Arduino RTC modul with a motor problem
Hello, I have a little problem with this project. In the first case, it turns on exactly, but in the second case, it turns on with a delay, not at the set time.
#include <DS3231.h>
int Relay = 8;
DS3231  rtc(SDA, SCL);
Time t;
const int NumOfTimePoints = 3; // Number of time points managed
const int OnHours[NumOfTimePoints] = {14, 14, 14}; // Array of activation hours
const int OnMins[NumOfTimePoints] = {05, 06, 07}; // Array of activation minutes
const int OnSecs[NumOfTimePoints] = {0x00, 0x10, 0x20}; // Array of activation seconds
const int OffHours[NumOfTimePoints] = {14, 14, 14}; // Array of deactivation hours
const int OffMins[NumOfTimePoints] = {05, 06, 07}; // Array of deactivation minutes
const int OffSecs[NumOfTimePoints] = {0x05, 0x15, 0x25}; // Array of deactivation seconds
bool executed[NumOfTimePoints] = {false}; // Array indicating whether timed events have been executed
  rtc.begin();
  pinMode(Relay, OUTPUT);
  digitalWrite(Relay, LOW);
  t = rtc.getTime();
  Serial.print(t.hour);
  Serial.print(" hour(s), ");
  Serial.print(t.min);
  Serial.print(" minute(s)");
  Serial.print(t.sec);
  Serial.print(" second(s)");
  Serial.println(" ");
  delay (1000);
  for (int i = 0; i < NumOfTimePoints; i++) {
    if(t.hour == OnHours[i] && t.min == OnMins[i] && t.sec == OnSecs[i]){
      digitalWrite(Relay,HIGH);
      Serial.println("MOTOR ON");
      executed[i] = true; // Indicates that the event has been executed
    else if(t.hour == OffHours[i] && t.min == OffMins[i] && t.sec == OffSecs[i]){
      digitalWrite(Relay,LOW);
      Serial.println("MOTOR OFF");
You are doing this in a complicated way.
If you calculate secondsOfDay as
secondsOfDay = t.hour * 3600 + t.min * 60 + t.sec;
you simply compare the actual secondsOfDay with the point in time as
secondsOfDayOn
secondsOfDayOff
Agree.
And I'd like to note also that "executed[i]" is always set to "true"...
You are defining the seconds as hexadecimal numbers.
0x is the indicator for hexadecimal numbers
As the ontimes are pretty short just a few seconds is this for testing or for the real application?
Here is a code-version with secondsOfday
I do not have your DS3231.h-library and there is no comment saying which one of the dozens DS3231.h-libraries it is.
This means I can't compile your code
still here it is
#include <DS3231.h>
#include <time.h>
unsigned long MyTestTimer = 0;  // Timer-variables MUST be of type unsigned long
const byte    OnBoard_LED = 13; // onboard-LED uno, mega
const byte Relay_pin = 8;
DS3231  rtc (SDA, SCL);
Time t;
const byte NumOfTimePoints = 3;
const unsigned long OnSecsOfDay[NumOfTimePoints] = {
  (14UL * 3600 + 5 * 60 +  0),
  (14UL * 3600 + 6 * 60 + 10),
  (14UL * 3600 + 7 * 60 + 20)
const unsigned long OffSecsOfDay[NumOfTimePoints] = {
  (14UL * 3600 + 5 * 60 +  5),
  (14UL * 3600 + 6 * 60 + 15),
  (14UL * 3600 + 7 * 60 + 25)
unsigned long secondsOfDay;
bool executedOn[NumOfTimePoints]  = {false, false, false}; // Array indicating whether timed events have been executed
bool executedOff[NumOfTimePoints] = {false, false, false}; // Array indicating whether timed events have been executed
  Serial.println("Setup-Start");
  PrintFileNameDateTime();
  rtc.begin();
  digitalWrite(Relay_pin, LOW);
  pinMode(Relay_pin, OUTPUT);
  BlinkHeartBeatLED(OnBoard_LED, 250); // non-blocking blinking
  // non-blocking timing
  // check if 1000 milliseconds of time have passed by
  if ( TimePeriodIsOver(MyTestTimer, 1000) ) {
    // when REALLY 1000 milliseconds of time HAVE passed by
    // execute code below
    //t = rtc.getTime();
    t = rtc.getDateTime();
    secondsOfDay = t.hour * 3600UL + t.min * 60 + t.sec;
    // delay (1000); // no blocking delay needed
    if (secondsOfDay >= OnSecsOfDay[i] ) {
      digitalWrite(Relay_pin, HIGH);
      executedOn[i]  = true; // Indicates that the event has been executed
      executedOff[i] = false; // Indicates that the event has been executed
    if (secondsOfDay >= OffSecsOfDay[i] ) {
      executedOn[i]  = false; // Indicates that the event has been executed
      executedOff[i] = true; // Indicates that the event has been executed
// helper-functions
void PrintFileNameDateTime() {
