arduino + sensor shield + servo + atx power supply
hi arduino community,
I need advices about my wiring.
I have a duemilanove + sensor shield v4 + 4 digitals servos.
I'm wandering what i need for my power supply, because the internal amperage will not be sufficient.
I have an old atx power supply, that i can convert...
And I need informations about my general wiring (setup) for this kind of configuration.
Thank you very much for helping a new arduino afficionado.
merci,
Antoine
Some links to the hardware that you have would be a good idea.
Don't use the same color wire for everything.
If you have some specific questions, the answers might (OK, probably will ;)) be better.
Most ATX power supplies have minimum load specifications in order to have stable voltages. The supply I have sitting next to me needs .5a @ 3.3v, .3A @ 5v, and 2A @ 12V. That's about 20W just to provide stable power.
I managed to do this recently with 12 servo's
But i would strongly suggest not to use the sensor shield, the 5v paths on the board are way to thin for the ampere's your going to surge.
I made a shield myself with only the GRND connected to the arduino and thick threads to some female connectors that lead to the atx power supply.
For my first test i did use a sensor shield, and it smoked/burned the little paths on the board..
For the ATX supply i would suggest following this guide:
thank you cybertim,
I will follow your advices.
What do you think about the pololu micro servo controller :
is this will be a better solution ? and why?
thank you again,
antoine
