- Project: Remote control Crawling robot
- Author: panerqiang@sunfounder.com
- Date: 2015/1/27
- Overview
- This project was written for the Crawling robot desigened by Sunfounder.
This version of the robot has 4 legs, and each leg is driven by 3 servos.
This robot is driven by a Ardunio Nano Board with an expansion Board.
We recommend that you view the product documentation before using.
- Request
- This project requires some library files, which you can find in the head of
this file. Make sure you have installed these files.
- How to
- Before use,you must to adjust the robot,in order to make it more accurate.
- Adjustment operation
1.uncomment ADJUST, make and run
2.comment ADJUST, uncomment VERIFY
3.measure real sites and set to real_site[4][3], make and run
4.comment VERIFY, make and run
The document describes in detail how to operate.
// modified by Sparklers for smartphone controlled Crawling robot, 3/30/2021
/* Includes ------------------------------------------------------------------*/
#include <Servo.h> //to define and control servos
#include "FlexiTimer2.h"//to set a timer to manage all servos
/* Servos --------------------------------------------------------------------*/
//define 12 servos for 4 legs
char data = 0;
Servo servo[4][3];
//define servos' ports
const int servo_pin[4][3] = { {2, 3, 4}, {5, 6, 7}, {8, 9, 10}, {11, 12, 13} };
/* Size of the robot ---------------------------------------------------------*/
const float length_a = 55;
const float length_b = 77.5;
const float length_c = 27.5;
const float length_side = 71;
const float z_absolute = -28;
/* Constants for movement ----------------------------------------------------*/
const float z_default = -50, z_up = -30, z_boot = z_absolute;
const float x_default = 62, x_offset = 0;
const float y_start = 0, y_step = 40;
const float y_default = x_default;
/* variables for movement ----------------------------------------------------*/
volatile float site_now[4][3]; //real-time coordinates of the end of each leg
volatile float site_expect[4][3]; //expected coordinates of the end of each leg
float temp_speed[4][3]; //each axis' speed, needs to be recalculated before each movement
float move_speed; //movement speed
float speed_multiple = 1; //movement speed multiple
const float spot_turn_speed = 4;
const float leg_move_speed = 8;
const float body_move_speed = 3;
const float stand_seat_speed = 1;
volatile int rest_counter; //+1/0.02s, for automatic rest
//functions' parameter
const float KEEP = 255;
//define PI for calculation
const float pi = 3.1415926;
/* Constants for turn --------------------------------------------------------*/
//temp length
const float temp_a = sqrt(pow(2 * x_default + length_side, 2) + pow(y_step, 2));
const float temp_b = 2 * (y_start + y_step) + length_side;
const float temp_c = sqrt(pow(2 * x_default + length_side, 2) + pow(2 * y_start + y_step + length_side, 2));
const float temp_alpha = acos((pow(temp_a, 2) + pow(temp_b, 2) - pow(temp_c, 2)) / 2 / temp_a / temp_b);
//site for turn
const float turn_x1 = (temp_a - length_side) / 2;
const float turn_y1 = y_start + y_step / 2;
const float turn_x0 = turn_x1 - temp_b * cos(temp_alpha);
const float turn_y0 = temp_b * sin(temp_alpha) - turn_y1 - length_side;
- setup function
//start serial for debug
Serial.println("Robot starts initialization");
//initialize default parameter
pinMode(14, OUTPUT);
set_site(0, x_default - x_offset, y_start + y_step, z_boot);
set_site(1, x_default - x_offset, y_start + y_step, z_boot);
set_site(2, x_default + x_offset, y_start, z_boot);
set_site(3, x_default + x_offset, y_start, z_boot);
for (int i = 0; i < 4; i++)
for (int j = 0; j < 3; j++)
site_now[i][j] = site_expect[i][j];
//start servo service
FlexiTimer2::set(20, servo_service);
FlexiTimer2::start();
Serial.println("Servo service started");
//initialize servos
servo_attach();
Serial.println("Servos initialized");
Serial.println("Robot initialization Complete");
void servo_attach(void)
servo[i][j].attach(servo_pin[i][j]);
delay(100);
void servo_detach(void)
servo[i][j].detach();
delay(100);
- loop function
if(Serial.available() > 0)