  Serial.println( F("Code running comes from file ") );
  Serial.println( F(__FILE__) );
  Serial.print( F("  compiled ") );
  Serial.print( F(__DATE__) );
  Serial.print( F(" ") );
  Serial.println( F(__TIME__) );
// easy to use helper-function for non-blocking timing
// explanation see here
// https://forum.arduino.cc/t/example-code-for-timing-based-on-millis-easier-to-understand-through-the-use-of-example-numbers-avoiding-delay/974017
boolean TimePeriodIsOver (unsigned long &startOfPeriod, unsigned long TimePeriod) {
  unsigned long currentMillis  = millis();
  if ( currentMillis - startOfPeriod >= TimePeriod ) {
    // more time than TimePeriod has elapsed since last time if-condition was true
    startOfPeriod = currentMillis; // a new period starts right here so set new starttime
    return true;
  else return false;            // actual TimePeriod is NOT yet over
void BlinkHeartBeatLED(int IO_Pin, int BlinkPeriod) {
  static unsigned long MyBlinkTimer;
  pinMode(IO_Pin, OUTPUT);
  if ( TimePeriodIsOver(MyBlinkTimer, BlinkPeriod) ) {
    digitalWrite(IO_Pin, !digitalRead(IO_Pin) );
GitHub - rodan/ds3231: arduino library for DS3231 RTC
The program essence is a clock relay. I insert some hour when the motor turns on and turns off after a few seconds(for example 10 seconds).
I want 5 hour what can manage this program.
Not clear what you want to know.
The code uses SecondsOfDay
starting at 0:00 AM with SecondsOfDay = 0
ending at 23:59:59 ending with 23* 3600 + 59 * 60 + 59 = 86399 seconds and as the clock turns over to 0:00 AM SecondsOfDay becomes 0 again.
This means as long as switching on and switching off again is in the same day you can use any time and any time-intervall starting from 1 second up 86399 seconds and it will work
If you want switching on on
06th April 2024 01:00 AM and switching of 07th April 24 24 5 PM this is over midnight
which would require including the date
As unsigned longs can count up to 2^32-1 = 4.294.967.295
Let's say we use year 2000 as the reference-point in time
These are 8760 hours per year * 3600 seconds per hour * 24 years = 756.864.000 seconds fits easy into an unsigned long
4.294.967.295
  756.864.000
So adding anything below a year does not exceed the maximum-number
Now i understand the code, but have problem code.
Compilation error: exit status 1
Now i have this problem code, but when i write over this part
To this
    t = rtc.getTime();
    //t = rtc.getDateTime();
And I upload this, then the relay goes crazy and turns on and off several times in a second, you can say in a millisecond.
This is the code I mentioned above.
C:\Users\oxtro\OneDrive\Asztali gép\arduino\Lehel_motor\Lehel_motor.ino: In function 'void loop()':
C:\Users\oxtro\OneDrive\Asztali gép\arduino\Lehel_motor\Lehel_motor.ino:61:13: error: 'class DS3231' has no member named 'getDateTime'; did you mean 'getTime'?
exit status 1
Compilation error: 'class DS3231' has no member named 'getDateTime'; did you mean 'getTime'?
In file included from C:\Users\oxtro\OneDrive\Asztali gép\arduino\Lehel_motor\Lehel_motor.ino:1:0:
C:\Users\oxtro\OneDrive\Documents\Arduino\libraries\DS3231/DS3231.h:53:17: error: expected identifier before numeric constant
 #define SUNDAY  7
C:\Users\oxtro\OneDrive\Documents\Arduino\libraries\DS3231/DS3231.h:53:17: error: expected '}' before numeric constant
C:\Users\oxtro\OneDrive\Documents\Arduino\libraries\DS3231/DS3231.h:53:17: error: expected unqualified-id before numeric constant
In file included from C:\Users\oxtro\OneDrive\Asztali gép\arduino\Lehel_motor\Lehel_motor.ino:2:0:
c:\users\oxtro\appdata\local\arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7\avr\include\time.h:506:1: error: expected declaration before '}' token
exit status 1
Sorry for my bad english. And for my mistakes, i am new in the arduino world.
It is not the english. You have to provide detailed information.
as a general rule:
always post your complete sketch
FQBN: arduino:avr:uno
Using board 'uno' from platform in folder: C:\Users\oxtro\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6
Using core 'arduino' from platform in folder: C:\Users\oxtro\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6
Detecting libraries used...
