Arduino RFID
Hello all...I built an RFID reader based on the famous PCMOFO design and used the parallax reader to change it up a bit. I am having trouble with it in the sense that it works great as soon as you turn it on or after a reset but after a few reads, it quits responding even though on a serial monitor via arduino software or hyperterminal, it always shows the HEX number of the cards as I scan them, but I get no response from the circuit. I have been at it for days with no luck and consistent bad results. Any ideas on what I am missing or doing wrong?
B.
It's difficult to say as I don't have a clear idea of what you have done. When you say:-
It is not like you have posted a schematic or anything. The implication is that the reader still works but some "something" hangs up after a bit. While the PCMOFO might be famous unfortunately it has passed me by. However in the absence of any other information look to add extra supply decoupling on your system.
#include <EEPROM.h> // Needed to write to EEPROM storage
#define powerPin 10
#define failPin 11
#define passPin 12
#define doorPin 13
boolean programMode = false;
boolean match = false;
byte storedCard[6]; // Stores an ID read from EEPROM
byte readCard[6]; // Stores an ID read from the RFID reader
byte checksum = 0; // Stores the checksum to verify the ID
// for (int i = 0; i < 512; i++) // Uncoment to wipe the EEPROM
// EEPROM.write(i, 0);
pinMode(powerPin, OUTPUT); // Connected to Blue on tri-color LED to indicate reader is ready
pinMode(passPin, OUTPUT); // Connected to Green on tri-color LED to indicate user is valid
pinMode(failPin, OUTPUT); // Connected to Green on tri-color LED to indicate user is NOT valid or read failed
pinMode(doorPin, OUTPUT); // Connected to relay to activate the door lock
Serial.begin(2400); // Connect to the serial port
void loop ()
byte val = 0; // Temp variable to hold the current byte
normalModeOn(); // Normal mode, blue Power LED is on, all others are off
if ( programMode) // Program mode to add a new ID card
programModeOn(); // Program Mode cycles through RGB waiting to read a new card
if(Serial.available() > 0) // Waits for something to come on the serial line
if((val = Serial.read()) == 10) // First Byte should be 2, STX byte
getID(); // Get the ID, sets readCard = to the read ID
if ( !isMaster(readCard) ) // Check to see if it is the master programing card
writeID(readCard); // If not, write the card to the EEPROM storage
programMode = false; // Turn off programing mode
checksum = 0; // Make sure the checksum is empty
// Normal Operation...
if(Serial.available() > 0) // If the serial port is available and sending data...
byte bytesread = 0;
for ( int i = 0; i < 5; i++ ) // Loop 5 times
if ( readCard < 16 ) // Print out 0 if < 16 to prepend output
  • Serial.print("0");*
_ Serial.print(readCard*, HEX); // Print out the hex value read in*_
* Serial.print(" ");*
* Serial.println();*
* Serial.print("Checksum: ");*
* Serial.print(readCard[5], HEX); // Checksum read from the card*
* if ( readCard[5] == checksum ) // See if the 5th BYTE (the checksum) read in from the reader*
* { // matches the checksum caculated*
* checksum = 0; // If so, we can empty the variable storing the calculated checksum*
* //Serial.println(" passed"); *
* //Serial.println();*
* if ( isMaster( readCard ) ) // Check to see if the card is the master programing card*
* programMode = true; // If so, enable programing mode*
* else*
* if ( findID(readCard) ) // If not, see if the card is in the EEPROM*
* openDoor(5); // If it is, open the door lock*
* else*
* failed(); // If not, show that the ID was not valid*
* else // If the checksum failed*
* { // Print out the checksum*
_ /_
_
Serial.println(" error");_
_
Serial.println();_
_
Serial.print("[");_
_
Serial.print(readCard[5], HEX);_
_
Serial.print("] != [");_
_
Serial.print(checksum, HEX);_
_
Serial.print("] ");_
_ /_
_
_
// If the serial port is ready and we received the STX BYTE (2) then this function is called
// to get the 4 BYTE ID + 1 BYTE checksum. The ID+checksum is stored in readCard[6]
// Bytes 0-4 are the 5 ID bytes, byte 5 is the checksum
void getID()
* byte bytesread = 0;*
* byte i = 0;*
* byte val = 0;*
* byte tempbyte = 0;*
* // 5 HEX Byte code is actually 10 ASCII Bytes.*
* while ( bytesread < 12 ) // Read 10 digit code + 2 digit checksum*
* if( Serial.available() > 0) // Check to make sure data is coming on the serial line*
* val = Serial.read(); // Store the current ASCII byte in val*
* if((val == 0x0D)||(val == 0x0A)||(val == 0x03)||(val == 0x02))*
* { // If header or stop bytes before the 10 digit reading*
* break; // Stop reading *
* if ( (val >= '0' ) && ( val <= '9' ) ) // Do Ascii/Hex conversion*
* val = val - '0';*