data = Serial.read();
Serial.print(data);
Serial.print("\n");
if(data == 'F')
Serial.println("Step forward");
step_forward();
else if(data == 'B')
Serial.println("Step back");
step_back();
else if(data == 'L')
Serial.println("Turn left");
turn_left();
else if(data == 'R')
Serial.println("Turn right");
turn_right();
else if(data == 'X')
Serial.println("Stand");
stand();
else if(data == 'x')
Serial.println("Sit");
sit();
else if(data == 'S' ||data == 'D' )
else if(data == 'W')
digitalWrite(14, HIGH);
else if(data == 'w')
digitalWrite(14, LOW);
else if(data == 'V')
Serial.println("Hand wave");
hand_shake(3);
else if(data == 'v')
hand_shake(3);
else if(data == 'U')
Serial.println("Body dance");
body_dance(10);
else if(data == 'u')
body_dance(10);
while(Serial.available()) {Serial.read();}
- sit
- blocking function
void sit(void)
move_speed = stand_seat_speed;
for (int leg = 0; leg < 4; leg++)
set_site(leg, KEEP, KEEP, z_boot);
wait_all_reach();
- stand
- blocking function
void stand(void)
set_site(leg, KEEP, KEEP, z_default);
wait_all_reach();
- spot turn to left
- blocking function
- parameter step steps wanted to turn
void turn_left()
move_speed = spot_turn_speed;
if (site_now[3][1] == y_start)
//leg 3&1 move
set_site(3, x_default + x_offset, y_start, z_up);
wait_all_reach();
set_site(0, turn_x1 - x_offset, turn_y1, z_default);
set_site(1, turn_x0 - x_offset, turn_y0, z_default);
set_site(2, turn_x1 + x_offset, turn_y1, z_default);
set_site(3, turn_x0 + x_offset, turn_y0, z_up);
wait_all_reach();
set_site(3, turn_x0 + x_offset, turn_y0, z_default);
wait_all_reach();
set_site(0, turn_x1 + x_offset, turn_y1, z_default);
set_site(1, turn_x0 + x_offset, turn_y0, z_default);
set_site(2, turn_x1 - x_offset, turn_y1, z_default);
set_site(3, turn_x0 - x_offset, turn_y0, z_default);
wait_all_reach();
set_site(1, turn_x0 + x_offset, turn_y0, z_up);
wait_all_reach();
set_site(0, x_default + x_offset, y_start, z_default);
set_site(1, x_default + x_offset, y_start, z_up);
set_site(2, x_default - x_offset, y_start + y_step, z_default);
set_site(3, x_default - x_offset, y_start + y_step, z_default);
wait_all_reach();
set_site(1, x_default + x_offset, y_start, z_default);
wait_all_reach();
//leg 0&2 move
set_site(0, x_default + x_offset, y_start, z_up);
wait_all_reach();
set_site(0, turn_x0 + x_offset, turn_y0, z_up);
set_site(1, turn_x1 + x_offset, turn_y1, z_default);
set_site(2, turn_x0 - x_offset, turn_y0, z_default);
set_site(3, turn_x1 - x_offset, turn_y1, z_default);
wait_all_reach();
set_site(0, turn_x0 + x_offset, turn_y0, z_default);
wait_all_reach();
set_site(0, turn_x0 - x_offset, turn_y0, z_default);
set_site(1, turn_x1 - x_offset, turn_y1, z_default);
set_site(2, turn_x0 + x_offset, turn_y0, z_default);
set_site(3, turn_x1 + x_offset, turn_y1, z_default);
wait_all_reach();
set_site(2, turn_x0 + x_offset, turn_y0, z_up);
wait_all_reach();
set_site(0, x_default - x_offset, y_start + y_step, z_default);
set_site(1, x_default - x_offset, y_start + y_step, z_default);
set_site(2, x_default + x_offset, y_start, z_up);
set_site(3, x_default + x_offset, y_start, z_default);
wait_all_reach();
set_site(2, x_default + x_offset, y_start, z_default);
wait_all_reach();
- spot turn to right
- blocking function
void turn_right()
if (site_now[2][1] == y_start)
//leg 2&0 move
wait_all_reach();
wait_all_reach();
wait_all_reach();
wait_all_reach();
wait_all_reach();
wait_all_reach();
wait_all_reach();
//leg 1&3 move
wait_all_reach();
wait_all_reach();
wait_all_reach();
wait_all_reach();
wait_all_reach();
wait_all_reach();
wait_all_reach();
- go forward
- blocking function
- parameter step steps wanted to go
void step_forward()
move_speed = leg_move_speed;
//leg 2&1 move
wait_all_reach();
set_site(2, x_default + x_offset, y_start + 2 * y_step, z_up);
wait_all_reach();
set_site(2, x_default + x_offset, y_start + 2 * y_step, z_default);
wait_all_reach();
move_speed = body_move_speed;
set_site(1, x_default + x_offset, y_start + 2 * y_step, z_default);
wait_all_reach();
set_site(1, x_default + x_offset, y_start + 2 * y_step, z_up);
wait_all_reach();
wait_all_reach();
