Arduino Python Serial
I see your post in Arduino Forum.
I want to get data from serial port, so I used this code to arduino:
int potPin = 0;
int val = map(analogRead(potPin), 0, 1023, 0, 255);
Serial.println(val);
And this code to python:
import serial
ser=serial.Serial(port='COM3',timeout=3)
s=ser.read(100) #reading up to 100 bytes
print s
When I connect the arduino to the serial port, python show 4 values from the serial port. But, if a run the code in python again, occurs this error:
raise SerialException("could not open port %s: %s" % (self.portstr, ctypes.WinError()))
serial.serialutil.SerialException: could not open port COM3: [Error 5] Access denied.
Can you help me?
Thanks
does the python script release the com port ? ==> you might need an explicit ser.close()
be aware that ser.read(100) read 100 bytes and that the Arduino sends 1-4 chars followed by \r\n per value.
So the variable s need to be processed to get the values back.
