Arduino Solenoid Door lock system using fingerprint and keypad and LCD-I2C besides using GSM (Sim800L)
The project is about a smart solenoid door lock that open with password or fingerprint sensor, and there is an LCD screen that shows the login status, besides if there 3 unsuccessful attempts an sms message send
I wrote this code but unfortunatly it doesn't work
Can any body help me
I am using Arduino Uno
This is the code:
#include <SoftwareSerial.h>
#include <Adafruit_Fingerprint.h>
#include <Keypad.h>
#define FINGERPRINT_RX 0
#define FINGERPRINT_TX 1
#define GSM_RX 2
#define GSM_TX 3
#define Relay_Pin 5
#define MAX_ATTEMPTS 3
SoftwareSerial gsmSerial(GSM_RX, GSM_TX);
Adafruit_Fingerprint finger = Adafruit_Fingerprint(&Serial);
const byte ROWS = 4;
const byte COLS = 4;
char keys[ROWS][COLS] = {
  {'1', '2', '3', 'A'},
  {'4', '5', '6', 'B'},
  {'7', '8', '9', 'C'},
  {'*', '0', '#', 'D'}
byte rowPins[ROWS] = {6,7,8,9};
byte colPins[COLS] = {10,11,12,13};
Keypad keypad = Keypad(makeKeymap(keys), rowPins, colPins, ROWS, COLS);
LiquidCrystal_I2C lcd(0x27, 16, 2);
int attempts = 0;
  gsmSerial.begin(9600);
  finger.begin(57600);
  pinMode(Relay_Pin, OUTPUT);
  lcd.init();
  lcd.backlight();
  lcd.print("Enter your fingerprint");
  char key = keypad.getKey();
  if (key != NO_KEY) {
    lcd.clear();
    lcd.print("Enter password");
    char password[4];
    for (int i = 0; i < 4; i++) {
      password[i] = keypad.getKey();
      lcd.setCursor(i, 1);
      lcd.print("*");
    if (checkPassword(password)) {
      unlockDoor();
      lcd.clear();
      lcd.print("Access granted");
      delay(5000);
      lcd.clear();
      lcd.print("Enter fingerprint");
      attempts = 0;
      attempts++;
      lcd.clear();
      lcd.print("Access denied");
      delay(5000);
      lcd.clear();
      if (attempts == MAX_ATTEMPTS) {
        sendNotification();
        attempts = 0;
  if (finger.getImage() == FINGERPRINT_OK) {
    int id = finger.fingerFastSearch();
    if (id == -1) {
      lcd.clear();
      delay(5000);
      lcd.clear();
      attempts++;
        sendNotification();
        attempts = 0;
      unlockDoor();
      lcd.clear();
      delay(5000);
      lcd.clear();
      attempts = 0;
bool checkPassword(char* password) {
  // Check if the password is valid
  // Return true if the password is valid, false otherwise
  char correctPassword[4] = {'1', '2', '3', '4'}; // Change this to the correct password
    if (password[i] != correctPassword[i]) {
      return false;
  return true;
void unlockDoor() {
  digitalWrite(Relay_Pin, HIGH);
  delay(5000);
  digitalWrite(Relay_Pin, LOW);
void sendNotification() {
  gsmSerial.println("AT+CMGF=1");
  gsmSerial.println("AT+CMGS=\"+966508637808\"");
  gsmSerial.println("Unauthorized access detected!");
  gsmSerial.write(0x1A);
you have 2 devices but trying to activate three Serials
what happen if keys not pressed quick enough ?
what happen if keys is pressed while delay() is active?
Can you edit the code to do the wanted function, i am new at programming so you will find many mistakes.
show schematic
really ? you wrote it?
Ok i will do it and send it
Yes, with the help of AI
ah, well, it is explain many things
f.e. :
if someone interested my thoughts about ChatGPT sketches:
ChatGPT is not responsible for its results so you must be clever then it to find it's errors, but if you are so clever - you do not need ChatGPT at all. using of ChatGPT is like declaring self to incompetent/incapable. but if you consider yourself to be such, then it may be better to spend your life on something more attractive.