wait_all_reach();
//leg 0&3 move
wait_all_reach();
set_site(0, x_default + x_offset, y_start + 2 * y_step, z_up);
wait_all_reach();
set_site(0, x_default + x_offset, y_start + 2 * y_step, z_default);
wait_all_reach();
set_site(3, x_default + x_offset, y_start + 2 * y_step, z_default);
wait_all_reach();
set_site(3, x_default + x_offset, y_start + 2 * y_step, z_up);
wait_all_reach();
wait_all_reach();
wait_all_reach();
- go back
- blocking function
void step_back()
//leg 3&0 move
wait_all_reach();
wait_all_reach();
wait_all_reach();
wait_all_reach();
wait_all_reach();
wait_all_reach();
wait_all_reach();
//leg 1&2 move
wait_all_reach();
wait_all_reach();
wait_all_reach();
wait_all_reach();
wait_all_reach();
wait_all_reach();
wait_all_reach();
// add by RegisHsu
void body_left(int i)
set_site(0, site_now[0][0] + i, KEEP, KEEP);
set_site(1, site_now[1][0] + i, KEEP, KEEP);
set_site(2, site_now[2][0] - i, KEEP, KEEP);
set_site(3, site_now[3][0] - i, KEEP, KEEP);
wait_all_reach();
void body_right(int i)
set_site(0, site_now[0][0] - i, KEEP, KEEP);
set_site(1, site_now[1][0] - i, KEEP, KEEP);
set_site(2, site_now[2][0] + i, KEEP, KEEP);
set_site(3, site_now[3][0] + i, KEEP, KEEP);
wait_all_reach();
void hand_wave(int i)
float x_tmp;
float y_tmp;
float z_tmp;
move_speed = 1;
body_right(15);
x_tmp = site_now[2][0];
y_tmp = site_now[2][1];
z_tmp = site_now[2][2];
for (int j = 0; j < i; j++)
set_site(2, turn_x1, turn_y1, 50);
wait_all_reach();
set_site(2, turn_x0, turn_y0, 50);
wait_all_reach();
set_site(2, x_tmp, y_tmp, z_tmp);
wait_all_reach();
move_speed = 1;
body_left(15);
body_left(15);
x_tmp = site_now[0][0];
y_tmp = site_now[0][1];
z_tmp = site_now[0][2];
set_site(0, turn_x1, turn_y1, 50);
wait_all_reach();
set_site(0, turn_x0, turn_y0, 50);
wait_all_reach();
set_site(0, x_tmp, y_tmp, z_tmp);
wait_all_reach();
move_speed = 1;
body_right(15);
void hand_shake(int i)
float x_tmp;
float y_tmp;
float z_tmp;
move_speed = 1;
body_right(15);
set_site(2, x_default - 30, y_start + 2 * y_step, 55);
wait_all_reach();
set_site(2, x_default - 30, y_start + 2 * y_step, 10);
wait_all_reach();
wait_all_reach();
move_speed = 1;
body_left(15);
body_left(15);
set_site(0, x_default - 30, y_start + 2 * y_step, 55);
wait_all_reach();
set_site(0, x_default - 30, y_start + 2 * y_step, 10);
wait_all_reach();
wait_all_reach();
move_speed = 1;
body_right(15);
void head_up(int i)
set_site(0, KEEP, KEEP, site_now[0][2] - i);
set_site(1, KEEP, KEEP, site_now[1][2] + i);
set_site(2, KEEP, KEEP, site_now[2][2] - i);
set_site(3, KEEP, KEEP, site_now[3][2] + i);
wait_all_reach();
void head_down(int i)
set_site(0, KEEP, KEEP, site_now[0][2] + i);
set_site(1, KEEP, KEEP, site_now[1][2] - i);
set_site(2, KEEP, KEEP, site_now[2][2] + i);
set_site(3, KEEP, KEEP, site_now[3][2] - i);
wait_all_reach();
void body_dance(int i)
float x_tmp;
float y_tmp;
float z_tmp;
float body_dance_speed = 2;
sit();
move_speed = 1;
set_site(0, x_default, y_default, KEEP);
set_site(1, x_default, y_default, KEEP);
set_site(2, x_default, y_default, KEEP);
set_site(3, x_default, y_default, KEEP);
wait_all_reach();
//stand();
set_site(0, x_default, y_default, z_default - 20);
set_site(1, x_default, y_default, z_default - 20);
set_site(2, x_default, y_default, z_default - 20);
set_site(3, x_default, y_default, z_default - 20);
wait_all_reach();
move_speed = body_dance_speed;
head_up(30);
if (j > i / 4)
move_speed = body_dance_speed * 2;
if (j > i / 2)
move_speed = body_dance_speed * 3;
set_site(0, KEEP, y_default - 20, KEEP);
set_site(1, KEEP, y_default + 20, KEEP);
set_site(2, KEEP, y_default - 20, KEEP);
set_site(3, KEEP, y_default + 20, KEEP);
wait_all_reach();
set_site(0, KEEP, y_default + 20, KEEP);
set_site(1, KEEP, y_default - 20, KEEP);
set_site(2, KEEP, y_default + 20, KEEP);
set_site(3, KEEP, y_default - 20, KEEP);
wait_all_reach();
head_down(30);
- microservos service /timer interrupt function/50Hz
- when set site expected,this function move the end point to it in a straight line
- temp_speed[4][3] should be set before set expect site,it make sure the end point
move in a straight line,and decide move speed.
