Arduino_SSD1306_OLED
Hi all, When compiling (Win11) (ESP32) I get:
Documents\Arduino\libraries\Arduino_SSD1306_OLED: invalid library: no header files found.
I tried to fin the ".h" but could not. I have the lib (Arduino_SSD1306_OLED)installed but when I look in it, no ".h" I tried removing Arduino_SSD1306_OLED and re-installing it but...same error.
Does anyone know hot to fix this?
Thanks.
Hi Greg,
the way to fix this is to analyse your compiling process:
  • set the compile-log to verbose to print all details available
  • as a code-section: posting the compiler-log as a code-section
tutorial to adjust compiler-log
how to post content into a code-section
To check if the library has been really installed.
Install the file-search tool everything from voidtools
https://www.voidtools.com/
Do a search for the filename without ".h"
best regards Stefan
tvoid setup() {
type or paste code here
Above is my code...blank.
I'm using ESP32 DevkitII on a Win 11 Computer With Arduino IDE V2.1.1
Below is the error code:
FQBN: esp32:esp32:esp32doit-devkit-v1
Using board 'esp32doit-devkit-v1' from platform in folder: C:\Users\greg\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.11
Using core 'esp32' from platform in folder: C:\Users\greg\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.11
loading library from c:\Users\greg\Documents\Arduino\libraries\Arduino_SSD1306_OLED: invalid library: no header files found
cmd /c if exist "C:\Users\greg\AppData\Local\Temp\.arduinoIDE-unsaved202376-32188-r8o1yb.mh9fq\sketch_aug6a\partitions.csv" COPY /y "C:\Users\greg\AppData\Local\Temp\.arduinoIDE-unsaved202376-32188-r8o1yb.mh9fq\sketch_aug6a\partitions.csv" "C:\Users\greg\AppData\Local\Temp\arduino\sketches\C92CEAC6DB33728142C0AEE4486553CA\partitions.csv"
cmd /c if not exist "C:\Users\greg\AppData\Local\Temp\arduino\sketches\C92CEAC6DB33728142C0AEE4486553CA\partitions.csv" if exist "C:\Users\greg\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.11\variants\doitESP32devkitV1\partitions.csv" COPY "C:\Users\greg\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.11\variants\doitESP32devkitV1\partitions.csv" "C:\Users\greg\AppData\Local\Temp\arduino\sketches\C92CEAC6DB33728142C0AEE4486553CA\partitions.csv"
cmd /c if not exist "C:\Users\greg\AppData\Local\Temp\arduino\sketches\C92CEAC6DB33728142C0AEE4486553CA\partitions.csv" COPY "C:\Users\greg\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.11\tools\partitions\default.csv" "C:\Users\greg\AppData\Local\Temp\arduino\sketches\C92CEAC6DB33728142C0AEE4486553CA\partitions.csv"
1 file(s) copied.
I tried everything I know to trace down the error to no avail.
I remover the IDE and reinstalled it, ..no help.
I reinstalled the library no help.
I'm at a dead end.
The compiler-log you have posted is a short version that clearly indicates that you have not adjusted the compiler-log to verbose output
what is so hard about clicking on
file - preferences
and then to change the compiler-log-options like described in this tutorial
Do I have to copy and paste the screens shots in your thread or are you able to click on the link and and read the tutorial?
Where did you get the library from?
The github page I'm looking at for Arduino_SSD1306_OLED is not a library, but some demonstration sketches for directly driving the display without a library.
The compiler-log to verbose output WAS checked.
Thanks
I don't know where it came from.
Adafruit has good libraries for that display. Try their examples.
Are you saying that you still get the error if you completely delete the Arduino_SSD1306_OLED library?
You are working on an informatic project. And what is most needed in an informatic project is guess what?: information
You should post your complete sketch. You did it yet not.
So I took a very very short sketch trying to simulate your situation by assumings.
