Hello together , I am working on a Oled Menu using the Adafruit_SSD1306.h and OneButton library. The idea is to navigating and changing values true the Menu using only 3 buttons. Each button as several function like normal Click, double Click, long Click etc. With the One Click Select Button i can navigate true the Menu forward. With the Double Click Select Button i go to a Variable Pages where i can change several values with the Plus and Minus Button. To go back from the Variable Pages to the Menu Pages again using the Double Click Select Button. All this what i have explained until now is working. The problem that i have is the folowing. When i am in the last Page of the Main Menu, pressing the Minus Button it brings me to a Sub Menu. Here i have also three pages where i can navigate forward with the One Click Select Button. Reaching the last Page of the Sub Menu clicking again on Minus Button it would bring me back to the Main Menu. Exactly on this last step my Microcontroller Reboots by himself all the time.
I am using a variable byte PageSwitch = 0; to controll where i am inside the Menu. For sure at some point inside the code i am not using this variable correctly and this brings the Microcontroller to Reboot.
Follows my Code
#include <EEPROM.h>
#include <OneButton.h>
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH 128
#define SCREEN_HEIGHT 64
#define display_RESET -1
const char*Vartext[] {"Text_0", "Text_1", "Text_2",
"Text_3", "Text_4"
const byte maxAnz = sizeof(Vartext) / sizeof(Vartext[0]);
const int mindata[maxAnz] {0, 0, 0, 0, 0};
const int maxdata[maxAnz] {10000, 200, 300, 500, 1000};
uint32_t longstart;
byte Varindex;
byte Page = 0;
byte Page2 = 0;
bool input;
bool changed;
bool changed2;
bool datachanged ;
struct mydaten {
int VarData[maxAnz];
} daten;
const byte pinsel = 2; // Select Button
const byte pinplus = 4; // Plus Button
const byte pinminus = 5; // Minus Button
// Instanzen
OneButton Btnsel(pinsel, true);
OneButton Btnplus(pinplus, true);
OneButton Btnminus(pinminus, true);
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, display_RESET);
EEPROM.get(0, daten);
for (byte i = 0; i < maxAnz; i++) {
checkminmax();
changed = true;
changed2 = true;
Btnsel.attachClick(selClick);
Btnsel.attachDoubleClick(selDblClick);
Btnplus.attachClick(plusClick);
Btnplus.attachDuringLongPress(plusDurPress);
Btnplus.attachLongPressStart(LongStart);
Btnminus.attachClick(minusClick);
Btnminus.attachDuringLongPress(minusDurPress);
Btnminus.attachLongPressStart(LongStart);
display.begin(SSD1306_SWITCHCAPVCC, 0x3C);
display.clearDisplay();
display.setTextWrap(false);
display.setTextSize(2);
display.setTextColor(WHITE);
display.setCursor(20, 30); display.print(F("Menu"));
display.display();
delay(2000);
PageSwitch = 1;
Btnsel.tick();
Btnplus.tick();
Btnminus.tick();
if (input)Showinput();
else if (PageSwitch == 1) {
Show(Page);
else if (PageSwitch == 2) {
Show2(Page2);
void selClick() {
changed = true;
changed2 = true;
if (input) {
Varindex++;
if (Varindex >= maxAnz) Varindex = 0;
if (Show && PageSwitch == 1) {
Page++;
if (Page >= 4) Page = 0;
if (Show2 && PageSwitch == 2) {
Page2++;
if (Page2 >= 4) Page2 = 0;
void selDblClick() {
if (input) saveEEprom();
input = !input;
changed = true;
changed2 = true;
#ifdef debug
Serial.print(Vartext[i]); Serial.print('\t');
Serial.println(daten.VarData[i]);
Serial.print("Change visual mode"); Serial.println(input);
Serial.print("Index "); Serial.println(Varindex);
#endif
void plusClick() {
click(1);
void minusClick() {
click(-1);
void plusDurPress() {
longclick(1);
void minusDurPress() {
longclick(-1);
void LongStart() {
longstart = millis();
void click(int inc) {
if (input) {
changed = true;
changed2 = true;
datachanged = true;
daten.VarData[Varindex] += inc;
checkminmax();
void longclick(int direction) {
static uint32_t oldtime;
int inc = 10;
if (millis() - longstart > 5000) inc = 100;
if (millis() - oldtime >= 100 && input) {
oldtime = millis();
changed = true;
changed2 = true;
datachanged = true;
daten.VarData[Varindex] += inc * direction;
checkminmax();
void checkminmax() {
if (daten.VarData[Varindex] < mindata[Varindex]) {
daten.VarData[Varindex] = mindata[Varindex];
if (daten.VarData[Varindex] > maxdata[Varindex]) {
daten.VarData[Varindex] = maxdata[Varindex];
void Showinput() {
if (changed || changed2) {
changed = false;
changed2 = false;
display.setCursor(0, 0); display.print("input");
display.setCursor(0, 20); display.print(Vartext[Varindex]);
display.setCursor(10, 40); display.print(daten.VarData[Varindex]);
display.display();
void Show(byte Page) {
if (changed) {
changed = false;
if (Page == 0) {
display.print("Main Menu");
else if (Page == 1) {
display.setCursor(0, 0); display.print("Page 1");
else if (Page == 2) {
display.setCursor(0, 0); display.print("Page 2");
else if (Page == 3) {
changed = true;
display.setTextSize(1);
display.setCursor(0, 0); display.print("Go to SubMenu");
display.setCursor(20, 20); display.print("Press Down Button");
if (!digitalRead(pinminus) ) {
PageSwitch = 2;
Show2(Page2);
changed = true;
display.display();
void Show2(byte Page2) {
if (changed2) {
changed2 = false;
if (Page2 == 0) {
display.print("Sub Menu");
else if (Page2 == 1) {
display.setCursor(0, 0); display.print("Sub Page 1");
else if (Page2 == 2) {
display.setCursor(0, 0); display.print("Sub Page 2");
else if (Page2 == 3) {
changed2 = true;
display.setCursor(0, 0); display.print("Go to Main Menu");
changed2 = true;
PageSwitch = 1;
Show(Page);
display.display();
void saveEEprom() {
if (datachanged) {
datachanged = false;
#ifdef debug
Serial.println("Save in EEprom");
#endif
EEPROM.put(0, daten);
