Arduino Nano ESP32 s3 issue with flashing
I am using Arduino Nano ESP32 S3. I tries uploading the code multiple times. Tried different cables and also tried uploading just the blink examples. Gone through all the post as well on the forum. Tried all the alternatives. There was one that was working for me which is connecting B1 and Gnd and then flashing in the bootloader mode but I need to change the program on the go which is not possible with this method.
My Errors and settings are as below:
Please let me know what’s the issue with this board. It was a new one I got from the official Arduino distributor.
I use “Upload using Programmer”
Try Usb mode>> USB CDC on Boot.
Hi @v_deepanon.
That is the cause of the "PermissionError(13, 'A device attached to the system is not functioning.', None, 31)" upload error you encountered.
Leave the configuration as "Normal mode (TinyUSB)" and then do a standard upload (either by clicking the "Upload" button on the Arduino IDE toolbar, or by selecting Sketch > Upload from the Arduino IDE menus), not an "Upload Using Programmer".
Let us know if the upload still fails when you do the standard upload.
Hi @ptillisch ,
With standard upload, I get the error “No DFU capable device found”
Hi @kmin
Still upload error. Thanks for the suggestion though @kmin @ptillisch . Please let me know if there’s any other way. Even after buying through official channel to ensure the device is not a fake, I didn’t expect it to be so hard to make it flash in the least.
I still have the issue open, if anyone has any solutions, can you please comment?
I'm going to ask you to provide the full verbose output from a normal upload attempt.
:red_exclamation_mark: This procedure is not intended to solve the problem. The purpose is to gather more information.
Please do this:
  1. Select File > Preferences... (or Arduino IDE > Settings... for macOS users) from the Arduino IDE menus.
    The "Preferences" dialog will open.
  2. Uncheck the box next to Show verbose output during: compile in the "Preferences" dialog.
  3. Check the box next to Show verbose output during: ☐ upload.
  4. Click the "OK" button.
    The "Preferences" dialog will close.
  5. Attempt an upload, as you did before.
  6. Wait for the upload to fail.
  7. You will see an "Upload error: ..." notification at the bottom right corner of the Arduino IDE window. Click the "COPY ERROR MESSAGES" button on that notification.
  8. Open a reply here on this forum topic by clicking the "Reply" button.
  9. Click the <CODE/> icon on the post composer toolbar.
    This will add the forum's code block markup (```) to your reply to make sure the error messages are correctly formatted.
  10. Press the Ctrl+V keyboard shortcut (Command+V for macOS users).
    This will paste the error output from the upload into the code block.
  11. Move the cursor outside of the code block markup before you add any additional text to your reply.
  12. Click the "Reply" button to publish the post.
I'm not the same person, but I have the same issue with my board. Here is the error log @ptillisch
FQBN: arduino:esp32:nano_nora
Using board 'nano_nora' from platform in folder: C:\Users\Levi\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.18-arduino.5
Using core 'esp32' from platform in folder: C:\Users\Levi\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.18-arduino.5
cmd /c if exist "C:\\Users\\Levi\\AppData\\Local\\Temp\\.arduinoIDE-unsaved20251128-916-j2c6mt.ii6k\\sketch_dec28a\\partitions.csv" COPY /y "C:\\Users\\Levi\\AppData\\Local\\Temp\\.arduinoIDE-unsaved20251128-916-j2c6mt.ii6k\\sketch_dec28a\\partitions.csv" "C:\\Users\\Levi\\AppData\\Local\\arduino\\sketches\\A366996E717B2298F7665A339C5822A2\\partitions.csv"
cmd /c if not exist "C:\\Users\\Levi\\AppData\\Local\\arduino\\sketches\\A366996E717B2298F7665A339C5822A2\\partitions.csv" if exist "C:\\Users\\Levi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.18-arduino.5\\variants\\arduino_nano_nora\\partitions.csv" COPY "C:\\Users\\Levi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.18-arduino.5\\variants\\arduino_nano_nora\\partitions.csv" "C:\\Users\\Levi\\AppData\\Local\\arduino\\sketches\\A366996E717B2298F7665A339C5822A2\\partitions.csv"
cmd /c if not exist "C:\\Users\\Levi\\AppData\\Local\\arduino\\sketches\\A366996E717B2298F7665A339C5822A2\\partitions.csv" COPY "C:\\Users\\Levi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.18-arduino.5\\tools\\partitions\\app3M_fat9M_fact512k_16MB.csv" "C:\\Users\\Levi\\AppData\\Local\\arduino\\sketches\\A366996E717B2298F7665A339C5822A2\\partitions.csv"
cmd /c IF EXIST "C:\\Users\\Levi\\AppData\\Local\\Temp\\.arduinoIDE-unsaved20251128-916-j2c6mt.ii6k\\sketch_dec28a\\bootloader.bin" ( COPY /y "C:\\Users\\Levi\\AppData\\Local\\Temp\\.arduinoIDE-unsaved20251128-916-j2c6mt.ii6k\\sketch_dec28a\\bootloader.bin" "C:\\Users\\Levi\\AppData\\Local\\arduino\\sketches\\A366996E717B2298F7665A339C5822A2\\sketch_dec28a.ino.bootloader.bin" ) ELSE ( IF EXIST "C:\\Users\\Levi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.18-arduino.5\\variants\\arduino_nano_nora\\bootloader.bin" ( COPY "C:\\Users\\Levi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.18-arduino.5\\variants\\arduino_nano_nora\\bootloader.bin" "C:\\Users\\Levi\\AppData\\Local\\arduino\\sketches\\A366996E717B2298F7665A339C5822A2\\sketch_dec28a.ino.bootloader.bin" ) ELSE ( "C:\\Users\\Levi\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esptool_py\\4.5.1\\esptool.exe" --chip esp32s3 elf2image --flash_mode dio --flash_freq 80m --flash_size 16MB -o "C:\\Users\\Levi\\AppData\\Local\\arduino\\sketches\\A366996E717B2298F7665A339C5822A2\\sketch_dec28a.ino.bootloader.bin" "C:\\Users\\Levi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.18-arduino.5\\tools\\sdk\\esp32s3\\bin\\bootloader_qio_80m.elf" ) )
esptool.py v4.5.1
Creating esp32s3 image...
Merged 1 ELF section
Successfully created esp32s3 image.
cmd /c if exist "C:\\Users\\Levi\\AppData\\Local\\Temp\\.arduinoIDE-unsaved20251128-916-j2c6mt.ii6k\\sketch_dec28a\\build_opt.h" COPY /y "C:\\Users\\Levi\\AppData\\Local\\Temp\\.arduinoIDE-unsaved20251128-916-j2c6mt.ii6k\\sketch_dec28a\\build_opt.h" "C:\\Users\\Levi\\AppData\\Local\\arduino\\sketches\\A366996E717B2298F7665A339C5822A2\\build_opt.h"
cmd /c if not exist "C:\\Users\\Levi\\AppData\\Local\\arduino\\sketches\\A366996E717B2298F7665A339C5822A2\\build_opt.h" type nul > "C:\\Users\\Levi\\AppData\\Local\\arduino\\sketches\\A366996E717B2298F7665A339C5822A2\\build_opt.h"
cmd /c type nul > "C:\\Users\\Levi\\AppData\\Local\\arduino\\sketches\\A366996E717B2298F7665A339C5822A2/file_opts"
Detecting libraries used...