* else if ( ( val >= 'A' ) && ( val <= 'F' ) )*
* val = 10 + val - 'A';*
* if ( bytesread & 1 == 1 ) // Every two ASCII charactors = 1 BYTE in HEX format*
* // Make some space for this hex-digit by*
* // shifting the previous hex-digit with 4 bits to the left:*
* readCard[bytesread >> 1] = (val | (tempbyte << 4));*
* if ( bytesread >> 1 != 5 ) // If we're at the checksum byte,*
* checksum ^= readCard[bytesread >> 1]; // Calculate the checksum using XOR*
* else // If it is the first HEX charactor*
* tempbyte = val; // Store the HEX in a temp variable*
* bytesread++; // Increment the counter to keep track*
* bytesread = 0;*
// Read an ID from EEPROM and save it to the storedCard[6] array
void readID( int number ) // Number = position in EEPROM to get the 5 Bytes from
_ int start = (number * 5 ) - 4; // Figure out starting position_
* //Serial.print("Start: ");*
* //Serial.print(start);*
* //Serial.print("\n\n");*
* for ( int i = 0; i < 5; i++ ) // Loop 5 times to get the 5 Bytes*
_ storedCard = EEPROM.read(start+i); // Assign values read from EEPROM to array
Serial.print("Read [");
Serial.print(start+i);
Serial.print("] [");
Serial.print(storedCard, HEX);
Serial.print("] \n");
// Write an array to the EEPROM in the next available slot
void writeID( byte a[] )
* if ( !findID( a ) ) // Before we write to the EEPROM, check to see if we have seen this card before!
int num = EEPROM.read(0); // Get the number of used spaces, position 0 stores the number of ID cards*
Serial.print("Num: ");
Serial.print(num);
Serial.print(" \n");*
int start = ( num * 5 ) + 1; // Figure out where the next slot starts_
* num++; // Increment the counter by one*
* EEPROM.write( 0, num ); // Write the new count to the counter*
* for ( int j = 0; j < 5; j++ ) // Loop 5 times*
* EEPROM.write( start+j, a[j] ); // Write the array values to EEPROM in the right position*
_ /
Serial.print("W[");
Serial.print(start+j);
Serial.print("] Value [");
Serial.print(a[j], HEX);
* successWrite();
else*
failedWrite();
// Check two arrays of bytes to see if they are exact matches*
boolean checkTwo ( byte a[], byte b[] )
* if ( a[0] != NULL ) // Make sure there is something in the array first*
* match = true; // Assume they match at first*_
* for ( int k = 0; k < 5; k++ ) // Loop 5 times*
_ /
Serial.print("[");
Serial.print(k); Serial.print("] ReadCard [");
Serial.print(a[k], HEX);
Serial.print("] StoredCard [");
Serial.print(b[k], HEX);
if ( a[k] != b[k] ) // IF a != b then set match = false, one fails, all fail
* match = false;
if ( match ) // Check to see if if match is still true*
//Serial.print("Strings Match! \n");
return true; // Return true*
else {
//Serial.print("Strings do not match \n");
return false; // Return false*
// Looks in the EEPROM to try to match any of the EEPROM ID's with the passed ID*
boolean findID( byte find[] )
* int count = EEPROM.read(0); // Read the first Byte of EEPROM that*
// Serial.print("Count: "); // stores the number of ID's in EEPROM
// Serial.print(count);
* //Serial.print("\n");
for ( int i = 1; i <= count; i++ ) // Loop once for each EEPROM entry*
readID(i); // Read an ID from EEPROM, it is stored in storedCard[6]
if( checkTwo( find, storedCard ) ) *_
sorry...didn't post code properly.... what kinds of info would be helpful?
  1. A diagram or schematic of what hardware you have.
  2. A better description of exactly what is going wrong.
Parallax RFID reader 2400baud serial output to rx input of arduino duemilanove. leds connected to pins 10, 11, and 12. both the arduino and reader share common ground and i have powered them by usb and separatley with 5vdc supply.
I have 5 RFID tags that I am testing with. One is set as a master to allow adding cards and it is saved in eeprom. I have two cards saved to "give access" and the other two do not allow access. On inital power up, everything works fine. The cards when scanned give the proper result....go, or no-go. After a few reads though, I quit getting a response from the arduino unless I press the reset, or cycle the power. When I open the serial monitor, it always outputs the HEX data from the cards even if the arduino quits responding. I have checked and double checked everything and do not understand what could be causing the intermittent results.
I am assuming that the Parallax RFID reader does not output RS232 but actually outputs TTL.
This sounds like it is crashing possibly from lack of memory. You haven't posted all the code (maybe there is a limit on the site) but check for recursion. That is a function calling itself either directly or in a round about way. That means function 1 calls function 2 and then that function calls function 1.
you are right...all the code did not post. Yes, it is serial TTL 2400 baud.
