Arduino nano sense not connecting anymore
Hello everyone,
When I uploaded a new script to my nano sense I can't connect it anymore to my PC. It connects really quick and immediatly disconnects.
Does anyone know how to fix this?
BTW this is the small script I uploaded. I fear the arduino crashes because of the array or something.
int rotarySensorPin = D2;
int val = 0;
long unsigned int timer = 0;
String sensorValues[10000];
  pinMode(rotarySensorPin, INPUT);
  for (int i = 0; i <= 9999; i++)
    val = digitalRead(rotarySensorPin);
    timer = millis();
    sensorValues[i] = val + "," + timer;
    Serial.println(sensorValues[i]);
Please edit your post, select all code and click the </> button; next save your post.
I'm not familiar with the Nano Sense; maybe a double tap on the reset button will put it in bootloader mode?
Lastly, 10,000 String objects take 60,000 bytes to start with; adding text to one/each element will increase it.
Yes double tapping the reset button made the connection possible.
Thank you
You should see a solution checkbox under replies; you can tick the most useful reply so others that find this topic know that it has a solution.
