I just noticed this SSR that was for DCV instead of all the others that are normally for AC.
Although I can not find the datasheet for it, it does seem compatible with Arduino. http://www.ebay.com/itm/251138639900 auction site and also SainSmart 2 Channel SSR-2F Solid State Relay 3V-32V 5A For AVR DSP Arduino Mega Uno R3 – SainSmart.com is where I found it.
However, I am just wanting to double check 2 things here:
- My thoughts on how to go about wiring it:
I have 2 scenarios here. One that runs 12V out and another that does ground. Is this SSR capable of doing the 0vdc out since I am seeing the output is 5V-220V DC? I'm using the 0V DC to "push" a button (pushing = grounding it) so that the object it's connected to turns on or off.
- I gather that when I send 5V DC to the SSR (via Digital Pin 1 or 2) it will open up the line for the 12V/0V to flow out the negative (-) side? Not sure if these are NO or NC? And as a side note, the diagram in the picture and the label on the SSR itself seems to be backwords? It says +/- and +/- while the diagram says -/+ and -/+?
Addition:
This image shows that they have some resisters in place:
Can anyone tell by those images above what type of resister they are using? Seems to me they are dropping the voltage by that on the arduino board side?
