Arduino Nano @ delay signal
Hello,
I use the arduino Nano.
I'm trying to create a delay signal (~1.2sec) after turning power ON.
Pin "D2" reading power ON, with a resistor 20K to GND and 1K to +5V
Pin "D13": output for delay signal
But I get an oscillation on signal output ?!
Could anyone please explain this issue ?
Here is my code:
// Set pin numbers:
const int powerOn = 'D2';     // at pin #2, adding a resistor 1K pull up and a resistor 20K to GND !!! ***
const int BLM_RESET = 'D13';
// variables will change:
int poweronState = 0;      // variable to read the status of power
  // initialize the powerOn pin as an input:
  pinMode(powerOn, INPUT);
  // initialize delai_1.2 s as an output:
  pinMode(BLM_RESET, OUTPUT);
  // read the state of the poweronState value:
  poweronState = digitalRead(powerOn);
   // check if the power is ON. If it is, the pin #2 is HIGH:
  if (poweronState == HIGH) {  // power is ON
    delay(1200); // waiting for 1200 ms (1.2s) before BLM_RESET is actived HIGH
    digitalWrite(BLM_RESET, HIGH);
  else {
    // if power is OFF, turn BLM_RESET off:
    digitalWrite(BLM_RESET, LOW);
    // delay(20);
You're not using a Nano 33 IoT so your topic has been moved to a more suitable location on the forum.
Where do you get the below from?
That should just be 2 and 13, no D and no ticks around them.
the
signal
Thanks for replying. Note.
You are using pin 13.
I think your problem is that the bootloader flashes the pin13 LED just after power up (or reset).
Try using any other pin for your delay signal.
Hi all,
I found the problem: I use the USB cable (or +5V on board, pin 27) to power pin D2.
After using the power extern, I don't see the oscillation on the delay signal.
Thanks for your support !
Hi, I see the same behave on other pin. Your idea is closed to this issue.
