Arduino rc car
Hi, I've got a problem when i'm trying to upload my code to Arduino UNO .
This is my code:
//Se crea la variable
int unChar;
//Se crean las funciones
void adelante();
void reversa();
void parado();
void parado2();
void derecha();
void izquierda();
//Se iniclializa el puerto
void setup(){
//Se llama a la función dependiendo de los datos que reciba
void loop(){
  char unChar=Serial.read();//Se leen los datos entrantes
  //Se inicia el switch
  switch (unChar){
    case 'w':
    adelante();
    digitalWrite(led,HIGH); //Indicador para saber si recibe los datos
    Serial.write("Avanzar");
    case 's':
    reversa();
    digitalWrite(led,LOW);
    Serial.write("retroceder");
    case '<':
    izquierda();
    Serial.write("izquierda");
    case '>':
    reversa();
    Serial.write("derecha");
    case 'c':
    parado();
    Serial.write("parado control");
   case 's':
    parado2();
    Serial.write("parado direccion");
   //Declaración de funciones
   void adelante(){
     digitalWrite(motorA,LOW);
     digitalWrite(motorB,HIGH);
     //digitalWrite(led,HIGH);
     void reversa(){
     digitalWrite(motorA,HIGH);
     digitalWrite(motorB,LOW);
     void izquierda(){
     digitalWrite(dirA,LOW);
     digitalWrite(dirB,HIGH);
   void derecha(){
     digitalWrite(dirA,HIGH);
     digitalWrite(dirB,LOW);
    void parado(){
   void parado2(){
And these are the problems :
define the undefined...:
like..:
int led=13; //??
byte motorA=4;
byte motorB=5;
byte dirA=.... //compete with correct pin numbers
I don't know how to do that , please can you help me? . The connections of the car are something like that.
Did you write the code or copy some/all of it from somewhere ?
How many of the Arduino example programs in the IDE have you looked at and run ?
Ok , I just read some information about it and I solved my problem :smiley: :smiley: . Thanks. Sorry for not seeking information before. :-[ :-[
