Me and some friends are trying to make a segaway as a school projekt. However we got some problem while testing it, we only get one motor to work, the motor that are connected to m1 but we can't get the m2 terminal to work. Any ideas?
Products:
Motors - two 500 watt dc brushed, from a permobile
Arduino uno
Sabertooth 2x25 v2
Deadman switch
Two 12v 17ah lead-acid gel battery connected in series
Sabertooth simplified serial mode
Code:
#include <SoftwareSerial.h>
//Digital pin 13 is serial transmit pin to sabertooth
#define SABER_TX_PIN 13
//Not used but still initialised, Digital pin 12 is serial receive from Sabertooth
#define SABER_RX_PIN 12
//set baudrate to match sabertooth dip settings
#define SABER_BAUDRATE 9600
#define SABER_MOTOR1_FULL_FORWARD 127
#define SABER_MOTOR1_FULL_REVERSE 1
#define SABER_MOTOR2_FULL_FORWARD 255
#define SABER_MOTOR2_FULL_REVERSE 128
SoftwareSerial SaberSerial = SoftwareSerial (SABER_RX_PIN, SABER_TX_PIN );
void initSabertooth (void) {
//initialise software to communicate with sabertooth
pinMode ( SABER_TX_PIN, OUTPUT );
SaberSerial.begin( SABER_BAUDRATE );
//2 sec delay to let it settle
delay (2000);
float level = 0;
int u;
signed char Motor1percent;
signed char Motor2percent;
void setup() // run once, when the sketch starts
initSabertooth();
//analogINPUTS
void set_motor() {
unsigned char cSpeedVal_Motor1 = 0;
unsigned char cSpeedVal_Motor2 = 0;
Motor1percent = (signed char) level;
Motor2percent = (signed char) level;
Serial.print("level ");
Serial.println(level);
if (Motor1percent > 100) Motor1percent = 100;
if (Motor1percent < -100) Motor1percent = -100;
if (Motor2percent > 100) Motor2percent = 100;
if (Motor2percent < -100) Motor2percent = -100;
cSpeedVal_Motor1 = map (Motor1percent,
-100,
100,
SABER_MOTOR1_FULL_REVERSE,
SABER_MOTOR1_FULL_FORWARD);
cSpeedVal_Motor2 = map (Motor2percent,
-100,
100,
SABER_MOTOR2_FULL_REVERSE,
SABER_MOTOR2_FULL_FORWARD);
SaberSerial.print (cSpeedVal_Motor1, BYTE);
SaberSerial.print (cSpeedVal_Motor2, BYTE);
delay(5000);
void loop () {
level = 20;
set_motor();
} // end loop
