hy guys
I am working on an university project, and I'm looking for some guidance on a problem I am encountering. Basically, I am trying to read data via a receiver radio connected to an Arduino Mega. The data is being transmitted via a transmitter radio connected to my laptop.
The telemetry are synced (solid green light and same baud rate of 9600) and I know there is some communication. I used lcd to see what receiver get.
The setup is as follows: The transmitter radio is connected to my laptop via USB cable. There, I can use any serial port emulator to write data for transmitting. This works without any issue. On the other side, I have the receiver radio connected to my Arduino board. Radio RX and TX goes to Arduino RX and TX, respectively. If i use Serial0 it work but if i use Serial1 it not work anymore, however, as I transmit data via the transmitter, the receiver does not respond. Thus, the output from the Arduino is always -1.
Here is the code I'm using or the receiver radio:
#include <LiquidCrystal.h>
#include <SoftwareSerial.h>
//SoftwareSerial ss(1, 0);
String inputString = ""; // a string to hold incoming data
boolean stringComplete = false; // whether the string is complete
String commandString = "";
int led1Pin = 19;
int led2Pin = 20;
int led3Pin = 21;
boolean isConnected = false;
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
Serial1.begin(57600);
pinMode(led1Pin,OUTPUT);
pinMode(led2Pin,OUTPUT);
pinMode(led3Pin,OUTPUT);
initDisplay();
Serial1.print(random(0,100));
if(stringComplete)
getCommand();
if(commandString.equals("STAR"))
lcd.clear();
if(commandString.equals("STOP"))
turnLedOff(led1Pin);
turnLedOff(led2Pin);
turnLedOff(led3Pin);
lcd.clear();
lcd.print("Ready to connect");
else if(commandString.equals("TEXT"))
String text = getTextToPrint();
printText(text);
else if(commandString.equals("LED1"))
boolean LedState = getLedState();
if(LedState == true)
turnLedOn(led1Pin);
}else
else if(commandString.equals("LED2"))
turnLedOn(led2Pin);
}else
else if(commandString.equals("LED3"))
turnLedOn(led3Pin);
}else
inputString = "";
void initDisplay()
lcd.begin(16, 2);
boolean getLedState()
boolean state = false;
if(inputString.substring(5,7).equals("ON"))
state = true;
}else
state = false;
return state;
void getCommand()
if(inputString.length()>0)
commandString = inputString.substring(1,5);
void turnLedOn(int pin)
digitalWrite(pin,HIGH);
void turnLedOff(int pin)
digitalWrite(pin,LOW);
String getTextToPrint()
String value = inputString.substring(5,inputString.length()-2);
return value;
void printText(String text)
lcd.clear();
lcd.setCursor(0,0);
if(text.length()<16)
lcd.print(text);
}else
lcd.print(text.substring(0,16));
lcd.setCursor(0,1);
lcd.print(text.substring(16,32));
void serialEvent() {
while (Serial1.available()) {
// get the new byte:
char inChar = (char)Serial1.read();
// add it to the inputString:
inputString += inChar;
// if the incoming character is a newline, set a flag
// so the main loop can do something about it:
if (inChar == '\n') {
stringComplete = true;
Plis Help Me !!
