Arduino project on Tinkercad not working
Hi everyone! I'm from Brazil, so sorry if the english is not that good. I've studied elotronics some time ago, but I've never got into programing and haven´t used that knowledge in quite some time, so sorry if there's something basic I'm missing.
I'm trying to use tinkercad to simulate a circuit that lets you choose for how long a motor will be functioning and than start the motor. I'm using diferent AIs to help me build it, but I'm stuck and not evolving from the AIs. I even tried to take all the other components off the circuit and use a "hello World" code to test it, but it doesn't work. The arduino uno turns on and the LCD backlight as well, but no text is displayed. It´s not about the contrast, because even if I messe with the potenciometer nothing diferent happens.
I'm going to put the conections in here, as well as the code that the AIs wrote. Any insight is more than helpfull :slight_smile:
The motor has the negative connection to the GND of the Arduino, while the positive is connected to the C output of the TIP 120. There is a diode connected in parallel to the motor's power supply.
The TIP 120 transistor connects its E terminal to the negative rail of the breadboard, while the B terminal is connected to pin 5 of the Arduino, with a resistor to protect the component.
The trigger switch has terminal 2b connected to the positive rail on the breadboard, while terminal 1a is connected to ground with a resistor. Terminal 1b is connected to pin 4 of the Arduino, while terminal 2a is not connected.
The LCD display follows the connections below:
  • RS connected to pin 13
  • E connected to pin 12
  • D4 connected to pin 11
  • D5 connected to pin 10
  • D6 connected to pin 9
  • D7 connected to pin 8
  • GND connected to the negative rail of the breadboard
  • VCC connected to the positive rail of the breadboard
  • V0 connected to the potentiometer that controls the LCD brightness
  • RW connected to the negative rail of the breadboard
  • DB0 is not connected to anything
  • DB1 is not connected to anything
  • DB2 is not connected to anything
  • DB3 is not connected to anything
  • LED anode is connected to power with a resistor
  • LED cathode is connected to GND
The keypad follows the connections below:
  • Row 1 connected to pin A0
  • Row 2 connected to pin A1
  • Row 3 connected to pin A2
  • Row 4 connected to pin A3
  • Column 1 connected to pin A4
  • Column 2 connected to pin A5
  • Column 3 connected to pin 6
  • Column 4 connected to pin 7
The code I'm trying right now is the following, wrote by Deepseek (I've tried ChatGPT, Gemini and Copilot, all with the same result). The only test code that seemed to work is one that makes the L LED of the arduino blink, all the others had the same result, LCD backlight goes on and displays nothing. The tinkercad doesn't indicate any problem with the code.
// Configurações do LCD (sem I2C)
#include <LiquidCrystal.h>
LiquidCrystal lcd(13, 12, 11, 10, 9, 8); // Novos pinos: RS, E, D4, D5, D6, D7
// Configurações do teclado 4x4
const byte ROWS = 4; // 4 linhas
const byte COLS = 4; // 4 colunas
char keys[ROWS][COLS] = {
  {'1','2','3','A'},
  {'4','5','6','B'},
  {'7','8','9','C'},
  {'*','0','#','D'}
byte rowPins[ROWS] = {A0, A1, A2, A3}; // Conectar às linhas do teclado
byte colPins[COLS] = {A4, A5, 6, 7};   // Conectar às colunas do teclado
// Pino do motor (conectado ao transistor)
const int motorPin = 5; // Base do transistor (controla o motor)
// Pino do switch
const int switchPin = 4;
// Variáveis
unsigned long motorTime = 5000; // Tempo padrão de ativação do motor (5 segundos)
bool motorRunning = false;
unsigned long motorStartTime = 0;
  // Inicializa o LCD
  lcd.begin(16, 2);
  lcd.print("Tempo Motor:");
  lcd.setCursor(0, 1);
  lcd.print(motorTime / 1000);
  lcd.print(" seg");
  // Configura o pino do motor
  pinMode(motorPin, OUTPUT);
  digitalWrite(motorPin, LOW); // Inicia com o motor desligado
  // Configura o pino do switch
  pinMode(switchPin, INPUT_PULLUP);
  // Configura os pinos do teclado
  for (byte r = 0; r < ROWS; r++) {
    pinMode(rowPins[r], OUTPUT);
    digitalWrite(rowPins[r], HIGH); // Desativa as linhas
  for (byte c = 0; c < COLS; c++) {
    pinMode(colPins[c], INPUT_PULLUP); // Configura as colunas como entrada com pull-up
  // Verifica se o switch foi pressionado
  if (digitalRead(switchPin) == LOW && !motorRunning) {
    motorRunning = true;
    motorStartTime = millis();
    digitalWrite(motorPin, HIGH); // Liga o motor
    lcd.print("Motor ON ");
  // Verifica se o tempo de ativação do motor acabou
  if (motorRunning && (millis() - motorStartTime >= motorTime)) {
    digitalWrite(motorPin, LOW); // Desliga o motor
    lcd.print("Motor OFF");
  // Verifica a entrada do teclado para alterar o tempo
  char key = getKey();
  if (key) {
    if (key >= '0' && key <= '9') {
      motorTime = (motorTime * 10) + ((key - '0') * 1000);
      if (motorTime > 60000) motorTime = 1000; // Limite máximo de 60 segundos
      lcd.print(" seg");
    } else if (key == 'C') {
      motorTime = 1000; // Reseta para 1 segundo
      lcd.print(" seg");
// Função para ler o teclado matricial
char getKey() {
    digitalWrite(rowPins[r], LOW); // Ativa a linha
      if (digitalRead(colPins[c]) == LOW) {
        digitalWrite(rowPins[r], HIGH); // Desativa a linha
        return keys[r][c]; // Retorna a tecla pressionada
  return 0; // Nenhuma tecla pressionada
AI made the code?
Please transform the text to schematics.
Yes, the code was made by deepseek, but I've tried ChatGPT, Gemini and Copilot as well, with the same result.
I've added the schematics to the text, sorry for the confusion... I'm not used to these forums.
The recommendation is to continue asking them.
It doesn´t work, it keeps saying that the code is right and it's something with the components... but since it's a test on tinkercad, that can't be the case
That motor connection to GND is wrong.
The motor should be connected between the collector of the TIP120 and the positive terminal of the motor power supply.
It's coneccted like the tinkercad tells to, but I've tried putting as you sad and it kept the same. I think it's about the code cause nothing shows up on the display and it should be showing the turn on message...
I've tried using test codes like that "hello world" one, but not even that shows up on the display.
I'm going to try to get another code that works for something else and adapt it.
