Greetings and salutations all. It's been a while since my last arduino project, and this time I thought I would go for something a little less complicated. Still, I seem to have hit a snag, and I hope someone can help me out.
I am simpy trying to make my very own HAL9000, and I have started with the electronics using an Arduino Nano, a memory card module a LED and a 3ohm speaker just to get things going.
The plan is to incorporate motion sensor or proximity sensor to have sounds play when people are near... or simply just add a button ;).
Anyways, I am currently using the TMRPCM library, and I do get sound out of my speaker. However, there is a crackle I can hear all the time when the sound is playing and it is really bugging me. I have converted the audio-files to 8 bit, 16kHz sample rate and mono. I do get sound, but there is also noise/crackle.
I even updated pcmConfig.h with #define buffSize 256 to see if that helped, as I found that someone had bypassed the crackle on an Arduino Uno with that setting...
Still, I have the same crackle.
Any ideas as to what I can do? Bear in mind, I haven't added an amplifier circuit as I was under the impression the Nano could drive a 3ohm speaker with no problems.
Any help is most welcome.
