24NetworkHeader header1(base_node);   // (Address where the data is going)
  network.write(header1, &payload, sizeof(payload)); // Send the data
  unsigned long start_timeout = millis();  // timer to detect no response
  while (!radio.available()) {             // wait for response or timeout
    if (millis() - start_timeout > 300)    // only wait 300 ms
  PayloadStruct received;
  if (radio.available()) {  // Check if there is a response
    radio.read(&received, sizeof(received)); // Read the response
    // Check if the received message is "True"
    if (strcmp(received.message, "True") == 0) {
      digitalWrite(ledPin, HIGH); // Turn LED on if message is "True"
      digitalWrite(ledPin, LOW);  // Turn LED off otherwise
  // Blink LED while waiting for response
und der Empfänger Code so:
#include <RF24.h>
#include <SPI.h>
#define CE_PIN 6
#define CSN_PIN 5
#define LED 7
RF24 radio(CE_PIN, CSN_PIN);     // nRF24L01 (CE,CSN)
const uint16_t this_node = 00;   // Address of this node in Octal format ( 04,031, etc)
const uint16_t node01 = 01;      // Address of the other node in Octal format
const uint16_t node02 = 02;
char *ID[] = {"00001", "00002", "00003", "00004", "00005", "00006", "00007", "00008"};
  uint8_t Dev;
  uint8_t counter;
  SPI.begin();
  radio.begin();
  network.begin(90, this_node);  //(channel, node address)
  pinMode(LED, OUTPUT);
  network.update();
  if (network.available()) { // Is there any incoming data?
    RF24NetworkHeader header;
    network.read(header, &received, sizeof(received)); // Read the incoming data
    Serial.print("Received Message: ");
    Serial.print(received.message);
    Serial.print(" Device: ");
    Serial.print(received.Dev);
    Serial.print(" Counter: ");
    Serial.println(received.counter);
    // Prepare response
    PayloadStruct response;
    response.Dev = deviceNumber_value;
    response.counter = received.counter + 1;
    // Check if the received message matches any ID
    bool idMatch = false;
    for (int id_index = 0; id_index < 8; id_index++) {
      if (strcmp(received.message, ID[id_index]) == 0) {
        idMatch = true;
    // Set response message based on ID match
    if (idMatch) {
      strcpy(response.message, "True");
      strcpy(response.message, "Wrong");
    // Send response
    RF24NetworkHeader responseHeader(node01);   // (Address where the data is going)
    bool success = network.write(responseHeader, &response, sizeof(response)); // Send the data
    if (success) {
      Serial.println("Response sent successfully");
      Serial.println("Failed to send response");
jetzt sendet der Attiny korrekt seine ID an den Arduino aber es soll eine Antwort zurückgegeben werden ob die ID korrekt war. Und diese Nachricht wird nicht abgeschickt.
Kann mir hier wer helfen?
Im englischen Teil des Forum müssen die Beiträge und Diskussionen in englischer Sprache verfasst werden.
Deswegen wurde diese Diskussion in den deutschen Teil des Forums verschoben.
mfg ein Moderator.
Was bekommst du denn da:
"Success" / "Failed" / gar nichts ?
Ohne dass du mitmachst, nicht.
ich bekomme diesen Output am Arduino
Received Message: 00001 Device: 3 Counter: 0
Der Attiny bekommt bei if (radio.available()) immer false zurück.
Hast du es schon mit radio.setDataRate(RF24_1MBPS); probiert? Es gibt einige „Nachbauten“ die Probleme mit 250KBPS haben. (In beiden Sketchen)
Edit: Sollte auch der Default sein. Auskommentieren/Löschen in beiden Sketchen sollte also das gleiche erreichen.
Edit2: Wie sieht eigentlich die Versorgung der ATTinys aus?
danke für die Info, jetzt bekomme ich schon mal eine Anwort, aber der Sender sendet nur 5x und egal wie lange ich das Programm laufen lasse.
Die Versorgung habe ich über den arduino uno und dessen 3V3 ausgang gemacht.
Der Uno stellt nicht ausreichend Strom auf der 3,3V Schiene bereit. Setze mal ein 100μF Kondensator auf die 3,3V Schiene.
ich habe einen Kondensator bereits eingebaut.
Nun wollt ich versuchen das selbe mit nur einem Sender über den Uno selber zu testen, aber hier wird die If-Abfrage auch dauert false.
das thema hat sich erledigt, es klappt nun