C:\Users\Levi\AppData\Local\Arduino15\packages\esp32\tools\s3-gcc\2021r2-p5/bin/xtensa-esp32s3-elf-g++ -DHAVE_CONFIG_H -DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE -DIDF_VER="v4.4.7-dirty" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS -iprefix C:\Users\Levi\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.18-arduino.5/tools/sdk/esp32s3/include/ -iwithprefixbefore newlib/platform_include -iwithprefixbefore freertos/include -iwithprefixbefore freertos/include/esp_additions/freertos -iwithprefixbefore freertos/port/xtensa/include -iwithprefixbefore freertos/include/esp_additions -iwithprefixbefore esp_hw_support/include -iwithprefixbefore esp_hw_support/include/soc -iwithprefixbefore esp_hw_support/include/soc/esp32s3 -iwithprefixbefore esp_hw_support/port/esp32s3 -iwithprefixbefore esp_hw_support/port/esp32s3/private_include -iwithprefixbefore heap/include -iwithprefixbefore log/include -iwithprefixbefore lwip/include/apps -iwithprefixbefore lwip/include/apps/sntp -iwithprefixbefore lwip/lwip/src/include -iwithprefixbefore lwip/port/esp32/include -iwithprefixbefore lwip/port/esp32/include/arch -iwithprefixbefore soc/include -iwithprefixbefore soc/esp32s3 -iwithprefixbefore soc/esp32s3/include -iwithprefixbefore hal/esp32s3/include -iwithprefixbefore hal/include -iwithprefixbefore hal/platform_port/include -iwithprefixbefore esp_rom/include -iwithprefixbefore esp_rom/include/esp32s3 -iwithprefixbefore esp_rom/esp32s3 -iwithprefixbefore esp_common/include -iwithprefixbefore esp_system/include -iwithprefixbefore esp_system/port/soc -iwithprefixbefore esp_system/port/public_compat -iwithprefixbefore xtensa/include -iwithprefixbefore xtensa/esp32s3/include -iwithprefixbefore driver/include -iwithprefixbefore driver/esp32s3/include -iwithprefixbefore esp_pm/include -iwithprefixbefore esp_ringbuf/include -iwithprefixbefore efuse/include -iwithprefixbefore efuse/esp32s3/include -iwithprefixbefore vfs/include -iwithprefixbefore esp_wifi/include -iwithprefixbefore esp_event/include -iwithprefixbefore esp_netif/include -iwithprefixbefore esp_eth/include -iwithprefixbefore tcpip_adapter/include -iwithprefixbefore esp_phy/include -iwithprefixbefore esp_phy/esp32s3/include -iwithprefixbefore esp_ipc/include -iwithprefixbefore app_trace/include -iwithprefixbefore esp_timer/include -iwithprefixbefore mbedtls/port/include -iwithprefixbefore mbedtls/mbedtls/include -iwithprefixbefore mbedtls/esp_crt_bundle/include -iwithprefixbefore app_update/include -iwithprefixbefore spi_flash/include -iwithprefixbefore bootloader_support/include -iwithprefixbefore nvs_flash/include -iwithprefixbefore pthread/include -iwithprefixbefore esp_gdbstub/include -iwithprefixbefore esp_gdbstub/xtensa -iwithprefixbefore esp_gdbstub/esp32s3 -iwithprefixbefore espcoredump/include -iwithprefixbefore espcoredump/include/port/xtensa -iwithprefixbefore wpa_supplicant/include -iwithprefixbefore wpa_supplicant/port/include -iwithprefixbefore wpa_supplicant/esp_supplicant/include -iwithprefixbefore ieee802154/include -iwithprefixbefore console -iwithprefixbefore asio/asio/asio/include -iwithprefixbefore asio/port/include -iwithprefixbefore bt/common/osi/include -iwithprefixbefore bt/include/esp32c3/include -iwithprefixbefore bt/common/api/include/api -iwithprefixbefore bt/common/btc/profile/esp/blufi/include -iwithprefixbefore bt/common/btc/profile/esp/include -iwithprefixbefore bt/host/bluedroid/api/include/api -iwithprefixbefore bt/esp_ble_mesh/mesh_common/include -iwithprefixbefore bt/esp_ble_mesh/mesh_common/tinycrypt/include -iwithprefixbefore bt/esp_ble_mesh/mesh_core -iwithprefixbefore bt/esp_ble_mesh/mesh_core/include -iwithprefixbefore bt/esp_ble_mesh/mesh_core/storage -iwithprefixbefore bt/esp_ble_mesh/btc/include -iwithprefixbefore bt/esp_ble_mesh/mesh_models/common/include -iwithprefixbefore bt/esp_ble_mesh/mesh_models/client/include -iwithprefixbefore bt/esp_ble_mesh/mesh_models/server/include -iwithprefixbefore bt/esp_ble_mesh/api/core/include -iwithprefixbefore bt/esp_ble_mesh/api/models/include -iwithprefixbefore bt/esp_ble_mesh/api -iwithprefixbefore cbor/port/include -iwithprefixbefore unity/include -iwithprefixbefore unity/unity/src -iwithprefixbefore cmock/CMock/src -iwithprefixbefore coap/port/include -iwithprefixbefore coap/libcoap/include -iwithprefixbefore nghttp/port/include -iwithprefixbefore nghttp/nghttp2/lib/includes -iwithprefixbefore esp-tls -iwithprefixbefore esp-tls/esp-tls-crypto -iwithprefixbefore esp_adc_cal/include -iwithprefixbefore esp_hid/include -iwithprefixbefore tcp_transport/include -iwithprefixbefore esp_http_client/include -iwithprefixbefore esp_http_server/include -iwithprefixbefore esp_https_ota/include -iwithprefixbefore esp_https_server/include -iwithprefixbefore esp_lcd/include -iwithprefixbefore esp_lcd/interface -iwithprefixbefore protobuf-c/protobuf-c -iwithprefixbefore protocomm/include/common -iwithprefixbefore protocomm/include/security -iwithprefixbefore protocomm/include/transports -iwithprefixbefore mdns/include -iwithprefixbefore esp_local_ctrl/include -iwithprefixbefore sdmmc/include -iwithprefixbefore esp_serial_slave_link/include -iwithprefixbefore esp_websocket_client/include -iwithprefixbefore expat/expat/expat/lib -iwithprefixbefore expat/port/include -iwithprefixbefore wear_levelling/include -iwithprefixbefore fatfs/diskio -iwithprefixbefore fatfs/vfs -iwithprefixbefore fatfs/src -iwithprefixbefore freemodbus/freemodbus/common/include -iwithprefixbefore idf_test/include -iwithprefixbefore idf_test/include/esp32s3 -iwithprefixbefore jsmn/include -iwithprefixbefore json/cJSON -iwithprefixbefore libsodium/libsodium/src/libsodium/include -iwithprefixbefore libsodium/port_include -iwithprefixbefore mqtt/esp-mqtt/include -iwithprefixbefore openssl/include -iwithprefixbefore perfmon/include -iwithprefixbefore spiffs/include -iwithprefixbefore usb/include -iwithprefixbefore ulp/include -iwithprefixbefore wifi_provisioning/include -iwithprefixbefore rmaker_common/include -iwithprefixbefore esp_diagnostics/include -iwithprefixbefore rtc_store/include -iwithprefixbefore esp_insights/include -iwithprefixbefore json_parser/upstream/include -iwithprefixbefore json_parser/upstream -iwithprefixbefore json_generator/upstream -iwithprefixbefore esp_schedule/include -iwithprefixbefore espressif__esp_secure_cert_mgr/include -iwithprefixbefore esp_rainmaker/include -iwithprefixbefore gpio_button/button/include -iwithprefixbefore qrcode/include -iwithprefixbefore ws2812_led -iwithprefixbefore freertos/include/freertos -iwithprefixbefore arduino_tinyusb/tinyusb/src -iwithprefixbefore arduino_tinyusb/include -iwithprefixbefore esp_littlefs/include -iwithprefixbefore esp-dl/include -iwithprefixbefore esp-dl/include/tool -iwithprefixbefore esp-dl/include/typedef -iwithprefixbefore esp-dl/include/image -iwithprefixbefore esp-dl/include/math -iwithprefixbefore esp-dl/include/nn -iwithprefixbefore esp-dl/include/layer -iwithprefixbefore esp-dl/include/detect -iwithprefixbefore esp-dl/include/model_zoo -iwithprefixbefore esp32-camera/driver/include -iwithprefixbefore esp32-camera/conversions/include -iwithprefixbefore espressif__esp-dsp/modules/dotprod/include -iwithprefixbefore espressif__esp-dsp/modules/support/include -iwithprefixbefore espressif__esp-dsp/modules/support/mem/include -iwithprefixbefore espressif__esp-dsp/modules/windows/include -iwithprefixbefore espressif__esp-dsp/modules/windows/hann/include -iwithprefixbefore espressif__esp-dsp/modules/windows/blackman/include -iwithprefixbefore espressif__esp-dsp/modules/windows/blackman_harris/include -iwithprefixbefore espressif__esp-dsp/modules/windows/blackman_nuttall/include -iwithprefixbefore espressif__esp-dsp/modules/windows/nuttall/include -iwithprefixbefore espressif__esp-dsp/modules/windows/flat_top/include -iwithprefixbefore espressif__esp-dsp/modules/iir/include -iwithprefixbefore espressif__esp-dsp/modules/fir/include -iwithprefixbefore espressif__esp-dsp/modules/math/include -iwithprefixbefore espressif__esp-dsp/modules/math/add/include -iwithprefixbefore espressif__esp-dsp/modules/math/sub/include -iwithprefixbefore espressif__esp-dsp/modules/math/mul/include -iwithprefixbefore espressif__esp-dsp/modules/math/addc/include -iwithprefixbefore espressif__esp-dsp/modules/math/mulc/include -iwithprefixbefore espressif__esp-dsp/modules/math/sqrt/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/mul/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/add/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/addc/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/mulc/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/sub/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/include -iwithprefixbefore espressif__esp-dsp/modules/fft/include -iwithprefixbefore espressif__esp-dsp/modules/dct/include -iwithprefixbefore espressif__esp-dsp/modules/conv/include -iwithprefixbefore espressif__esp-dsp/modules/common/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/mul/test/include -iwithprefixbefore espressif__esp-dsp/modules/kalman/ekf/include -iwithprefixbefore espressif__esp-dsp/modules/kalman/ekf_imu13states/include -iwithprefixbefore fb_gfx/include -IC:\Users\Levi\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.18-arduino.5/tools/sdk/esp32s3/qio_opi/include -mlongcalls -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -c -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_NANO_ESP32 -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="NANO_ESP32" -DARDUINO_VARIANT="arduino_nano_nora" -DARDUINO_PARTITION_app3M_fat9M_fact512k_16MB -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DBOARD_HAS_PIN_REMAP -DBOARD_HAS_PSRAM -DUSB_MANUFACTURER="Arduino" -DUSB_PRODUCT="Nano ESP32" -DARDUINO_USB_MODE=0 -DARDUINO_USB_CDC_ON_BOOT=1 -DARDUINO_USB_MSC_ON_BOOT=0 -DARDUINO_USB_DFU_ON_BOOT=1 @C:\Users\Levi\AppData\Local\arduino\sketches\A366996E717B2298F7665A339C5822A2/build_opt.h @C:\Users\Levi\AppData\Local\arduino\sketches\A366996E717B2298F7665A339C5822A2/file_opts -IC:\Users\Levi\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.18-arduino.5\cores\esp32 -IC:\Users\Levi\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.18-arduino.5\variants\arduino_nano_nora C:\Users\Levi\AppData\Local\arduino\sketches\A366996E717B2298F7665A339C5822A2\sketch\sketch_dec28a.ino.cpp -o nul
Generating function prototypes...
