I’m trying to read voltage data from a Selec EM4M energy meter using Arduino Opta (as Modbus RTU master) via RS485, but I’m not getting any valid response.
Here’s the sketch I’m using:
#include <ArduinoRS485.h>
#include <ArduinoModbus.h>
const uint8_t SLAVE_ID = 1;
const uint16_t VOLTAGE_ADDR = 30000;
const uint8_t NUM_REGS = 2;
while (!Serial);
if (!ModbusRTUClient.begin(9600, SERIAL_8N1)) {
Serial.println("Failed to start Modbus RTU client!");
while (1);
if (!ModbusRTUClient.requestFrom(SLAVE_ID, HOLDING_REGISTERS, VOLTAGE_ADDR, NUM_REGS)) {
Serial.print("Error: "); Serial.println(ModbusRTUClient.lastError());
uint16_t hi = ModbusRTUClient.read();
uint16_t lo = ModbusRTUClient.read();
uint32_t raw = ((uint32_t)hi << 16) | lo;
float val; memcpy(&val, &raw, sizeof(val));
Serial.println(val);
delay(2000);
Connections:
Opta A(-) → EM4M B(D−)
Opta B(+v) → EM4M A(D+)
Baud rate: 9600, ID: 1, Parity: None
I’ve double-checked wiring and settings, but still getting “response not from requested slave” or “timeout”.
Thank you for your suggestion, Kmin.
As you mentioned, I think there might be other issues as well. I still could not establish Modbus communication between the Opta and the EM4M.
I found the issue — adding the following line solved the communication problem:
RS485.setDelays(1000, 1000);
Now, the Opta is successfully communicating with the EM4M energy meter.
Working setup:
Serial.println("Failed to start Modbus RTU Client!");
while (1);
Connections:
Opta A (-) → EM4M (+)
Opta B (+) → EM4M (-)
The communication is now stable and working perfectly in Arduino IDE.
However, I’m currently facing an issue implementing the same logic in PLC IDE — I’m unable to read the sensor data from the EM4M via RS485 in that environment.
The same setup works perfectly in the Arduino IDE, but in PLC IDE no data is being received .
I would really appreciate your guidance on what configuration or logic might be missing.
I have never used PLC IDE.
But you should stop using addressing like that. 30000 is first input register, either 0x0000 in hex or 1 in decimal.
So replace 30000 with 1 and 30001 with 2.
