I am trying to tune my setup with PID Autotune, unfortunately once I press 1 and the tuning starts, the tuning never goes anywhere an continues forever without ever giving the new constant values. What could be the reason?
#include <PID_v1.h>
#include <PID_AutoTune_v0.h>
byte ATuneModeRemember=2;
double input=80, output=50, setpoint=150;
double kp=2,ki=0.5,kd=2;
double kpmodel=1.5, taup=100, theta[50];
double outputStart=5;
double aTuneStep=50, aTuneNoise=1, aTuneStartValue=100;
unsigned int aTuneLookBack=20;
boolean tuning = false;
unsigned long modelTime, serialTime;
int raw = analogRead(A0); // Assuming the thermistor is connected to pin A0
PID myPID(&input, &output, &setpoint,kp,ki,kd, DIRECT);
PID_ATune aTune(&input, &output);
// Constants for the new temperature reading method
#define HISTORY_SIZE 5
#define RT0 100000 // Ω
#define B 3950 // K
#define VCC 3.3 // Supply voltage
#define R 100000 // R=100KΩ
#define T0 298.15 // Kelvin equivalent of 25 degrees Celsius
int Thermistor1_PIN = A0;
int Thermistor2_PIN = A1;
bool firstRun = true;
float historyA0[HISTORY_SIZE];
float historyA1[HISTORY_SIZE];
int historyIndexA0 = 0;
int historyIndexA1 = 0;
//set to false to connect to the real world
boolean useSimulation = false;
const long controlInterval = 500; // half second
unsigned long onTime = map(output, 0, 255, 0, controlInterval);
if(useSimulation)
for(byte i=0;i<50;i++)
theta[i]=outputStart;
modelTime = 0;
//Setup the pid
myPID.SetMode(AUTOMATIC);
if(tuning)
tuning=false;
changeAutoTune();
tuning=true;
serialTime = 0;
pinMode(4, OUTPUT);
float resistance = (VCC * R) / ((VCC * raw) / 1023.0) - R;
float temperatureK = 1 / ((log(resistance / RT0) / B) + (1 / 298.15)); // 298.15 is room temperature in Kelvin
float temperatureC = temperatureK - 273.15;
unsigned long now = millis();
if(!useSimulation)
{ //pull the input in from the real world
input = readTemperature();
if(tuning)
byte val = (aTune.Runtime());
if (val!=0)
tuning = false;
if(!tuning)
//we're done, set the tuning parameters
kp = aTune.GetKp();
ki = aTune.GetKi();
kd = aTune.GetKd();
myPID.SetTunings(kp,ki,kd);
AutoTuneHelper(false);
// Print the new values immediately
Serial.print("New kp: "); Serial.print(kp); Serial.print(" ");
Serial.print("New ki: "); Serial.print(ki); Serial.print(" ");
Serial.print("New kd: "); Serial.println(kd);
else myPID.Compute();
controlSSR();
if(useSimulation)
theta[30]=output;
if(now>=modelTime)
modelTime +=100;
DoModel();
//send-receive with processing if it's time
if(millis()>serialTime)
SerialReceive();
SerialSend();
SerialSendPlotter();
serialTime+=500;
void changeAutoTune()
if(!tuning)
//Set the output to the desired starting frequency.
output=aTuneStartValue;
aTune.SetNoiseBand(aTuneNoise);
aTune.SetOutputStep(aTuneStep);
aTune.SetLookbackSec((int)aTuneLookBack);
AutoTuneHelper(true);
tuning = true;
{ //cancel autotune
aTune.Cancel();
tuning = false;
void AutoTuneHelper(boolean start)
if(start)
ATuneModeRemember = myPID.GetMode();
myPID.SetMode(ATuneModeRemember);
void SerialSend()
Serial.print("setpoint: ");Serial.print(setpoint); Serial.print(" ");
Serial.print("input: ");Serial.print(input); Serial.print(" ");
Serial.print("output: ");Serial.print(output); Serial.print(" ");
if(tuning){
Serial.println("tuning mode");
Serial.print("kp: ");Serial.print(myPID.GetKp());Serial.print(" ");
Serial.print("ki: ");Serial.print(myPID.GetKi());Serial.print(" ");
Serial.print("kd: ");Serial.print(myPID.GetKd());Serial.println();
void SerialSendPlotter() {
Serial.print(input, 2); // Temperature value with 2 decimal places
Serial.print(", ");
Serial.println(setpoint, 2); // Setpoint value with 2 decimal places
void SerialReceive()
if(Serial.available())
char b = Serial.read();
Serial.flush();
if((b=='1' && !tuning) || (b!='1' && tuning))changeAutoTune();
void DoModel()
//cycle the dead time
for(byte i=0;i<49;i++)
theta[i] = theta[i+1];
//compute the input
input = (kpmodel / taup) *(theta[0]-outputStart) + input*(1-1/taup) + ((float)random(-10,10))/100;
float readTemperature() {
// Read from both sensors
float newTempA0 = readRawTemperature(Thermistor1_PIN);
float newTempA1 = readRawTemperature(Thermistor2_PIN);
// Initialize history with first reading
if (firstRun) {
for (int i = 0; i < HISTORY_SIZE; i++) {
historyA0[i] = newTempA0;
historyA1[i] = newTempA1;
firstRun = false;
// Calculate average
float avgA0 = average(historyA0, HISTORY_SIZE);
float avgA1 = average(historyA1, HISTORY_SIZE);
// Check for outliers using a simpler method and ignore them if found
if (abs(newTempA0 - avgA0) <= (0.2 * avgA0)) {
historyA0[historyIndexA0] = newTempA0;
historyIndexA0 = (historyIndexA0 + 1) % HISTORY_SIZE;
if (abs(newTempA1 - avgA1) <= (0.2 * avgA1)) {
historyA1[historyIndexA1] = newTempA1;
historyIndexA1 = (historyIndexA1 + 1) % HISTORY_SIZE;
// Compute the final temperature with simple smoothing
float finalTemp = (average(historyA0, HISTORY_SIZE) + average(historyA1, HISTORY_SIZE)) / 2.0;
static float previousTemp = finalTemp;
finalTemp = 0.8 * previousTemp + 0.2 * finalTemp;
return finalTemp;
float readRawTemperature(int pin) {
float voltage = (analogRead(pin) / 1023.0) * VCC;
float RT = (voltage * R) / (VCC - voltage);
float ln = log(RT / RT0);
float TX = (1 / ((ln / B) + (1 / T0)));
TX = TX - 273.15; // Convert Kelvin to Celsius
return TX;
float average(float arr[], int size) {
float sum = 0.0;
for (int i = 0; i < size; i++) {
sum += arr[i];
return sum / size;
void controlSSR() {
static unsigned long previousMillis = 0;
if (currentMillis - previousMillis >= controlInterval) {
else if (currentMillis - previousMillis < onTime) {
digitalWrite(4, LOW); // Turn on the SSR
else {
digitalWrite(4, HIGH); // Turn off the SSR
