Arduino RFID + PIN Lock
Hey! I am trying to setup RFID + PIN using arduino !
My Code works perfect with just RFID! But when i am trying to add second factor authentication i.e. the pin my code doesn't work any more!
 #include <SPI.h>
 #include <MFRC522.h>
 #include <Keypad.h>
 #include <LiquidCrystal.h>
 const byte numRows= 4; //number of rows on the keypad
 const byte numCols= 4; //number of columns on the keypad
 //keymap defines the key pressed according to the row and columns just as appears on the keypad
 char keymap[numRows][numCols]=
 {'1', '2', '3', 'A'},
 {'4', '5', '6', 'B'},
 {'7', '8', '9', 'C'},
 {'*', '0', '#', 'D'}
 //Code that shows the the keypad connections to the arduino terminals
 byte rowPins[numRows] = {2, 3, 4, 5}; //Rows 0 to 3
 byte colPins[numCols]= {6, 7, 8, 9}; //Columns 0 to 3
 //initializes an instance of the Keypad class
 Keypad myKeypad= Keypad(makeKeymap(keymap), rowPins, colPins, numRows, numCols);
 // initialize the library with the numbers of the interface pins
 LiquidCrystal lcd(24, 25, 26, 27, 28, 29);
 #define SS_PIN 10
 #define RST_PIN 9
 MFRC522 rfid(SS_PIN, RST_PIN); // Instance of the class
 MFRC522::MIFARE_Key key;
 // Init array that will store new NUID
 byte nuidPICC[4];
 byte knownTac0[4] = {43,149,119,172};
 byte knownTac1[4] = {150,014,65,59};
 byte knownTac2[4] = {102,27,07,73};
 bool success = false;
 int id;//!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
 int redpin = 41;
 int greenpin = 40;
  pinMode(redpin, OUTPUT);
  pinMode(greenpin, OUTPUT);
  // set up the LCD's number of columns and rows:
  lcd.begin(16, 2);
  SPI.begin(); // Init SPI bus
  rfid.PCD_Init(); // Init MFRC522
  // Print a message to the LCD and Serial.
  lcd.clear();
  lcd.print("Waiting for Card");
  Serial.println("Waiting for Card");
  digitalWrite(redpin, HIGH);
// Look for new cards
  if ( ! rfid.PICC_IsNewCardPresent())
   return;
  // Verify if the NUID has been read
  if ( ! rfid.PICC_ReadCardSerial())
   return;
  lcd.clear();
  lcd.print("Card Detected");
  Serial.println(F("Card Detected"));
  // Store NUID into nuidPICC array
  for (byte i = 0; i < 4; i++) {
   nuidPICC[i] = rfid.uid.uidByte[i];
  // comparing IDs
  if (knownTac0[0] == nuidPICC[0] &&
    knownTac0[1] == nuidPICC[1] &&
    knownTac0[2] == nuidPICC[2] &&
    knownTac0[3] == nuidPICC[3]){
   lcd.clear();
   lcd.print("Sumbal");
   Serial.println(F("Sumbal"));
   success = keypad_loop("1111");
  else if(knownTac1[0] == nuidPICC[0] &&
      knownTac1[1] == nuidPICC[1] &&
      knownTac1[2] == nuidPICC[2] &&
      knownTac1[3] == nuidPICC[3]){
    lcd.clear();
  else if(knownTac2[0] == nuidPICC[0] &&
      knownTac2[1] == nuidPICC[1] &&
      knownTac2[2] == nuidPICC[2] &&
      knownTac2[3] == nuidPICC[3]){
   lcd.clear();
  else {
   lcd.clear();
   lcd.print("Not Found");
   Serial.println("Not found");
  if(success){
   lcd.clear();
   lcd.print("Door Unlocked!");
   Serial.println("Door Unlocked!");
   digitalWrite(redpin, LOW);
   digitalWrite(greenpin, HIGH);
  else{
   lcd.clear();
   lcd.print("Try again!");
   Serial.println("Try again!");
    // Halt PICC
  rfid.PICC_HaltA();
  // Stop encryption on PCD
  rfid.PCD_StopCrypto1();
  delay(2000);
  lcd.clear();
  digitalWrite(greenpin, LOW);
 bool keypad_loop(String PIN){ // PIN section
  lcd.clear();
  lcd.print("Enter PIN...");
  Serial.println("Enter PIN...");
  String input;
  int i = 0;
  bool control = true;
  while(control == true){
  char keypressed = myKeypad.getKey();
  if (keypressed != NO_KEY){
   if(i<4){ // 4-digit input
    if(i==0)lcd.clear();
    i++;
    input.concat( String(keypressed) );
    lcd.print("*");
   if(i==4){
    control = false;
    if(input.equals(PIN) ){
     success = true;
  } // NO_KEY if ends
  } // while ends
  return success;
Here's the code i used!
The code works if i don't call "keypad_loop" using "success = keypad_loop("####")"
What might be wrong?
Using arduino UNO btw , and ignore the pin numbers for LCD and LED's!
That example you started with is pure garbage. There is NO excuse for returning if there is no card present. That stops loop() from doing anything else.
keypad_loop() is a non-blocking function. It does NOT wait for the required number of keys to be pressed. You need to change it to a blocking function (bad idea) or call it over and over until it returns true. Which, of course, your code can not possibly do.