C:\Users\oxtro\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Users\oxtro\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\oxtro\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\standard C:\Users\oxtro\AppData\Local\Temp\arduino\sketches\4BF59FFE07CD513D95B966F8A1870040\sketch\Lehel_motor2.ino.cpp -o nul
Alternatives for DS3231.h: [DS3231@1.1.2]
ResolveLibrary(DS3231.h)
  -> candidates: [DS3231@1.1.2]
C:\Users\oxtro\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Users\oxtro\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\oxtro\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\standard -IC:\Users\oxtro\OneDrive\Documents\Arduino\libraries\DS3231 C:\Users\oxtro\AppData\Local\Temp\arduino\sketches\4BF59FFE07CD513D95B966F8A1870040\sketch\Lehel_motor2.ino.cpp -o nul
C:\Users\oxtro\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Users\oxtro\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\oxtro\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\standard -IC:\Users\oxtro\OneDrive\Documents\Arduino\libraries\DS3231 C:\Users\oxtro\OneDrive\Documents\Arduino\libraries\DS3231\DS3231.cpp -o nul
Generating function prototypes...
C:\Users\oxtro\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Users\oxtro\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\oxtro\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\standard -IC:\Users\oxtro\OneDrive\Documents\Arduino\libraries\DS3231 C:\Users\oxtro\AppData\Local\Temp\arduino\sketches\4BF59FFE07CD513D95B966F8A1870040\sketch\Lehel_motor2.ino.cpp -o C:\Users\oxtro\AppData\Local\Temp\941950619\sketch_merged.cpp
C:\Users\oxtro\AppData\Local\Arduino15\packages\builtin\tools\ctags\5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives C:\Users\oxtro\AppData\Local\Temp\941950619\sketch_merged.cpp
Compiling sketch...
"C:\\Users\\oxtro\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\oxtro\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\oxtro\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Users\\oxtro\\OneDrive\\Documents\\Arduino\\libraries\\DS3231" "C:\\Users\\oxtro\\AppData\\Local\\Temp\\arduino\\sketches\\4BF59FFE07CD513D95B966F8A1870040\\sketch\\Lehel_motor2.ino.cpp" -o "C:\\Users\\oxtro\\AppData\\Local\\Temp\\arduino\\sketches\\4BF59FFE07CD513D95B966F8A1870040\\sketch\\Lehel_motor2.ino.cpp.o"
In file included from C:\Users\oxtro\OneDrive\Documents\Arduino\Lehel_motor2\Lehel_motor2.ino:1:0:
 #define SUNDAY  7
In file included from C:\Users\oxtro\OneDrive\Documents\Arduino\Lehel_motor2\Lehel_motor2.ino:2:0:
Using library DS3231 at version 1.1.2 in folder: C:\Users\oxtro\OneDrive\Documents\Arduino\libraries\DS3231
exit status 1
If you serach through the compiler-log for "
: error:"
in words double-point space "error" doublepoint
You find the lines that caused thecompiler-error.
In the log you hav posted this are the lines
#define SUNDAY 7
These are very unusual errors
I guess you try to use very old outdated / deprecated versions of the libraries named
DS3231.h
time.h
the compiler-log says you are using an Arduino Uno
Is this correct?
or
do you use a different microcontroller?
I repeat myself:
If you really want help.
Then write a detailed description in your motherlanguage and let do google-translate the translation.
It is REALLY IMPORTANT to have DETAILED information.
Such english like
Does say nothing what the problem is.
So please If you really want help.
I enter the given code
 #include <DS3231.h>
#include <time.h>
Time t;
  (11UL * 3600 + 2 * 60 +  0),
  (11UL * 3600 + 3 * 60 + 10),
  (11UL * 3600 + 4 * 60 + 20)
  (11UL * 3600 + 2 * 60 +  5),
  (11UL * 3600 + 3 * 60 + 15),
  (11UL * 3600 + 4 * 60 + 25)
  rtc.begin();
    t = rtc.getTime();
// helper-functions
    return true;
The program is now working, it also turns on at the first value
However, when it should be turned off, the relay starts clicking very quickly (turns on and off in milliseconds) and does not stop
The Serial monitor:
11 hour(s), 2 minute(s)57 second(s)
MOTOR OFF
MOTOR ON
MOTOR OFF
MOTOR ON
MOTOR OFF
MOTOR ON
MOTOR OFF
MOTOR OFF
MOTOR ON
MOTOR OFF
MOTOR ON
MOTOR OFF
MOTOR ON
MOTOR OFF
11 hour(s), 2 minute(s)58 second(s)
