Hi all,
I'm developping a MQTT client based on arduino nano and ENC28J60 ethernet module (the goal is sending data to home assistant wit mqtt).
This is the code already used and working with an arduino mega and ENC28J60 ethernet module:
#include <PubSubClient.h>
#include <UIPEthernet.h>
#define DEBUG 1 // Debug output to serial console
#include "DHT.h"
#include <PZEM004T.h>
#define DHTPIN 8
#define DHTTYPE DHT11
DHT dht(DHTPIN, DHTTYPE);
PZEM004T pzem(2,3); // (RX,TX) connect to TX,RX of PZEM
IPAddress i(10,10,1,1);
int sensorPin = A0; // Pin to which the sensor is connected to
unsigned long mytime = 0;
byte mac[] = {0x80, 0x7D, 0x3A, 0x69, 0x20, 0xC8 }; //physical mac address
byte ip[] = {192, 168, 0, 15 }; // ip in lan
const char* mqtt_server = "192.168.0.9";
const char* mqttUser = "user";
const char* mqttPassword = "pass";
char buf[4]; // Buffer to store the sensor value
int updateInterval = 30000; // Interval in milliseconds
EthernetClient espClient;
PubSubClient client(espClient);
void reconnect() {
// Loop until we're reconnected
while (!client.connected()) {
Serial.print("Attempting MQTT connection...");
// Attempt to connect
if (client.connect("arduinoClientSuperior",mqttUser, mqttPassword)) {
Serial.println("connected");
Serial.print("failed, rc=");
Serial.print(client.state());
Serial.println(" try again in 5 seconds");
// Wait 5 seconds before retrying
delay(5000);
void sensors() {
int sensorValue = analogRead(sensorPin);
float h = dht.readHumidity();
float t = dht.readTemperature();
client.publish("home-assistant/sensor01/brightness", itoa(sensorValue, buf, 10));
client.publish("home-assistant/sensor02/temperature", String(t).c_str(), true);
client.publish("home-assistant/sensor02/humidity", String(h).c_str(), true);
float e = pzem.energy(i); //energia
float p = pzem.power(i); //potenza
float c = pzem.current(i); //energia
float v = pzem.voltage(i); //potenza
client.publish("home-assistant/sensor03/voltage", String(v).c_str(), true);
client.publish("home-assistant/sensor03/energy", String(e).c_str(), true);
client.publish("home-assistant/sensor03/power", String(p).c_str(), true);
client.publish("home-assistant/sensor03/current", String(c).c_str(), true);
#if DEBUG
Serial.print("Sensor value: ");
Serial.println(sensorValue);
Serial.print("HuM value value: ");
Serial.println(h);
Serial.print("Temp value value: ");
Serial.println(t);
if(e >= 0.0){ Serial.print(e);Serial.print("Wh; "); }
if(p >= 0.0){ Serial.print(p);Serial.print("W; "); }
if(c >= 0.0){ Serial.print(c);Serial.print("A; "); }
if(v >= 0.0){ Serial.print(v);Serial.print("V; "); }
#endif
pzem.setAddress(i);
delay(100);
dht.begin();
Ethernet.begin(mac,ip);
client.setServer(mqtt_server, 1883);
if (!client.connected()) { reconnect(); }
client.loop();
if (millis()-mytime>updateInterval)
{ mytime=millis();
sensors();
The sketch uses 29514byte (96%) and the memory used is 90%, so I have "low memory available, stability problems may occur"
How could I solve, using onother library? Using another ethernet board?
Many thanks
