I have a (hopefully) quick question about my code. I am trying to use an Arduino Nano to control the movement of two servo motors (both Tower Pro SG90's) via 2 touch buttons. Basically, I need the servo to move from a specific angle to another in slow steps so long as the button is in the HIGH (closed/pressed) state and move back to the original position at roughly the same speed when in the LOW (open/released) state. The angles in the code below aren't the ones I need but are just for an initial test to see if it works, I'll sort the exact angles later.
When I go into the serial monitor, the Serial.print(...) commands don't actually print any value and the servos don't move at all whether the button is pressed or not. Buttons are connected between GND and D2/D3, the servos are connected to +5V, power GND and A0/A1. Are my pin numbers in the code correct? The servo is powered as when I turn it on I hear it stutter slightly. I also don't plan to keep it powered through the +5Vpin as I'm aware it can't deliver more than 40mA (servo needs a few 100mA when moving, with spikes of up to 1A, right?). When the code works and I put the circuit into the final product it will have its own 4.5V power supply directly from a 3xAA battery pack.
CODE!!:
#include <Servo.h>
Servo Servo1; // raise lips
Servo Servo2; // sniffing nose
const int Button1Pin = 2; // the number of the pushbutton pin
const int Button2Pin = 3;
const int Servo1Pin = 23; // the number of the LED pin
const int Servo2Pin = 24;
// variables will change:
int Button1State = 0;
int Button2State = 0;
int pos1 = 0;
int pos2 = 0;
Servo1.attach(Servo1Pin);
Servo2.attach(Servo2Pin);
Button1State = digitalRead(Button1Pin);
Button2State = digitalRead(Button2Pin);
if (Button1State == HIGH) {
for(pos1 = 0; pos1 <= 90; pos1 += 2)
Servo1.write(pos1);
Serial.print("Button 1 State = ");
Serial.print(Button1State);
delay(15);
else {
pos1 = 0;
Servo1.write(pos1);
if (Button2State == HIGH) {
for(pos2 = 0; pos2 <= 45; pos2 += 1)
Servo2.write(pos2);
Serial.print("Button 2 State = ");
Serial.println(Button2State);
delay(15);
else {
pos2 = 0;
Servo2.write(pos2);
Any help and tips/tricks are much appreciated as hopefully they will also help someone else
Basic two button servo increment test code from the past. Note that servos need an external power supply. Powering the servos from tha arduino will probably crash the arduino.
//zoomkat servo button sweep test 12-23-2013
// Powering a servo from the arduino usually *DOES NOT WORK*.
#include <Servo.h>
int button1 = 5; //button pin, connect to ground to move servo
int press1 = 0;
int button2 = 6; //button pin, connect to ground to move servo
int press2 = 0;
Servo servo1;
int pos = 90; // variable to store and set the servo position
pinMode(button1, INPUT);
pinMode(button2, INPUT);
servo1.attach(7);
servo1.write(pos); //starting position
digitalWrite(5, HIGH); //enable pullups to make pin high
digitalWrite(6, HIGH); //enable pullups to make pin high
Serial.println("servo button sweep test 12-23-2013");
press1 = digitalRead(button1);
if (press1 == LOW)
pos=(pos+1);
if(pos>180) pos=180; //limit upper value
Serial.println(pos); //for serial monitor debug
servo1.write(pos); // tell servo to go to position in variable 'pos'
delay(150); // waits 150ms to slow servo movement
press2 = digitalRead(button2);
if (press2 == LOW)
pos=(pos-1);
if(pos<0) pos=0; //limit lower value
Thanks everyone for your replies! Much appreciated
I'm going to try the pinMode suggestion as well as double check the pin numbers. Either I'm a bit stupid or the nano pin diagrams aren't very clear as to which number to use in the code to use a specific pin
If it works I'll reply with the working code for other people to use if needed.
Cheers!
Sooo, I have changed the pin numbers to the correct ones (D2 = 5, D3 = 6, A0 = 14, A1 = 15) and included the pinMode commands to turn the button pins to INPUTS and make them initially LOW (and turn HIGH when pressed). The servos are also now powered directly from a 9xAA battery pack that runs through a 5V regulator I soldered together with some capacitors. The servos now jitter but don't do anything when the button is pressed. Also, the button state (HIGH/LOW) doesn't get printed into the serial monitor (commands in the void loop if sections) so I'm wondering if there is a problem with my if statement.
// Control 2 servos with 1 button each to move between 2 positions as long as the button is presed
// Thanks to zoomkat for their code to adjust mine
#include <Servo.h>
const int Button1 = 5; // D2
const int Button2 = 6; // D3
const int Servo1Pin = 14; // A0
const int Servo2Pin = 15; // A1
int pos1 = 0;
int pos2 = 0;
Servo1.write(pos1);
Servo2.write(pos2);
pinMode(Button1, INPUT);
pinMode(Button2,INPUT);
digitalWrite(5, LOW);
digitalWrite(6, LOW);
Serial.println("2 Servos, 2 Buttons, 31.12.2015");
Button1State = digitalRead(Button1);
Button2State = digitalRead(Button2);
pos1 = (pos1+1);
if(pos1 > 90) pos1 = 90;
Serial.println(Button1State);
Servo1.write(pos1);
delay(15);
else {
pos1 = 0;
Servo1.write(pos1);
pos2 = pos2+1;
if(pos2 > 45) pos2 = 45;
Servo2.write(pos2);
delay(15);
else {
pos2 = 0;
Servo2.write(pos2);
}[CODE]
Desolator69:
Do the servos work with a simple sweep example?
To which pins are your buttons connected? It looks like your using the button assignments from zoomkat's code. Did you move the buttons?
You should test your setup with the example button code in the IDE. Based on your code I think you need a refresher on how to use buttons.
Sorry for the late update, haven't been able to work on this recently but I solved my problem!
The code above in post #9 works just fine, the problem was with my buttons, I hadn't wired them up correctly (just had it wired to GND and input pin >.< ).
Thanks so much for all the replies and help from everyone! I hope this code is useful to others too