void servo_service(void)
sei();
static float alpha, beta, gamma;
if (abs(site_now[i][j] - site_expect[i][j]) >= abs(temp_speed[i][j]))
site_now[i][j] += temp_speed[i][j];
cartesian_to_polar(alpha, beta, gamma, site_now[i][0], site_now[i][1], site_now[i][2]);
polar_to_servo(i, alpha, beta, gamma);
rest_counter++;
- set one of end points' expect site
- this founction will set temp_speed[4][3] at same time
- non - blocking function
void set_site(int leg, float x, float y, float z)
float length_x = 0, length_y = 0, length_z = 0;
if (x != KEEP)
length_x = x - site_now[leg][0];
if (y != KEEP)
length_y = y - site_now[leg][1];
if (z != KEEP)
length_z = z - site_now[leg][2];
float length = sqrt(pow(length_x, 2) + pow(length_y, 2) + pow(length_z, 2));
temp_speed[leg][0] = length_x / length * move_speed * speed_multiple;
temp_speed[leg][1] = length_y / length * move_speed * speed_multiple;
temp_speed[leg][2] = length_z / length * move_speed * speed_multiple;
if (x != KEEP)
site_expect[leg][0] = x;
if (y != KEEP)
site_expect[leg][1] = y;
if (z != KEEP)
site_expect[leg][2] = z;
- wait one of end points move to expect site
- blocking function
void wait_reach(int leg)
while (1)
if (site_now[leg][0] == site_expect[leg][0])
if (site_now[leg][1] == site_expect[leg][1])
if (site_now[leg][2] == site_expect[leg][2])
- wait all of end points move to expect site
- blocking function
void wait_all_reach(void)
wait_reach(i);
- trans site from cartesian to polar
- mathematical model 2/2
void cartesian_to_polar(volatile float &alpha, volatile float &beta, volatile float &gamma, volatile float x, volatile float y, volatile float z)
//calculate w-z degree
float v, w;
w = (x >= 0 ? 1 : -1) * (sqrt(pow(x, 2) + pow(y, 2)));
v = w - length_c;
alpha = atan2(z, v) + acos((pow(length_a, 2) - pow(length_b, 2) + pow(v, 2) + pow(z, 2)) / 2 / length_a / sqrt(pow(v, 2) + pow(z, 2)));
beta = acos((pow(length_a, 2) + pow(length_b, 2) - pow(v, 2) - pow(z, 2)) / 2 / length_a / length_b);
//calculate x-y-z degree
gamma = (w >= 0) ? atan2(y, x) : atan2(-y, -x);
//trans degree pi->180
alpha = alpha / pi * 180;
beta = beta / pi * 180;
gamma = gamma / pi * 180;
- trans site from polar to microservos
- mathematical model map to fact
- the errors saved in eeprom will be add
void polar_to_servo(int leg, float alpha, float beta, float gamma)
if (leg == 0)
alpha = 90 - alpha;
beta = beta;
gamma += 90;
else if (leg == 1)
alpha += 90;
beta = 180 - beta;
gamma = 90 - gamma;
else if (leg == 2)
alpha += 90;
beta = 180 - beta;
gamma = 90 - gamma;
else if (leg == 3)
alpha = 90 - alpha;
beta = beta;
gamma += 90;
servo[leg][0].write(alpha);
servo[leg][1].write(beta);
servo[leg][2].write(gamma);
