I'm an Arduino noob taking my first stumbling steps outside my SparkFun beginner's kit. I purchased an SFR02 distance sensor and think I'm having problems with physically connecting it properly.
Related to this: what's the proper way of connecting a board with "holes" like the SFR02 board? I'd like to avoid soldering since I'm prototyping, but still ensure good connections.
AWOL:
I solder pin headers to devices, then plug them into ribbon cable headers.
Thanks, problem now solved! I soldered the SRF02 board to a 4-way ribbon cable header, swapped the resistors to 6k, and voilĂ : distance meter is working.
AWOL:
I have easily 60cm of 10 way cable with four IDC headers at 10cm spacing.
Hmm not sure I get this bit, please elaborate. 10cm spacing?
I have a 60cm length of ribbon cable. There's an IDC connector at one end to plug into my processor board, and the other end of the cable has four IDCs at 10cm spacing. These are connected to my four SRF02s.
The pull ups are on the main board.
AWOL:
Ah, got it: you can connect multiple SRF02's serially. Thanks!
