Arduino Nano V3 powered from 3.6V - is it possible ?
Hello !
I have question. Is it possible to power Arduino Nano from 3.6V ?? I looked on arduino schematic:
can I connect 3.6V from 3 x AAA after 5V voltage stabilizer ?? arduino will work ?? I don't need to use ft232rl to send data via USB.
Greetings !
Darek
More than likely it will work. The part is spec'ed to need ~3.8V for full 16MHz operation.
If you're not using the FT232, why not use a Promini instead then?
Can use the 3.3V/8MHz unit and save on battery power too.
