Arduino pin always high and other blink at same time
I need a pin always high without delay and in same time one pin blink.
I try this code, but the bluetooth light isn't always linked
int led = 13;
const int bluetooth = 11;
int ledState = LOW; // ledState used to set the LED
long previousMillis = 0;
long interval = 0;
int lamp = 12;
void setup() { // put your setup code here, to run once:
pinMode(led, OUTPUT);
pinMode(lamp, OUTPUT);
pinMode(bluetooth, OUTPUT); }
digitalWrite(bluetooth, HIGH);
if(currentMillis - previousMillis > interval) {
if (ledState == LOW)
ledState = HIGH;
else ledState = LOW;
digitalWrite(bluetooth, ledState); }
digitalWrite(led, HIGH);
delay(5000);
digitalWrite(led, LOW);
delay(5000);
digitalWrite(lamp, HIGH);
delay(5000);
digitalWrite(lamp, LOW);
delay(5000);
Can someone help?
Can someone help?
When you get rid of ALL of the delay calls, yes. Until then, the reason that your bluetooth LED doesn't (b)link is because of the delay() calls.
Checkout the blinkWithoutDelay example and see how to avoid using delay().
I cannot begin to tell you how much I hate your code layout. It seems to be designed to make it hard to read.
Here it is tidied up, auto-formatted and in code tags.
int led = 13;
long interval = 0;
int lamp = 12;
      ledState = HIGH;
      ledState = LOW;
  delay(5000);
  delay(5000);
  delay(5000);
  delay(5000);
As to your problem, have a look at Gammon Forum : Electronics : Microprocessors : How to do multiple things at once ... like cook bacon and eggs
