Can anybody point me to where i can find the schematics or info to add a 5 pin midi input to an Arduino pro micro, I have looked everywhere and found lots of information but i am very confused as to what is correct and not sure if it is suited to my controller. Thanks for any help in advance!!!!! ![]()
pempi78:
What have you looked at so far so people don't duplicate your efforts?
What is "confusing" ?
Well this is an example but it's a UNO board so not sure if it will work with my pro micro
https://libremusicproduction.com/tutorials/arduino-and-midi-in
This is another one with different pin connection using the same board
It looks possible to me.
How were you planning on uploading the code to the Pro Mini?
i am going to create new code at least if i know the connection will work, which link looks possible both of them?
I actually have the Pro Micro Leonardo
Those circuits are all basically the same and any of them will work. MIDI isn't very fussy about resistor values. I usually use the version from Notes and Volts: Midi for the Arduino - Build a Midi Input Circuit which works with Uno/Nano/Pro Micro and just about any other 5V Arduino.
What pin you use on the Arduino will depend on what code you're using.
Steve
Ok Great thanks for the help! ![]()
pempi78:
I haven't heard of the Pro Micro Leonardo.
What's the link for it?
