Arduino Nano Every Error: cannot convert 'boolean {aka bool}' to 'PinStatus'
hi i am very new to Arduino and I started piecing this code together with an Arduino Uno as my quick tester so I can quickly connect everything and see if its working. I wanted to upload the exact same code to my Arduino Nano Every but it gives me an error. Im using a Motor Driver maybe that's the problem?
#include <Servo.h>
int buttonStart = 0;
int buttonMiddle = 0;
int buttonEnd = 0;
// Setup pins
int standBy = 10;
// Motor A
int PWMA = 3;   // PWM Speed Control
int AIN1 = 9;   // Direction pin 1
int AIN2 = 8;   // Direction pin 2
// Motor B
int PWMB = 5;   // PWM Speed Control
int BIN1 = 11;  // Direction pin 1
int BIN2 = 12;  // Direction pin 2
Servo servo_13;
  pinMode(2, INPUT);
  pinMode(1, INPUT);
  pinMode(4, INPUT);
  servo_13.attach(13, 500, 2500);
  pinMode(7, OUTPUT);
  pinMode(6, OUTPUT);
  // Setup Pins as OUTPUT
  pinMode(standBy, OUTPUT);
  // Motor A
  pinMode(PWMA, OUTPUT);
  pinMode(AIN1, OUTPUT);
  pinMode(AIN2, OUTPUT);
  // Motor B
  pinMode(PWMB, OUTPUT);
  pinMode(BIN1, OUTPUT);
  pinMode(BIN2, OUTPUT);
  Serial.begin(19200);
  Serial.println("I Did it");
  buttonStart = digitalRead(2);
  buttonMiddle = digitalRead(1);
  buttonEnd = digitalRead(4);
  servo_13.write(0);
  if (buttonStart == HIGH) {
    servo_13.write(90);
    delay(5000);
    forward(128);   // Move forward
  if (buttonMiddle == HIGH) {
     delay(30000);
     reverse(255);   // Move in reverse
  if (buttonEnd == HIGH) {
  stop();
  servo_13.write(0);
 * Functions
void turnLeft(int spd)
  runMotor(0, spd, 0);
  runMotor(1, spd, 1);
void turnRight(int spd)
  runMotor(0, spd, 1);
  runMotor(1, spd, 0);
void forward(int spd)
void reverse(int spd)
void runMotor(int motor, int spd, int dir)
  digitalWrite(standBy, HIGH); // Turn on Motor
  boolean dirPin1 = LOW;
  boolean dirPin2 = HIGH;
  if(dir == 1) {
    dirPin1 = HIGH;
    dirPin2 = LOW;
  if(motor == 1) {
    digitalWrite(AIN1, dirPin1);
    digitalWrite(AIN2, dirPin2);
    analogWrite(PWMA, spd);
    digitalWrite(BIN1, dirPin1);
    digitalWrite(BIN2, dirPin2);
    analogWrite(PWMB, spd);
void stop() {
  digitalWrite(standBy, LOW);
the error message says: cannot convert 'boolean {aka bool}' to 'PinStatus' for argument '2' to 'void digitalWrite(pin_size_t, PinStatus)'
if you know what to to could you answer it in the most dumbed down way, I read a similar post with a similar problem but I didn't understand anything about it
Don't use boolean, it's a nonstandard type alias, use bool instead. However, in this case, also don't use bool for pin states, use PinStatus:
  PinStatus dirPin1 = LOW;
  PinStatus dirPin2 = HIGH;
Pieter
With the official core for the Nano Every, you can't pass booleans as the second argument to digitalWrite. They do this moronic thing with PinStatus enum for HIGH/LOW (and PinMode for the arguments to pinMode - which has the incredibly perverse effect of making PinMode(pin,value) valid code, rather than a syntax error. I spent like an hour searching for that before I found it with my own megaTinyCore, which was based on that official core. I then immediately dropped what I was doing and excised that abomination from my core so the digital I/O functions work like they do on an Uno there :stuck_out_tongue: ).
