Let me start with saying without being rude Please do not reply with negativity such as "You are a beginner, not gonna happen etc" Because I am sick of being told i can't do something due to knowledge then i research for 2 months and pull it off anyway. I am here to learn and for information most of you started in the same boat.
Now that's out of the way i wanted to make a Meter for my Job with Hydroponics and i wanted to create my own Self uploading and monitoring equipment. Simple Features as (Water's: PPM Maybe (EC in future) and PH) as well as Co2 Monitor for an environment Kind of how this guy did here by uploading the results to a cloud
Example: CJMCU-8118 (CCS811 and HDC1080) - ThingSpeak IoT
My Questions:
I just need to be pointed in the right direction for starters. For those of you once in my shoes thanks for your advice/input.
First and for most to save everyone time and effort's i just wanted to know what device should i be looking into for a 24hr running device example: Raspi, Arduino, Other? as far as most options to build on and work with for the task i require i can post examples of the pieces of equipment's tasks i am trying to replicate.
Reason For interest:
Some of the pieces of equipment created and sold for combined controllers are priced starting $3k+ (Cannot Afford, For multiple locations)
Datadecimal:
You don't have to make it that obvious you're new here. That's what your post count gives away already.
PPM sensor: that's measured through EC, so you got that the wrong way around. Sounds simple, is simple, is not easy at all. I hope to launch my Kickstarter campaign in September for an inexpensive EC sensor, limited range but more than enough for hydroponics. Or if you like to build yourself - follow the links to source & schematics.
For accurate measurements you must add a water temperature sensor - the EC changes by about 2% for every 1 °C temperature change.
pH sensor: get an industrial type pH probe (those are designed to be continuously submerged) and amplifier board. Also can do with temperature correction.
CO2 sensor: no direct experience; a quick search here or on Google will tell you all you need to know.
Controller: as you want Internet connectivity go for an ESP8266 based board such as NodeMCU or WeMOS D1.
For CO2, use an NDIR type. It's essentially a small photometer with a filter so it only looks at the carbonyl peak, so it's very selective for just CO2. I've used several, and the K30 is very good. I also have used the Gravity and Vernier NDIR sensors. Unfortunately they are expensive, but they don't wear out, and other gasses don't interfere as they do with the resistive type
