I wrote a nice front end that works with arduino and also Parallax USB scopes..
more info:
more info:
This is pretty cool - I might have to try it out. I currently have a Tek 2213 analog scope, but I also have a couple of the Parallax scopes, and the only thing holding me back from using them was the fact of no software for Linux, other than some Python (or was it Perl?) code I found.
I thought about writing my own driver/software using the code I did find as a base, but I have yet to even think about getting 'round to it...
This sounds like it might be interesting to play with! Thanks for posting it!
What is the biggest frequency that you can get with an arduino?
Nice. That software + firmware would drop right on to the hardware described in this project: practicalarduino.com
Jon
But the atmega 328 datasheet clearly states that the adc clock must be between 50Khz and 200KHz, how can this code put and the adc at 1Mhz and still get good values?
It's a trade-off. It's all explained in detail starting around page 194 of "Practical Arduino", but the basic summary is that the MCU's ADC is rated for optimal precision with a clock between 50 and 200KHz, but is designed to handle up to a 1MHz clock with minimal degradation. The ADC uses a successive approximation technique to read each bit of resolution sequentially, and changing the pre-scaler to force the ADC clock right up to 1MHz makes it complete each sample much faster (16 microseconds per read instead of 111 microseconds) at the cost of a little accuracy.
Jon
Practical Arduino: www.practicalarduino.com
And going back to the original topic....
Has anyone tried it yet? was it easy to use? I'd like to hear your feedback...
Thanks!
Some traffic stats about my post: (yeah kind of off topic)
From the 300 people that read this thread only 100 went to my blog entry, and from there only 45 went to the project page..
I hope this stats are helpful to you, one would expect that 100% of the people that read this post bother to click twice in order to read the full details...
Looks nice.
I have something similar, but rudimentary, working in Processing. I would have been tempted to try it, if it was in java as I have other code in java that I'd like to take advantage of.
wow, good timing. I'm learning Arduino and electronics at the same time.. the first thing I wanted is some kind of logic analyzer and scope.
I have Jonathan's excellent book and have been working to tweak the Processing to my liking....this will speed my progress.
thanks!!!
Wow really nice! A good use for my old arduino! ![]()
that's so sweet!
can't open the .pde file here...
got this error:
Exception in thread "AWT-EventQueue-0" java.lang.ArrayIndexOutOfBoundsException: 0
at processing.app.Sketch.setCurrentCode(Unknown Source)
at processing.app.Sketch.load(Unknown Source)
at processing.app.Sketch.<init>(Unknown Source)
at processing.app.Editor.handleOpenInternal(Unknown Source)
at processing.app.Editor.<init>(Unknown Source)
at processing.app.Base.handleOpen(Unknown Source)
at processing.app.Base.handleOpenPrompt(Unknown Source)
at processing.app.Base$3.actionPerformed(Unknown Source)
at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:1995)
at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2318)
at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:387)
at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:242)
at javax.swing.AbstractButton.doClick(AbstractButton.java:357)
at javax.swing.plaf.basic.BasicMenuItemUI.doClick(BasicMenuItemUI.java:1225)
at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(BasicMenuItemUI.java:1266)
at java.awt.Component.processMouseEvent(Component.java:6263)
at javax.swing.JComponent.processMouseEvent(JComponent.java:3267)
at java.awt.Component.processEvent(Component.java:6028)
at java.awt.Container.processEvent(Container.java:2041)
at java.awt.Component.dispatchEventImpl(Component.java:4630)
at java.awt.Container.dispatchEventImpl(Container.java:2099)
at java.awt.Component.dispatchEvent(Component.java:4460)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4574)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4238)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4168)
at java.awt.Container.dispatchEventImpl(Container.java:2085)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:599)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:269)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:184)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:174)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:169)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:161)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
the PDE is not Processing code, is arduino code.
Let me know how it goes...
i know that pde is arduino code, the error is from the arduino IDE
Well... you didn't explain how exactly did you get that error so it's hard to help you, and all I can do is guess.
Can you open other PDE's and flash them successfully on the arduino?
yes i can open other files and flash them, i got the error when i try to open the file on the IDE, i've dowloaded the file another time to check if its not corrupted but its the same.
can you share the code here?
thanks...
EDIT: I opened the file with notepad then I copied the source diretly to the IDE and everything is working now ![]()
I'll leave feedback later
it seems the arduino IDe doesnt like filenames that have dashes.. rename it to arduinooscillo.pde and it should work
I'll fix it in the repository, thanks!
ya, i also had to open the file with notepad and paste the code in - not too big a deal...
I am getting a lot of crashes with the C# program - divide by zero and some others. It seems to have a hard time 'finding' my arduino board also. I have tried 2 computers - my VISTA computer did not work but my XP workstation did. I'll try later with the source code assuming I can get the project to open with C# express. That might give me a clue as to why the communication is not working. I'm somewhat new at this so I might be missing something...
I am VERY interested in this application so I am determined to get it working and hopefully I can contribute in some tiny way.
Awesome! That is the spirit ![]()