The unofficial MegaCoreX supports the ATmega4809 used on the Nano Every with "normal" digital I/O functions (as well as a bunch of other improvements); I think they have a pin mapping that matches the numbering on the Nano Every too. I use MCUdude's cores instead of the official ones for everything (either he or I maintain a core for all the AVR chips one might want to use with Arduino) MegaCoreX
DrAzzy:
thank u for the quick response I will look into MegaCoreX and get rid of that boolean stuff
There's a bug submitted for this:
It's had quite a bit of discussion.
PieterP:
Pieter
thank you I will try this as well ( can I just replace the two commands or do I have to change some other stuff)
PieterP:
Pieter
please help I replaced the bool stuff with this but it says its out of scope what do I do ?
Kilian03:
That's a different error. Please post your full code and the full error message.
PieterP:
#include <Servo.h>
int buttonEnd = 0;
// Setup pins
int standBy = 10;
// Motor A
// Motor B
Servo servo_13;
  pinMode(2, INPUT);
  pinMode(6, INPUT);
  pinMode(4, INPUT);
  // Motor A
  // Motor B
  buttonMiddle = digitalRead(6);
    servo_13.write(90);
    delay(5000);
     delay(30000);
  stop();
  servo_13.write(0);
 * Functions
  //boolean dirPin1 = LOW;
  //boolean dirPin2 = HIGH;
  if(dir == 1) {
    dirPin1 = HIGH;
    dirPin2 = LOW;
  if(motor == 1) {
void stop() {
error message:
[color=#da5b4a]/tmp/641214848/Schuh_Code/Schuh_Code.ino: In function 'void runMotor(int, int, int)':[/color]
[color=#da5b4a]/tmp/641214848/Schuh_Code/Schuh_Code.ino:98:3: error: 'PinStatus' was not declared in this scope[/color]
[color=#da5b4a]PinStatus dirPin1 = LOW;[/color]
[color=#da5b4a]^~~~~~~~~[/color]
[color=#da5b4a]/tmp/641214848/Schuh_Code/Schuh_Code.ino:99:13: error: expected ';' before 'dirPin2'[/color]
[color=#da5b4a]PinStatus dirPin2 = HIGH;[/color]
[color=#da5b4a]^~~~~~~[/color]
[color=#da5b4a]/tmp/641214848/Schuh_Code/Schuh_Code.ino:102:5: error: 'dirPin1' was not declared in this scope[/color]
[color=#da5b4a]dirPin1 = HIGH;[/color]
[color=#da5b4a]/tmp/641214848/Schuh_Code/Schuh_Code.ino:103:5: error: 'dirPin2' was not declared in this scope[/color]
[color=#da5b4a]dirPin2 = LOW;[/color]
[color=#da5b4a]/tmp/641214848/Schuh_Code/Schuh_Code.ino:107:24: error: 'dirPin1' was not declared in this scope[/color]
[color=#da5b4a]digitalWrite(AIN1, dirPin1);[/color]
[color=#da5b4a]/tmp/641214848/Schuh_Code/Schuh_Code.ino:108:24: error: 'dirPin2' was not declared in this scope[/color]
[color=#da5b4a]digitalWrite(AIN2, dirPin2);[/color]
[color=#da5b4a]/tmp/641214848/Schuh_Code/Schuh_Code.ino:111:24: error: 'dirPin1' was not declared in this scope[/color]
[color=#da5b4a]digitalWrite(BIN1, dirPin1);[/color]
[color=#da5b4a]/tmp/641214848/Schuh_Code/Schuh_Code.ino:112:24: error: 'dirPin2' was not declared in this scope[/color]
[color=#da5b4a]digitalWrite(BIN2, dirPin2);[/color]
[color=#da5b4a]exit status 1[/color]
PieterP:
nevermind I just noticed I had the normal Arduino Nano selected, after changing that back to the nano Every it doesn't show an error anymore