C:\Users\Levi\AppData\Local\Arduino15\packages\esp32\tools\s3-gcc\2021r2-p5/bin/xtensa-esp32s3-elf-g++ -DHAVE_CONFIG_H -DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE -DIDF_VER="v4.4.7-dirty" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS -iprefix C:\Users\Levi\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.18-arduino.5/tools/sdk/esp32s3/include/ -iwithprefixbefore newlib/platform_include -iwithprefixbefore freertos/include -iwithprefixbefore freertos/include/esp_additions/freertos -iwithprefixbefore freertos/port/xtensa/include -iwithprefixbefore freertos/include/esp_additions -iwithprefixbefore esp_hw_support/include -iwithprefixbefore esp_hw_support/include/soc -iwithprefixbefore esp_hw_support/include/soc/esp32s3 -iwithprefixbefore esp_hw_support/port/esp32s3 -iwithprefixbefore esp_hw_support/port/esp32s3/private_include -iwithprefixbefore heap/include -iwithprefixbefore log/include -iwithprefixbefore lwip/include/apps -iwithprefixbefore lwip/include/apps/sntp -iwithprefixbefore lwip/lwip/src/include -iwithprefixbefore lwip/port/esp32/include -iwithprefixbefore lwip/port/esp32/include/arch -iwithprefixbefore soc/include -iwithprefixbefore soc/esp32s3 -iwithprefixbefore soc/esp32s3/include -iwithprefixbefore hal/esp32s3/include -iwithprefixbefore hal/include -iwithprefixbefore hal/platform_port/include -iwithprefixbefore esp_rom/include -iwithprefixbefore esp_rom/include/esp32s3 -iwithprefixbefore esp_rom/esp32s3 -iwithprefixbefore esp_common/include -iwithprefixbefore esp_system/include -iwithprefixbefore esp_system/port/soc -iwithprefixbefore esp_system/port/public_compat -iwithprefixbefore xtensa/include -iwithprefixbefore xtensa/esp32s3/include -iwithprefixbefore driver/include -iwithprefixbefore driver/esp32s3/include -iwithprefixbefore esp_pm/include -iwithprefixbefore esp_ringbuf/include -iwithprefixbefore efuse/include -iwithprefixbefore efuse/esp32s3/include -iwithprefixbefore vfs/include -iwithprefixbefore esp_wifi/include -iwithprefixbefore esp_event/include -iwithprefixbefore esp_netif/include -iwithprefixbefore esp_eth/include -iwithprefixbefore tcpip_adapter/include -iwithprefixbefore esp_phy/include -iwithprefixbefore esp_phy/esp32s3/include -iwithprefixbefore esp_ipc/include -iwithprefixbefore app_trace/include -iwithprefixbefore esp_timer/include -iwithprefixbefore mbedtls/port/include -iwithprefixbefore mbedtls/mbedtls/include -iwithprefixbefore mbedtls/esp_crt_bundle/include -iwithprefixbefore app_update/include -iwithprefixbefore spi_flash/include -iwithprefixbefore bootloader_support/include -iwithprefixbefore nvs_flash/include -iwithprefixbefore pthread/include -iwithprefixbefore esp_gdbstub/include -iwithprefixbefore esp_gdbstub/xtensa -iwithprefixbefore esp_gdbstub/esp32s3 -iwithprefixbefore espcoredump/include -iwithprefixbefore espcoredump/include/port/xtensa -iwithprefixbefore wpa_supplicant/include -iwithprefixbefore wpa_supplicant/port/include -iwithprefixbefore wpa_supplicant/esp_supplicant/include -iwithprefixbefore ieee802154/include -iwithprefixbefore console -iwithprefixbefore asio/asio/asio/include -iwithprefixbefore asio/port/include -iwithprefixbefore bt/common/osi/include -iwithprefixbefore bt/include/esp32c3/include -iwithprefixbefore bt/common/api/include/api -iwithprefixbefore bt/common/btc/profile/esp/blufi/include -iwithprefixbefore bt/common/btc/profile/esp/include -iwithprefixbefore bt/host/bluedroid/api/include/api -iwithprefixbefore bt/esp_ble_mesh/mesh_common/include -iwithprefixbefore bt/esp_ble_mesh/mesh_common/tinycrypt/include -iwithprefixbefore bt/esp_ble_mesh/mesh_core -iwithprefixbefore bt/esp_ble_mesh/mesh_core/include -iwithprefixbefore bt/esp_ble_mesh/mesh_core/storage -iwithprefixbefore bt/esp_ble_mesh/btc/include -iwithprefixbefore bt/esp_ble_mesh/mesh_models/common/include -iwithprefixbefore bt/esp_ble_mesh/mesh_models/client/include -iwithprefixbefore bt/esp_ble_mesh/mesh_models/server/include -iwithprefixbefore bt/esp_ble_mesh/api/core/include -iwithprefixbefore bt/esp_ble_mesh/api/models/include -iwithprefixbefore bt/esp_ble_mesh/api -iwithprefixbefore cbor/port/include -iwithprefixbefore unity/include -iwithprefixbefore unity/unity/src -iwithprefixbefore cmock/CMock/src -iwithprefixbefore coap/port/include -iwithprefixbefore coap/libcoap/include -iwithprefixbefore nghttp/port/include -iwithprefixbefore nghttp/nghttp2/lib/includes -iwithprefixbefore esp-tls -iwithprefixbefore esp-tls/esp-tls-crypto -iwithprefixbefore esp_adc_cal/include -iwithprefixbefore esp_hid/include -iwithprefixbefore tcp_transport/include -iwithprefixbefore esp_http_client/include -iwithprefixbefore esp_http_server/include -iwithprefixbefore esp_https_ota/include -iwithprefixbefore esp_https_server/include -iwithprefixbefore esp_lcd/include -iwithprefixbefore esp_lcd/interface -iwithprefixbefore protobuf-c/protobuf-c -iwithprefixbefore protocomm/include/common -iwithprefixbefore protocomm/include/security -iwithprefixbefore protocomm/include/transports -iwithprefixbefore mdns/include -iwithprefixbefore esp_local_ctrl/include -iwithprefixbefore sdmmc/include -iwithprefixbefore esp_serial_slave_link/include -iwithprefixbefore esp_websocket_client/include -iwithprefixbefore expat/expat/expat/lib -iwithprefixbefore expat/port/include -iwithprefixbefore wear_levelling/include -iwithprefixbefore fatfs/diskio -iwithprefixbefore fatfs/vfs -iwithprefixbefore fatfs/src -iwithprefixbefore freemodbus/freemodbus/common/include -iwithprefixbefore idf_test/include -iwithprefixbefore idf_test/include/esp32s3 -iwithprefixbefore jsmn/include -iwithprefixbefore json/cJSON -iwithprefixbefore libsodium/libsodium/src/libsodium/include -iwithprefixbefore libsodium/port_include -iwithprefixbefore mqtt/esp-mqtt/include -iwithprefixbefore openssl/include -iwithprefixbefore perfmon/include -iwithprefixbefore spiffs/include -iwithprefixbefore usb/include -iwithprefixbefore ulp/include -iwithprefixbefore