Arduino Pro Micro Timer and Interruption Problems
Hello!
I am trying to have a code that will light a led and will calculate the time an LDR is taking to detect it.
I am struggling a little bit with the timers. I am using Timer1 at 100kHz without prescaler to detect the signal from the LDR (read the analog input)
As I am not able to use millis()... I do not know why, to be honest... I am using the interruptions on the Timer1 to update a counter, that should be happening every 10 us. However it looks to be slower than that.
#include<stdio.h>
#include<stdlib.h>
#include<string.h>
#include<unistd.h>
//Register variables
    unsigned char OCR1AL_reg = 0x88; //output compare low 8 bits for Counter 1
    unsigned char OCR1AH_reg = 0x89; //output compare high 8 bits for Counter 1
    unsigned char TCCR1B_reg = 0x81; //Timer/Counter0 Control Register B
    unsigned char TCCR1A_reg = 0x80; //Timer/Counter0 Control Register A
    unsigned char TIMSK1_reg = 0x6F; //Timer/Counter0 Interrupt Mask Register
    unsigned char TIFR1_reg = 0x36; //Timer/Counter0 Interrupt Flag Register
    unsigned char TCNT1H_reg = 0x85; //Timer/Counter0 Interrupt Flag Register
    unsigned char TCNT1L_reg = 0x84; //Timer/Counter0 Interrupt Flag Register
    boolean ledState=false;
    int ledPin = 6;      // LED connected to digital pin 6
    int ledPin2= 7;
    unsigned char SREG_reg = 0x5F; //Status register used for disabling and enabling global interrupts
    int analogIn = A0;
    int Aval =0;
    unsigned long timeDetection;
    unsigned long timeLED =0;
    unsigned long diffTime=0;
    unsigned long counterTime=0 ;
    bool flagInput = false;
    bool flagPrint = false;
    bool checkAnalog = false;
    //resetting the Timer/Counter1
     (*(volatile unsigned char*)(TCNT1H_reg)) = 0;
     (*(volatile unsigned char*)(TCNT1L_reg)) = 0;
     //disabling all global interrupts
     (*(volatile unsigned char *)(SREG_reg)) = 0b00000000;
    //defining prescalar
     (*(volatile unsigned char *)(TCCR1B_reg)) = 0b01001001; //the last 3 bits set to 001 will make the clock scalar 1 ;
     //setting up CTC mode
     (*(volatile unsigned char *)(TCCR1A_reg)) = 0b10000000;
      //defining the output compare value which is calculated to be  assuming 16MHz clock speed: OCRNA = (fClk_I/O)/(N*fOCRNA) where N is the prescalar fOCRNA is the compare value and fClk_I/O is the clock speed
      //the value calculated for fOCRNA to be 1 MHz is 16 --> 0b10000
     (*(volatile unsigned char *)(OCR1AH_reg)) = 0b00000000; //writing to high first which will write to a temp register first
      (*(volatile unsigned char *)(OCR1AL_reg)) = 0b10100000; //writing to low will write both high and low in the same clock cycle
    (*(volatile unsigned char *)(TIMSK1_reg)) = 0b00100010; //writing so that output compare A is set up
    //enable global interrupts
     (*(volatile unsigned char*)(SREG_reg)) = 0b10000000;
      // initialize digital pin LED_BUILTIN as an output.
      pinMode(ledPin, OUTPUT);
      pinMode(ledPin2, OUTPUT);
ISR(TIMER1_COMPA_vect) // timer compare interrupt service routine
   counterTime++;
    CheckAnalogInput()
void CheckAnalogInput(){
  //Read Analog and write in serial.
  Aval = analogRead(analogIn);   // read the input pin
  if (Aval<300 && flagInput)
      timeDetection= counterTime;
      flagInput=false;
      flagPrint= true;
      digitalWrite(ledPin, 0);
   //Serial.println(counterTime);
  if (flagPrint)
      flagPrint=false;
      Serial.print("timeLED   (ms)");
      Serial.println(timeLED* 0.01);
      Serial.print("timeDetection  (ms) ");
      Serial.println(timeDetection* 0.01);
      Serial.print("diffTime  (ms) ");
      diffTime=    timeDetection - timeLED;
      Serial.println(diffTime* 0.01);
      counterTime=0;
 if (Serial.available()) {
      // get the new byte:
      char inChar = (char)Serial.read();
      // if the incoming character is a newline, set a flag so the main loop can
      // do something about it:
      if (inChar == '\n') {
        digitalWrite(ledPin, 1);
        timeLED= counterTime;
         flagInput = true;
First of all, Do you know why I cannot use millis()? everytime I try to use it instead of the counter I get 0. If I use micros() it will overflow... For that reason I decided to use the counter.
When I check with the counter, the values I get make no sense...
Hope you can help me here!
Hello Alco6,
welcome to the forum. For following the forum instructions and posting your code correctly on your first post ++Karma;
I don't know the answer to either question, but with regard to millis(), which I have used many times without issue, what have you tried? Can you post some simple code using millis() to illustrate what you are trying that doesn't work?
An analogRead() needs more than 10µs to execute. Using analogRead() you might get up to about 8kS/s.
An LDR won't be fast enough to measure such fast actions. You must use a photo transistor or something similar for your task.
Hello!!
Thank you very much for your answer.
pylon, you are right, it was a problem of the speed for the interruption.
I have changed it to 1kHz, and it is working perfectly fine now, and the Resistance Recovery Rate of the LDR do not affect too much .
In case I have any problems I will definitely change it for a photo transistor.
