Hi, my Arduino (UNO) is not working as it should, i can't upload codes, and i don't know if i actually fried it.
And yes, i am using the correct COM, Arduino device, programmer AVRISP mkII.
When i plug into my PC:
ON led is ok
built in LED is ok
Some steps i did:
Loop back test IS working properly
Tried to burn bootloader with another working arduino (failed)
When i try to upload something into my arduino:
RX led blinks 3 times, and continues to blink in a way larger period (about 10 seconds between blinks)
It takes forever to upload, but in the end, it just fails and show a error
(avrdude: stk500_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x52)
the "resp" code error it's not fixed, sometimes it shows another code error, but the same text.
TX led does'nt blink at all (idk if it should blink or not)
built in LED stay fixed
Reset button may shut down or decrease led intensity while pressed
I dont know if it should do that, but when a touch some conductive parts, the built in LED change intensity
So that's it is my arduino just broken, and cannot be fixed?
I don't know what the progammer do, i'm kinda a newbie but i write a code, select the right port and board, press the Arrow (upload button), and it should work, right?
I just mencioned the AVRISP MKII programmer because it was already there, i don't know what it changes when i upload, but i'll try to provide details
I connected 5V and GND in a trimpot, i did not mess with the connection with the trimpot, to be fair i dont even know if the arduino was already malfunctioning when i tried to connect to a trimpot.
I was doing the AnalogInput example, and observing in plotter serial yesterday, and it worked just fine, when i tried to do the same thing, well, it didnt worked
My guess is that i might fried my arduino putting it on top of my laptop, that i guess is a metal (not really sure) and messed with the arduino, but the arduino should still be working? (LED on, power on, loop back test ok) And that messed with the GND too? Since de LED brightness is easily messed while just touching the arduino
The LED brightness is just an artifact of pin 13 not initialized, because it's driven through an op amp. Then the op amp input floats and picks up junk.
Maybe you shorted 5V to ground with an incorrect trim pot circuit... the Arduino has LIVE conductors on the back, if it's placed on a metal surface those can easily be short circuited. So the laptop theory holds some credence.
