Arduino output relating to Ultrasonic Sensor code
This is the code given for the URM06 RS485 sensor:
#include "Arduino.h"
// Include application, user and local libraries
#include "URM_RS485.h"
#define Rs485TriggerPin 2 //the pin to select whether the RS485 is output or input
#define DefaultBaudrate 19200UL //the Default Baudrate for the Urm06_485
#define DefaultAddress 0x11 //the Default Address for the Urm06_485
#define DefaultMaxDistance (-1) //the Default Max Distance for the Urm06_485. "-1" means there is no Max Distance limitation. Set the Max Distance can limit the Distance range and speed up the detection.
#define CustomizedTimeOutDuration 500 //Time Out Duration can be Customized in "ms" unit
// Define variables and constants
URM_RS485 urm(Serial,Rs485TriggerPin); //select the Serial port for communication with Urm_485 sensor
void onTimeOut()
//If there is no reply from Urm_485 lasting for 1 second, this function will run. The time duration can be Customized
//TODO write your code here:
Serial.println("onTimeOut");
void onRequestDistance(byte theAddress, int theDistance)
//If received Distance reply, this function will run.
//theDistance is in "mm" unit
Serial.print("Address:");
Serial.println(theAddress);
Serial.print("Distance:");
Serial.print(theDistance);
Serial.println("mm");
void onRequestTemperature(byte theAddress, float theTemperature)
//If received Temperature reply, this function will run.
//theTemperature is in "°C" unit
Serial.print("Temperature:");
Serial.print(theTemperature);
Serial.println(" C");
void onRequestMaxDistance(byte theAddress, int theMaxDistance)
//If received Max Distance reply, this function will run.
//theMaxDistance is in "mm" unit
Serial.print("MaxDistance:");
Serial.print(theMaxDistance);
void onSetMaxDistance(byte theAddress, boolean isOperationSuccess)
//After setting the Max Distance and getting a reply, this function will run.
//Set the Max Distance can limit the Distance range and speed up the detection.
Serial.print("SetMaxDistance:");
if (isOperationSuccess) {
Serial.println("Success");
else{
Serial.println("Failure");
void onSetBaudrate(byte theAddress, boolean isOperationSuccess)
//After setting the Baudrate and getting a reply, this function will run.
Serial.print("SetBaudrate:");
else{
void onSetAddress(byte theAddress, boolean isOperationSuccess)
//After setting the Address and getting a reply, this function will run.
Serial.print("SetAddress:");
else{
void onWrongStack()
//If received wrong command, this function will run.
Serial.println("WrongStack");
//Run the proper function based on the different kinds of states
void commandProcess()
if (urm.available()) {
switch (urm.callBackState) {
case URM_RS485::OnTimeOut:
onTimeOut();
case URM_RS485::OnRequestDistance:
onRequestDistance(urm.receivedAddress, urm.receivedContent);
case URM_RS485::OnRequestTemperature:
onRequestTemperature(urm.receivedAddress, urm.receivedContent/10.0);
case URM_RS485::OnRequestMaxDistance:
onRequestMaxDistance(urm.receivedAddress, urm.receivedContent);
case URM_RS485::OnSetMaxDistance:
onSetMaxDistance(urm.receivedAddress, urm.receivedContent);
case URM_RS485::OnSetBaudrate:
onSetBaudrate(urm.receivedAddress, urm.receivedContent);
case URM_RS485::OnSetAddress:
onSetAddress(urm.receivedAddress, urm.receivedContent);
case URM_RS485::OnWrongStack:
onWrongStack();
default:
// Add setup code
urm.begin(DefaultBaudrate);
// Add loop code
commandProcess();
static unsigned long sendingTimer=millis();
if (millis()-sendingTimer>=1000) {
//Each function below from URM_RS485 returns the state whether RS485 Bus is busy or not.
//If the Bus is busy, wait until the bus is released.
while(!urm.requestDistance(DefaultAddress)) {
commandProcess();
// while(!urm.requestTemperature(DefaultAddress)) {
// commandProcess();
// while(!urm.requestMaxDistance(DefaultAddress)) {
// while(!urm.setAddress(DefaultAddress)) {
// while(!urm.setBaudrate(DefaultAddress, DefaultBaudrate)) {
// while(!urm.setMaxDistance(DefaultAddress, DefaultMaxDistance)) {
// while(!urm.requestDistance(DefaultAddress, CustomizedTimeOutDuration)) {
// while(!urm.requestTemperature(DefaultAddress, CustomizedTimeOutDuration)) {
// while(!urm.requestMaxDistance(DefaultAddress, CustomizedTimeOutDuration)) {
// while(!urm.setAddress(DefaultAddress, CustomizedTimeOutDuration)) {
// while(!urm.setBaudrate(DefaultAddress, DefaultBaudrate, CustomizedTimeOutDuration)) {
// while(!urm.setMaxDistance(DefaultAddress, DefaultMaxDistance, CustomizedTimeOutDuration)) {
I have no idea why i would get weird inputs as followed:
XúíÞ?øXúíÞï?xXúíÞï?øXúíÞï?øXúíÞï?øXú
Þï?øXúÖó÷ZÄ�!�ÓˆÌXúÖó÷†Ä�!�ÓˆÌXúÖ+÷ZÄ�!�ÓˆÌXúÖó÷ZÄ�!­ÓˆÌXúÖó÷ZÄÅ!�ÓˆÌXúÖó÷ZÄ�!�ÓˆÌXúVó÷ZÄ�!�ÓˆÌ
Anyone have any possible incite of this
Looks like it uses the Serial port and sets its baud rate to 19200. So you probably want to set the serial monitor to that also.
That was it thank you so much!!!!!!!!