wifi_provisioning/include -iwithprefixbefore rmaker_common/include -iwithprefixbefore esp_diagnostics/include -iwithprefixbefore rtc_store/include -iwithprefixbefore esp_insights/include -iwithprefixbefore json_parser/upstream/include -iwithprefixbefore json_parser/upstream -iwithprefixbefore json_generator/upstream -iwithprefixbefore esp_schedule/include -iwithprefixbefore espressif__esp_secure_cert_mgr/include -iwithprefixbefore esp_rainmaker/include -iwithprefixbefore gpio_button/button/include -iwithprefixbefore qrcode/include -iwithprefixbefore ws2812_led -iwithprefixbefore freertos/include/freertos -iwithprefixbefore arduino_tinyusb/tinyusb/src -iwithprefixbefore arduino_tinyusb/include -iwithprefixbefore esp_littlefs/include -iwithprefixbefore esp-dl/include -iwithprefixbefore esp-dl/include/tool -iwithprefixbefore esp-dl/include/typedef -iwithprefixbefore esp-dl/include/image -iwithprefixbefore esp-dl/include/math -iwithprefixbefore esp-dl/include/nn -iwithprefixbefore esp-dl/include/layer -iwithprefixbefore esp-dl/include/detect -iwithprefixbefore esp-dl/include/model_zoo -iwithprefixbefore esp32-camera/driver/include -iwithprefixbefore esp32-camera/conversions/include -iwithprefixbefore espressif__esp-dsp/modules/dotprod/include -iwithprefixbefore espressif__esp-dsp/modules/support/include -iwithprefixbefore espressif__esp-dsp/modules/support/mem/include -iwithprefixbefore espressif__esp-dsp/modules/windows/include -iwithprefixbefore espressif__esp-dsp/modules/windows/hann/include -iwithprefixbefore espressif__esp-dsp/modules/windows/blackman/include -iwithprefixbefore espressif__esp-dsp/modules/windows/blackman_harris/include -iwithprefixbefore espressif__esp-dsp/modules/windows/blackman_nuttall/include -iwithprefixbefore espressif__esp-dsp/modules/windows/nuttall/include -iwithprefixbefore espressif__esp-dsp/modules/windows/flat_top/include -iwithprefixbefore espressif__esp-dsp/modules/iir/include -iwithprefixbefore espressif__esp-dsp/modules/fir/include -iwithprefixbefore espressif__esp-dsp/modules/math/include -iwithprefixbefore espressif__esp-dsp/modules/math/add/include -iwithprefixbefore espressif__esp-dsp/modules/math/sub/include -iwithprefixbefore espressif__esp-dsp/modules/math/mul/include -iwithprefixbefore espressif__esp-dsp/modules/math/addc/include -iwithprefixbefore espressif__esp-dsp/modules/math/mulc/include -iwithprefixbefore espressif__esp-dsp/modules/math/sqrt/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/mul/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/add/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/addc/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/mulc/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/sub/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/include -iwithprefixbefore espressif__esp-dsp/modules/fft/include -iwithprefixbefore espressif__esp-dsp/modules/dct/include -iwithprefixbefore espressif__esp-dsp/modules/conv/include -iwithprefixbefore espressif__esp-dsp/modules/common/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/mul/test/include -iwithprefixbefore espressif__esp-dsp/modules/kalman/ekf/include -iwithprefixbefore espressif__esp-dsp/modules/kalman/ekf_imu13states/include -iwithprefixbefore fb_gfx/include -IC:\Users\Levi\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.18-arduino.5/tools/sdk/esp32s3/qio_opi/include -mlongcalls -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -c -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_NANO_ESP32 -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="NANO_ESP32" -DARDUINO_VARIANT="arduino_nano_nora" -DARDUINO_PARTITION_app3M_fat9M_fact512k_16MB -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DBOARD_HAS_PIN_REMAP -DBOARD_HAS_PSRAM -DUSB_MANUFACTURER="Arduino" -DUSB_PRODUCT="Nano ESP32" -DARDUINO_USB_MODE=0 -DARDUINO_USB_CDC_ON_BOOT=1 -DARDUINO_USB_MSC_ON_BOOT=0 -DARDUINO_USB_DFU_ON_BOOT=1 @C:\Users\Levi\AppData\Local\arduino\sketches\A366996E717B2298F7665A339C5822A2/build_opt.h @C:\Users\Levi\AppData\Local\arduino\sketches\A366996E717B2298F7665A339C5822A2/file_opts -IC:\Users\Levi\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.18-arduino.5\cores\esp32 -IC:\Users\Levi\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.18-arduino.5\variants\arduino_nano_nora C:\Users\Levi\AppData\Local\arduino\sketches\A366996E717B2298F7665A339C5822A2\sketch\sketch_dec28a.ino.cpp -o C:\Users\Levi\AppData\Local\Temp\3533425778\sketch_merged.cpp
C:\Users\Levi\AppData\Local\Arduino15\packages\builtin\tools\ctags\5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives C:\Users\Levi\AppData\Local\Temp\3533425778\sketch_merged.cpp
Compiling sketch...
"C:\\Users\\Levi\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\s3-gcc\\2021r2-p5/bin/xtensa-esp32s3-elf-g++" -DHAVE_CONFIG_H "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE "-DIDF_VER=\"v4.4.7-dirty\"" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS -iprefix "C:\\Users\\Levi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.18-arduino.5/tools/sdk/esp32s3/include/" -iwithprefixbefore newlib/platform_include -iwithprefixbefore freertos/include -iwithprefixbefore freertos/include/esp_additions/freertos -iwithprefixbefore freertos/port/xtensa/include -iwithprefixbefore freertos/include/esp_additions -iwithprefixbefore esp_hw_support/include -iwithprefixbefore esp_hw_support/include/soc -iwithprefixbefore esp_hw_support/include/soc/esp32s3 -iwithprefixbefore esp_hw_support/port/esp32s3 -iwithprefixbefore esp_hw_support/port/esp32s3/private_include -iwithprefixbefore heap/include -iwithprefixbefore log/include -iwithprefixbefore lwip/include/apps -iwithprefixbefore lwip/include/apps/sntp -iwithprefixbefore lwip/lwip/src/include -iwithprefixbefore lwip/port/esp32/include -iwithprefixbefore lwip/port/esp32/include/arch -iwithprefixbefore soc/include -iwithprefixbefore soc/esp32s3 -iwithprefixbefore soc/esp32s3/include -iwithprefixbefore hal/esp32s3/include -iwithprefixbefore hal/include -iwithprefixbefore hal/platform_port/include -iwithprefixbefore esp_rom/include -iwithprefixbefore esp_rom/include/esp32s3 -iwithprefixbefore esp_rom/esp32s3 -iwithprefixbefore esp_common/include -iwithprefixbefore esp_system/include -iwithprefixbefore esp_system/port/soc -iwithprefixbefore esp_system/port/public_compat -iwithprefixbefore xtensa/include -iwithprefixbefore xtensa/esp32s3/include -iwithprefixbefore driver/include -iwithprefixbefore driver/esp32s3/include -iwithprefixbefore esp_pm/include -iwithprefixbefore esp_ringbuf/include -iwithprefixbefore efuse/include -iwithprefixbefore efuse/esp32s3/include -iwithprefixbefore vfs/include -iwithprefixbefore esp_wifi/include -iwithprefixbefore esp_event/include -iwithprefixbefore esp_netif/include -iwithprefixbefore esp_eth/include -iwithprefixbefore tcpip_adapter/include -iwithprefixbefore esp_phy/include -iwithprefixbefore esp_phy/esp32s3/include -iwithprefixbefore esp_ipc/include -iwithprefixbefore app_trace/include -iwithprefixbefore esp_timer/include -iwithprefixbefore mbedtls/port/include -iwithprefixbefore mbedtls/mbedtls/include -iwithprefixbefore mbedtls/esp_crt_bundle/include -iwithprefixbefore app_update/include -iwithprefixbefore spi_flash/include -iwithprefixbefore bootloader_support/include -iwithprefixbefore nvs_flash/include -iwithprefixbefore pthread/include -iwithprefixbefore esp_gdbstub/include -iwithprefixbefore esp_gdbstub/xtensa -iwithprefixbefore esp_gdbstub/esp32s3 -iwithprefixbefore espcoredump/include -iwithprefixbefore espcoredump/include/port/xtensa -iwithprefixbefore wpa_supplicant/include -iwithprefixbefore wpa_supplicant/port/include -iwithprefixbefore wpa_supplicant/esp_supplicant/include -iwithprefixbefore ieee802154/include -iwithprefixbefore console -iwithprefixbefore asio/asio/asio/include -iwithprefixbefore asio/port/include -iwithprefixbefore bt/common/osi/include -iwithprefixbefore bt/include/esp32c3/include -iwithprefixbefore bt/common/api/include/api -iwithprefixbefore bt/common/btc/profile/esp/blufi/include -iwithprefixbefore bt/common/btc/profile/esp/include -iwithprefixbefore bt/host/bluedroid/api/include/api -iwithprefixbefore bt/esp_ble_mesh/mesh_common/include -iwithprefixbefore bt/esp_ble_mesh/mesh_common/tinycrypt/include -iwithprefixbefore bt/esp_ble_mesh/mesh_core -iwithprefixbefore bt/esp_ble_mesh/mesh_core/include -iwithprefixbefore bt/esp_ble_mesh/mesh_core/storage -iwithprefixbefore bt/esp_ble_mesh/btc/include -iwithprefixbefore bt/esp_ble_mesh/mesh_models/common/include -iwithprefixbefore bt/esp_ble_mesh/mesh_models/client/include -iwithprefixbefore bt/esp_ble_mesh/mesh_models/server/include -iwithprefixbefore bt/esp_ble_mesh/api/core/include -iwithprefixbefore bt/esp_ble_mesh/api/models/include -iwithprefixbefore bt/esp_ble_mesh/api -iwithprefixbefore cbor/port/include -iwithprefixbefore unity/include -iwithprefixbefore unity/unity/src -iwithprefixbefore cmock/CMock/src -iwithprefixbefore coap/port/include -iwithprefixbefore coap/libcoap/include -iwithprefixbefore nghttp/port/include -iwithprefixbefore nghttp/nghttp2/lib/includes -iwithprefixbefore esp-tls -iwithprefixbefore esp-tls/esp-tls-crypto -iwithprefixbefore esp_adc_cal/include -iwithprefixbefore esp_hid/include -iwithprefixbefore tcp_transport/include -iwithprefixbefore esp_http_client/include -iwithprefixbefore esp_http_server/include -iwithprefixbefore esp_https_ota/include -iwithprefixbefore esp_https_server/include -iwithprefixbefore esp_lcd/include -iwithprefixbefore esp_lcd/interface -iwithprefixbefore protobuf-c/protobuf-c -iwithprefixbefore protocomm/include/common -iwithprefixbefore protocomm/include/security -iwithprefixbefore protocomm/include/transports -iwithprefixbefore mdns/include -iwithprefixbefore esp_local_ctrl/include -iwithprefixbefore sdmmc/include -iwithprefixbefore esp_serial_slave_link/include -iwithprefixbefore esp_websocket_client/include -iwithprefixbefore expat/expat/expat/lib -iwithprefixbefore expat/port/include -iwithprefixbefore wear_levelling/include -iwithprefixbefore fatfs/diskio -iwithprefixbefore fatfs/vfs -iwithprefixbefore fatfs/src -iwithprefixbefore freemodbus/freemodbus/common/include -iwithprefixbefore idf_test/include -iwithprefixbefore idf_test/include/esp32s3 -iwithprefixbefore jsmn/include -iwithprefixbefore json/cJSON -iwithprefixbefore libsodium/libsodium/src/libsodium/include -iwithprefixbefore libsodium/port_include -iwithprefixbefore mqtt/esp-mqtt/include -iwithprefixbefore openssl/include -iwithprefixbefore perfmon/include -iwithprefixbefore spiffs/include -iwithprefixbefore usb/include -iwithprefixbefore ulp/include -iwithprefixbefore wifi_provisioning/include -iwithprefixbefore rmaker_common/include -iwithprefixbefore esp_diagnostics/include -iwithprefixbefore rtc_store/include -iwithprefixbefore esp_insights/include -iwithprefixbefore json_parser/upstream/include -iwithprefixbefore json_parser/upstream -iwithprefixbefore json_generator/upstream -iwithprefixbefore esp_schedule/include -iwithprefixbefore espressif__esp_secure_cert_mgr/include -iwithprefixbefore esp_rainmaker/include -iwithprefixbefore gpio_button/button/include -iwithprefixbefore qrcode/include -iwithprefixbefore ws2812_led -iwithprefixbefore freertos/include/freertos -iwithprefixbefore arduino_tinyusb/tinyusb/src -iwithprefixbefore arduino_tinyusb/include -iwithprefixbefore esp_littlefs/include -iwithprefixbefore esp-dl/include -iwithprefixbefore esp-dl/include/tool -iwithprefixbefore esp-dl/include/typedef -iwithprefixbefore esp-dl/include/image -iwithprefixbefore esp-dl/include/math -iwithprefixbefore esp-dl/include/nn -iwithprefixbefore esp-dl/include/layer -iwithprefixbefore esp-dl/include/detect -iwithprefixbefore esp-dl/include/model_zoo -iwithprefixbefore esp32-camera/driver/include -iwithprefixbefore esp32-camera/conversions/include -iwithprefixbefore espressif__esp-dsp/modules/dotprod/include -iwithprefixbefore espressif__esp-dsp/modules/support/include -iwithprefixbefore espressif__esp-dsp/modules/support/mem/include -iwithprefixbefore espressif__esp-dsp/modules/windows/include -iwithprefixbefore espressif__esp-dsp/modules/windows/hann/include -iwithprefixbefore espressif__esp-dsp/modules/windows/blackman/include -iwithprefixbefore espressif__esp-dsp/modules/windows/blackman_harris/include -iwithprefixbefore espressif__esp-dsp/modules/windows/blackman_nuttall/include -iwithprefixbefore espressif__esp-dsp/modules/windows/nuttall/include -iwithprefixbefore espressif__esp-dsp/modules/windows/flat_top/include -iwithprefixbefore espressif__esp-dsp/modules/iir/include -iwithprefixbefore espressif__esp-dsp/modules/fir/include -iwithprefixbefore espressif__esp-dsp/modules/math/include -iwithprefixbefore espressif__esp-dsp/modules/math/add/include -iwithprefixbefore espressif__esp-dsp/modules/math/sub/include -iwithprefixbefore espressif__esp-dsp/modules/math/mul/include -iwithprefixbefore espressif__esp-dsp/modules/math/addc/include -iwithprefixbefore espressif__esp-dsp/modules/math/mulc/include -iwithprefixbefore espressif__esp-dsp/modules/math/sqrt/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/mul/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/add/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/addc/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/mulc/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/sub/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/include -iwithprefixbefore espressif__esp-dsp/modules/fft/include -iwithprefixbefore espressif__esp-dsp/modules/dct/include -iwithprefixbefore espressif__esp-dsp/modules/conv/include -iwithprefixbefore espressif__esp-dsp/modules/common/include -iwithprefixbefore espressif__esp-dsp/modules/matrix/mul/test/include -iwithprefixbefore espressif__esp-dsp/modules/kalman/ekf/include -iwithprefixbefore espressif__esp-dsp/modules/kalman/ekf_imu13states/include -iwithprefixbefore fb_gfx/include "-IC:\\Users\\Levi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.18-arduino.5/tools/sdk/esp32s3/qio_opi/include" -mlongcalls -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -MMD -c -Os -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_NANO_ESP32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"NANO_ESP32\"" "-DARDUINO_VARIANT=\"arduino_nano_nora\"" -DARDUINO_PARTITION_app3M_fat9M_fact512k_16MB -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DBOARD_HAS_PIN_REMAP -DBOARD_HAS_PSRAM "-DUSB_MANUFACTURER=\"Arduino\"" "-DUSB_PRODUCT=\"Nano ESP32\"" -DARDUINO_USB_MODE=0 -DARDUINO_USB_CDC_ON_BOOT=1 -DARDUINO_USB_MSC_ON_BOOT=0 -DARDUINO_USB_DFU_ON_BOOT=1 "@C:\\Users\\Levi\\AppData\\Local\\arduino\\sketches\\A366996E717B2298F7665A339C5822A2/build_opt.h" "@C:\\Users\\Levi\\AppData\\Local\\arduino\\sketches\\A366996E717B2298F7665A339C5822A2/file_opts" "-IC:\\Users\\Levi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.18-arduino.5\\cores\\esp32" "-IC:\\Users\\Levi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.18-arduino.5\\variants\\arduino_nano_nora" "C:\\Users\\Levi\\AppData\\Local\\arduino\\sketches\\A366996E717B2298F7665A339C5822A2\\sketch\\sketch_dec28a.ino.cpp" -o "C:\\Users\\Levi\\AppData\\Local\\arduino\\sketches\\A366996E717B2298F7665A339C5822A2\\sketch\\sketch_dec28a.ino.cpp.o"
Compiling libraries...
Compiling core...
cmd /c echo -DARDUINO_CORE_BUILD > "C:\\Users\\Levi\\AppData\\Local\\arduino\\sketches\\A366996E717B2298F7665A339C5822A2/file_opts"
Using previously compiled file: C:\Users\Levi\AppData\Local\arduino\sketches\A366996E717B2298F7665A339C5822A2\core\double_tap.c.o
Using previously compiled file: C:\Users\Levi\AppData\Local\arduino\sketches\A366996E717B2298F7665A339C5822A2\core\io_pin_remap.cpp.o
Using previously compiled file: C:\Users\Levi\AppData\Local\arduino\sketches\A366996E717B2298F7665A339C5822A2\core\variant.cpp.o
Using previously compiled file: C:\Users\Levi\AppData\Local\arduino\sketches\A366996E717B2298F7665A339C5822A2\core\dfu_callbacks.cpp.o
Using precompiled core: C:\Users\Levi\AppData\Local\arduino\cores\220274f9f5a44395a2bbd7c0fef2d62c\core.a
Linking everything together...
"C:\\Users\\Levi\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\s3-gcc\\2021r2-p5/bin/xtensa-esp32s3-elf-g++" "-Wl,--Map=C:\\Users\\Levi\\AppData\\Local\\arduino\\sketches\\A366996E717B2298F7665A339C5822A2/sketch_dec28a.ino.map" "-LC:\\Users\\Levi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.18-arduino.5/tools/sdk/esp32s3/lib" "-LC:\\Users\\Levi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.18-arduino.5/tools/sdk/esp32s3/ld" "-LC:\\Users\\Levi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.18-arduino.5/tools/sdk/esp32s3/qio_opi" -T memory.ld -T sections.ld -T esp32s3.rom.ld -T esp32s3.rom.api.ld -T esp32s3.rom.libgcc.ld -T esp32s3.rom.newlib.ld -T esp32s3.rom.version.ld -T esp32s3.rom.newlib-time.ld -T esp32s3.peripherals.ld -mlongcalls -Wl,--cref -Wl,--gc-sections -fno-rtti -fno-lto -Wl,--wrap=esp_log_write -Wl,--wrap=esp_log_writev -Wl,--wrap=log_printf -u _Z5setupv -u _Z4loopv -u esp_app_desc -u pthread_include_pthread_impl -u pthread_include_pthread_cond_var_impl -u pthread_include_pthread_local_storage_impl -u pthread_include_pthread_rwlock_impl -u include_esp_phy_override -u ld_include_highint_hdl -u start_app -u start_app_other_cores -u __ubsan_include -Wl,--wrap=longjmp -u __assert_func -u vfs_include_syscalls_impl -Wl,--undefined=uxTopUsedPriority -u app_main -u newlib_include_heap_impl -u newlib_include_syscalls_impl -u newlib_include_pthread_impl -u newlib_include_assert_impl -u __cxa_guard_dummy -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DBOARD_HAS_PIN_REMAP -DBOARD_HAS_PSRAM "-DUSB_MANUFACTURER=\"Arduino\"" "-DUSB_PRODUCT=\"Nano ESP32\"" -DARDUINO_USB_MODE=0 -DARDUINO_USB_CDC_ON_BOOT=1 -DARDUINO_USB_MSC_ON_BOOT=0 -DARDUINO_USB_DFU_ON_BOOT=1 -Wl,--start-group "C:\\Users\\Levi\\AppData\\Local\\arduino\\sketches\\A366996E717B2298F7665A339C5822A2\\sketch\\sketch_dec28a.ino.cpp.o" "C:\\Users\\Levi\\AppData\\Local\\arduino\\sketches\\A366996E717B2298F7665A339C5822A2\\core\\dfu_callbacks.cpp.o" "C:\\Users\\Levi\\AppData\\Local\\arduino\\sketches\\A366996E717B2298F7665A339C5822A2\\core\\double_tap.c.o" "C:\\Users\\Levi\\AppData\\Local\\arduino\\sketches\\A366996E717B2298F7665A339C5822A2\\core\\io_pin_remap.cpp.o" "C:\\Users\\Levi\\AppData\\Local\\arduino\\sketches\\A366996E717B2298F7665A339C5822A2\\core\\variant.cpp.o" "C:\\Users\\Levi\\AppData\\Local\\arduino\\cores\\220274f9f5a44395a2bbd7c0fef2d62c\\core.a" -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lasio -lbt -lcbor -lunity -lcmock -lcoap -lnghttp -lesp-tls -lesp_adc_cal -lesp_hid -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lesp_https_server -lesp_lcd -lprotobuf-c -lprotocomm -lmdns -lesp_local_ctrl -lsdmmc -lesp_serial_slave_link -lesp_websocket_client -lexpat -lwear_levelling -lfatfs -lfreemodbus -ljsmn -ljson -llibsodium -lmqtt -lopenssl -lperfmon -lspiffs -lusb -lulp -lwifi_provisioning -lrmaker_common -lesp_diagnostics -lrtc_store -lesp_insights -ljson_parser -ljson_generator -lesp_schedule -lespressif__esp_secure_cert_mgr -lesp_rainmaker -lgpio_button -lqrcode -lws2812_led -lesp32-camera -lesp_littlefs -lespressif__esp-dsp -lfb_gfx -lasio -lcmock -lunity -lcoap -lesp_lcd -lesp_websocket_client -lexpat -lfreemodbus -ljsmn -llibsodium -lperfmon -lusb -lesp_adc_cal -lesp_hid -lfatfs -lwear_levelling -lopenssl -lspiffs -lesp_insights -lcbor -lesp_diagnostics -lrtc_store -lesp_rainmaker -lesp_local_ctrl -lesp_https_server -lwifi_provisioning -lprotocomm -lbt -lbtdm_app -lprotobuf-c -lmdns -ljson -ljson_parser -ljson_generator -lesp_schedule -lespressif__esp_secure_cert_mgr -lqrcode -lrmaker_common -lmqtt -larduino_tinyusb -lcat_face_detect -lhuman_face_detect -lcolor_detect -lmfn -ldl -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls_2 -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls_2 -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls_2 -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls_2 -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls_2 -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls_2 -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lphy -lbtbb -lesp_phy -lphy -lbtbb -lesp_phy -lphy -lbtbb -lxt_hal -lc -lm -lnewlib -lstdc++ -lpthread -lgcc -lcxx -Wl,--end-group -Wl,-EL -o "C:\\Users\\Levi\\AppData\\Local\\arduino\\sketches\\A366996E717B2298F7665A339C5822A2/sketch_dec28a.ino.elf"
"C:\\Users\\Levi\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esptool_py\\4.5.1/esptool.exe" --chip esp32s3 elf2image --flash_mode dio --flash_freq 80m --flash_size 16MB --elf-sha256-offset 0xb0 -o "C:\\Users\\Levi\\AppData\\Local\\arduino\\sketches\\A366996E717B2298F7665A339C5822A2/sketch_dec28a.ino.bin" "C:\\Users\\Levi\\AppData\\Local\\arduino\\sketches\\A366996E717B2298F7665A339C5822A2/sketch_dec28a.ino.elf"
esptool.py v4.5.1
Merged 2 ELF sections
"C:\\Users\\Levi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.18-arduino.5\\tools\\gen_esp32part.exe" -q "C:\\Users\\Levi\\AppData\\Local\\arduino\\sketches\\A366996E717B2298F7665A339C5822A2/partitions.csv" "C:\\Users\\Levi\\AppData\\Local\\arduino\\sketches\\A366996E717B2298F7665A339C5822A2/sketch_dec28a.ino.partitions.bin"
cmd /c if exist "C:\\Users\\Levi\\AppData\\Local\\arduino\\sketches\\A366996E717B2298F7665A339C5822A2\\libraries\\Insights" "C:\\Users\\Levi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.18-arduino.5\\tools\\gen_insights_package.exe" "C:\\Users\\Levi\\AppData\\Local\\arduino\\sketches\\A366996E717B2298F7665A339C5822A2" sketch_dec28a.ino "C:\\Users\\Levi\\AppData\\Local\\Temp\\.arduinoIDE-unsaved20251128-916-j2c6mt.ii6k\\sketch_dec28a"
"C:\\Users\\Levi\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\s3-gcc\\2021r2-p5/bin/xtensa-esp32s3-elf-size" -A "C:\\Users\\Levi\\AppData\\Local\\arduino\\sketches\\A366996E717B2298F7665A339C5822A2/sketch_dec28a.ino.elf"
Sketch uses 286029 bytes (9%) of program storage space. Maximum is 3145728 bytes.
Global variables use 30552 bytes (9%) of dynamic memory, leaving 297128 bytes for local variables. Maximum is 327680 bytes.
"C:\Users\Levi\AppData\Local\Arduino15\packages\arduino\tools\dfu-util\0.11.0-arduino5/dfu-util" --device 0x2341:0x0070 -D "C:\Users\Levi\AppData\Local\arduino\sketches\A366996E717B2298F7665A339C5822A2/sketch_dec28a.ino.bin" -Q
No DFU capable USB device available
dfu-util 0.11-arduino4
Copyright 2005-2009 Weston Schmidt, Harald Welte and OpenMoko Inc.
Copyright 2010-2021 Tormod Volden and Stefan Schmidt
This program is Free Software and has ABSOLUTELY NO WARRANTY
Please report bugs to http://sourceforge.net/p/dfu-util/tickets/
Failed uploading: uploading error: exit status 74
Hi @levijg. I'm going to ask you to provide some additional information that might help us to identify the problem:
  1. Connect the Nano ESP32 board to your computer with the USB cable.
  2. Open Arduino IDE's Tools > Port menu.
Please add a reply here on this forum topic to tell us what label (if any) you see after the item for the board's port in the menu.
It might be labeled as one of the following things:
  • "(Arduino Nano ESP32)"
  • "(ESP32 Family Device)"
  • A random ESP32-based board (e.g., "(DFRobot Beetle ESP32-C3)", "(ESP32-S3-Box)", "(ESP32C3 Dev Module)", "(LOLIN S3)", "(WiFiduino32S3)", etc.)
Or you might see only the port name (e.g., "COM42", "/dev/cu.usbmodem211410", "/dev/ttyACM0") in the menu, without any label after it.
I finally got it figured out. I had to select Sketch > Upload Using Programmer.
A lot of headache for a simple solution :slightly_smiling_face:. For anyone else who needs it, the procedure to reset and upload to the board is here: https://support.arduino.cc/hc/en-us/articles/9810414060188-Reset-the-Arduino-bootloader-on-the-Nano-ESP32
Thanks for the help!