I took this sketch
#include <Arduino_SSD1306_OLED.h>
   Serial.println("Setup-Start");
and let it compile
The compiler-log looks like this
Using board 'esp32' from platform in folder: C:\Users\dipl-\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.9
Using core 'esp32' from platform in folder: C:\Users\dipl-\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.9
cmd /c if exist "F:\\myData\\Arduino\\tpc\\partitions.csv" COPY /y "F:\\myData\\Arduino\\tpc\\partitions.csv" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino\\sketches\\54FDAE9E2D78DCD1B6BC3C8809B4834E\\partitions.csv"
cmd /c if not exist "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino\\sketches\\54FDAE9E2D78DCD1B6BC3C8809B4834E\\partitions.csv" if exist "C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9\\variants\\esp32\\partitions.csv" COPY "C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9\\variants\\esp32\\partitions.csv" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino\\sketches\\54FDAE9E2D78DCD1B6BC3C8809B4834E\\partitions.csv"
cmd /c if not exist "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino\\sketches\\54FDAE9E2D78DCD1B6BC3C8809B4834E\\partitions.csv" COPY "C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9\\tools\\partitions\\default.csv" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino\\sketches\\54FDAE9E2D78DCD1B6BC3C8809B4834E\\partitions.csv"
cmd /c IF EXIST "F:\\myData\\Arduino\\tpc\\bootloader.bin" ( COPY /y "F:\\myData\\Arduino\\tpc\\bootloader.bin" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino\\sketches\\54FDAE9E2D78DCD1B6BC3C8809B4834E\\tpc.ino.bootloader.bin" ) ELSE ( IF EXIST "C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9\\variants\\esp32\\bootloader.bin" ( COPY "C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9\\variants\\esp32\\bootloader.bin" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino\\sketches\\54FDAE9E2D78DCD1B6BC3C8809B4834E\\tpc.ino.bootloader.bin" ) ELSE ( "C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esptool_py\\4.5.1/esptool.exe" --chip esp32 elf2image --flash_mode dio --flash_freq 80m --flash_size 4MB -o "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino\\sketches\\54FDAE9E2D78DCD1B6BC3C8809B4834E\\tpc.ino.bootloader.bin" "C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9\\tools\\sdk\\esp32\\bin\\bootloader_qio_80m.elf" ) )
esptool.py v4.5.1
Creating esp32 image...
Merged 1 ELF section
Successfully created esp32 image.
cmd /c if exist "F:\\myData\\Arduino\\tpc\\build_opt.h" COPY /y "F:\\myData\\Arduino\\tpc\\build_opt.h" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino\\sketches\\54FDAE9E2D78DCD1B6BC3C8809B4834E\\build_opt.h"
cmd /c if not exist "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino\\sketches\\54FDAE9E2D78DCD1B6BC3C8809B4834E\\build_opt.h" type nul > "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino\\sketches\\54FDAE9E2D78DCD1B6BC3C8809B4834E\\build_opt.h"
Detecting libraries used...
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\esp-2021r2-patch5-8.4.0/bin/xtensa-esp32-elf-g++" -DHAVE_CONFIG_H "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE "-DIDF_VER=\"v4.4.4\"" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/newlib/platform_include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/freertos/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/freertos/include/esp_additions/freertos" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/freertos/port/xtensa/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/freertos/include/esp_additions" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_hw_support/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_hw_support/include/soc" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_hw_support/include/soc/esp32" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_hw_support/port/esp32" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_hw_support/port/esp32/private_include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/heap/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/log/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/lwip/include/apps" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/lwip/include/apps/sntp" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/lwip/lwip/src/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/lwip/port/esp32/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/lwip/port/esp32/include/arch" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/soc/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/soc/esp32" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/soc/esp32/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/hal/esp32/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/hal/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/hal/platform_port/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_rom/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_rom/include/esp32" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_rom/esp32" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_common/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_system/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_system/port/soc" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_system/port/public_compat" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp32/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/xtensa/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/xtensa/esp32/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/driver/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/driver/esp32/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_pm/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_ringbuf/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/efuse/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/efuse/esp32/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/vfs/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_wifi/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_event/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_netif/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_eth/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/tcpip_adapter/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_phy/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_phy/esp32/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_ipc/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/app_trace/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_timer/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/mbedtls/port/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/mbedtls/mbedtls/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/mbedtls/esp_crt_bundle/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/app_update/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/spi_flash/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/bootloader_support/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/nvs_flash/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/pthread/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_gdbstub/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_gdbstub/xtensa" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_gdbstub/esp32" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espcoredump/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espcoredump/include/port/xtensa" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/wpa_supplicant/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/wpa_supplicant/port/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/wpa_supplicant/esp_supplicant/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/ieee802154/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/console" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/asio/asio/asio/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/asio/port/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/bt/common/osi/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/bt/include/esp32/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/bt/common/api/include/api" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/bt/common/btc/profile/esp/blufi/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/bt/common/btc/profile/esp/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/bt/host/bluedroid/api/include/api" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/tinycrypt/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/storage" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/bt/esp_ble_mesh/btc/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/common/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/client/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/server/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