Hi. I'm trying to use two SSD1306 through a TCA9548A together with a rotary encoder. When turning the encoder CCW, display #1 should count downwards and by turning the other way, display #2 should count upwards.
I've tested the display with a separate code and it works.
I've tested the rotary encoder with a separate code and it works.
My problem is when I merge the two codes. Then both displays show "0". The rotary does not respond (no feedback on display or SerialMonitor). Only the push-function seems to work.
Any ideas?
Here's my code:
For the display:
#include <Wire.h>
#include <Adafruit_SSD1306.h>
#include <Adafruit_BMP280.h>
#include <Adafruit_ADXL345_U.h>
// SSD1306 def:
#define SCREEN_WIDTH 128
#define SCREEN_HEIGHT 64
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, -1);
int UPvalue = 0;
int DOWNvalue = 0;
// Start I2C communication
Wire.begin();
// Initialize multiplexer on bus number 2
TCA9548A(0);
if(!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) {
Serial.println(F("SSD1306 allocation failed"));
for(;;);
display.clearDisplay();
// Initialize multiplexer on bus number 3
TCA9548A(1);
for(;;);
DisplayValue(0,UPvalue);
DisplayValue(1,DOWNvalue);
UPvalue++;
DOWNvalue--;
void DisplayValue(int displayNumber, int outputValue)
TCA9548A(displayNumber);
// Display altitude on SSD1306 OLED display
display.clearDisplay(); // Clear display buffer
display.setTextSize(2);
display.setTextColor(WHITE); // Set text color to white
display.setCursor(0, 0);
display.print(outputValue);
display.display();
// Select I2C BUS
void TCA9548A(uint8_t bus)
Wire.beginTransmission(0x70); // TCA9548A address
Wire.write(1 << bus); // send byte to select bus
Wire.endTransmission();
//Serial.print("bus active:" );
//Serial.println(bus);
For the rotary encoder:
#include <Arduino.h>
// Rotary encoder pins
#define PIN_A 2
#define PIN_B 3
#define PUSH_BTN 4
// A turn counter for the rotary encoder (negative = anti-clockwise)
int rotationCounter = 0;
int UPvalue = 0;
int DOWNvalue = 0;
// Flag from interrupt routine (moved=true)
volatile bool rotaryEncoder = false;
// The module already has pullup resistors on board
pinMode(PIN_A, INPUT);
pinMode(PIN_B, INPUT);
// But not for the push switch
pinMode(PUSH_BTN, INPUT_PULLUP);
// We need to monitor both pins, rising and falling for all states
attachInterrupt(digitalPinToInterrupt(PIN_A), rotary, CHANGE);
attachInterrupt(digitalPinToInterrupt(PIN_B), rotary, CHANGE);
Serial.println("Setup completed");
// Has rotary encoder moved?
if (rotaryEncoder)
// Get the movement (if valid)
int8_t rotationValue = checkRotaryEncoder();
// If valid movement, do something
if (rotationValue > 0)
UPvalue += rotationValue;
Serial.print("UPvalue: ");
Serial.println(UPvalue);
if (rotationValue < 0)
DOWNvalue += rotationValue;
Serial.print("DOWNvalue: ");
Serial.println(DOWNvalue);
if (digitalRead(PUSH_BTN) == LOW)
UPvalue = 0;
DOWNvalue = 0;
// Wait until button released (demo only! Blocking call!)
while (digitalRead(PUSH_BTN) == LOW)
delay(100);
//Interrupt/encoder-code copied from RalphBacon /226-Better-Rotary-Encoder---no-switch-bounce:
// Interrupt routine just sets a flag when rotation is detected
void rotary()
rotaryEncoder = true;
// Rotary encoder has moved (interrupt tells us) but what happened?
// See https://www.pinteric.com/rotary.html
int8_t checkRotaryEncoder()
// Reset the flag that brought us here (from ISR)
static uint8_t lrmem = 3;
static int lrsum = 0;
static int8_t TRANS[] = {0, -1, 1, 14, 1, 0, 14, -1, -1, 14, 0, 1, 14, 1, -1, 0};
// Read BOTH pin states to deterimine validity of rotation (ie not just switch bounce)
int8_t l = digitalRead(PIN_A);
int8_t r = digitalRead(PIN_B);
// Move previous value 2 bits to the left and add in our new values
lrmem = ((lrmem & 0x03) << 2) + 2 * l + r;
// Convert the bit pattern to a movement indicator (14 = impossible, ie switch bounce)
lrsum += TRANS[lrmem];
/* encoder not in the neutral (detent) state */
if (lrsum % 4 != 0)
return 0;
/* encoder in the neutral state - clockwise rotation*/
if (lrsum == 4)
lrsum = 0;
return 1;
/* encoder in the neutral state - anti-clockwise rotation*/
if (lrsum == -4)
lrsum = 0;
return -1;
// An impossible rotation has been detected - ignore the movement
lrsum = 0;
return 0;
Merged code:
#include <Wire.h>
// SSD1306 def:
#define PIN_A 2
#define PIN_B 3
#define PUSH_BTN 4
int UPvalue = 0;
int DOWNvalue = 0;
Wire.begin();
// Init screen 0
TCA9548A(0);
for(;;);
// Init screen 1
TCA9548A(1);
for(;;);
if (rotaryEncoder)
UPvalue = 0;
DOWNvalue = 0;
delay(100);
//UPvalue++;
//DOWNvalue--;
//delay(500);
display.display();
// Select I2C BUS
void rotary()
if (lrsum % 4 != 0)
return 0;
if (lrsum == 4)
lrsum = 0;
return 1;
if (lrsum == -4)
lrsum = 0;
return -1;
lrsum = 0;
return 0;