/bt/esp_ble_mesh/api/core/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/bt/esp_ble_mesh/api/models/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/bt/esp_ble_mesh/api" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/cbor/port/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/unity/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/unity/unity/src" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/cmock/CMock/src" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/coap/port/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/coap/libcoap/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/nghttp/port/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/nghttp/nghttp2/lib/includes" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp-tls" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp-tls/esp-tls-crypto" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_adc_cal/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_hid/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/tcp_transport/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_http_client/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_http_server/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_https_ota/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_https_server/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_lcd/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_lcd/interface" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/protobuf-c/protobuf-c" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/protocomm/include/common" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/protocomm/include/security" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/protocomm/include/transports" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/mdns/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_local_ctrl/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/sdmmc/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_serial_slave_link/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_websocket_client/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/expat/expat/expat/lib" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/expat/port/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/wear_levelling/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/fatfs/diskio" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/fatfs/vfs" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/fatfs/src" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/freemodbus/freemodbus/common/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/idf_test/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/idf_test/include/esp32" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/jsmn/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/json/cJSON" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/libsodium/libsodium/src/libsodium/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/libsodium/port_include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/mqtt/esp-mqtt/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/openssl/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/perfmon/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/spiffs/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/ulp/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/wifi_provisioning/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/rmaker_common/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_diagnostics/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/rtc_store/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_insights/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/json_parser/upstream/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/json_parser/upstream" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/json_generator/upstream" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_schedule/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp_secure_cert_mgr/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_rainmaker/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/gpio_button/button/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/qrcode/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/ws2812_led" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_littlefs/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp-dl/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp-dl/include/tool" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp-dl/include/typedef" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp-dl/include/image" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp-dl/include/math" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp-dl/include/nn" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp-dl/include/layer" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp-dl/include/detect" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp-dl/include/model_zoo" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp-sr/src/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp-sr/esp-tts/esp_tts_chinese/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp-sr/include/esp32" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp32-camera/driver/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp32-camera/conversions/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/dotprod/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/support/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/hann/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman_harris/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman_nuttall/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/nuttall/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/flat_top/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/iir/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/fir/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/add/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sub/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mul/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/addc/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mulc/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sqrt/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/fft/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/dct/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/conv/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/common/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf_imu13states/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/fb_gfx/include" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/qio_qspi/include" -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -c -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_default -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino\\sketches\\54FDAE9E2D78DCD1B6BC3C8809B4834E/build_opt.h" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9\\cores\\esp32" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9\\variants\\esp32" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino\\sketches\\54FDAE9E2D78DCD1B6BC3C8809B4834E\\sketch\\tpc.ino.cpp" -o nul
Alternatives for Arduino_SSD1306_OLED.h: []
ResolveLibrary(Arduino_SSD1306_OLED.h)
  -> candidates: []
F:\myData\Arduino\tpc\tpc.ino:1:10: fatal error: Arduino_SSD1306_OLED.h: No such file or directory
compilation terminated.
exit status 1
Compilation error: Arduino_SSD1306_OLED.h: No such file or directory
especcially the last lines
exit status 1
are missing in your posting
The characters that you have posted from your compiler-log are this
1 file(s) copied.
last lines are these
1 file(s) copied.
So the minimum you can do is clicking this button
or if you use the IDE 1.8.19
Which will copy the complete log
The part of the log that you have posted is missing lines inbetween.
This is very strange.
I will post here a screenshot and two code sections to make the difference easier to see
How did you manage to not copy all the lines of the compiler-log???
You should start the compiling new and then use the copy error-message button
You should post your complete sketch. From the very first line to the very last line
best regards Stefan
Yes, I do.
I did solve this problem by deleting ALL references to Arduino IDE on my computer and then reinstalling the IDE.
No more problems. The whole thing took about 10 minutes.
Go figure.
Thanks for the help.
I'm not sure what you mean with "all references to Arduino-IDE".
system-environment variables?
deleting all Arduino-IDE related files?
all arduino-IDE related registry entries?
Did you do it manually?
Did you restore to an older windows-restore-point?
best regards Stefan
To remove all traces of Arduino 2.0 IDE from your computer, you need to follow these steps:
