I want to make a digital clock with RTC and LCD. It works but when I disconnect it from the computer ıt doesn't works. A 4.5 volt power supply is connected to the Arduino. LCD's light is on but code doesn't works.
#include <virtuabotixRTC.h>
#include <LiquidCrystal.h>
int CLK_PIN = 6;
int DAT_PIN = 7;
int RST_PIN = 8;
virtuabotixRTC myRTC(CLK_PIN, DAT_PIN, RST_PIN);
int rs = 12, en = 11, d4 = 5, d5 = 4, d6 = 3, d7 = 2;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
lcd.begin(16, 2);
pinMode(10,HIGH);
analogWrite(10,900);
myRTC.updateTime();okuyoruz
lcd.clear();
lcd.setCursor(0, 0);
lcd.print(myRTC.dayofmonth);
lcd.print("/");
lcd.print(myRTC.month);
lcd.print("/");
lcd.print(myRTC.year);
lcd.setCursor(0, 1);
lcd.print(myRTC.hours); /
lcd.print(":");
lcd.print(myRTC.minutes);
lcd.print(":");
lcd.print(myRTC.seconds);
That is my code.
The posted code has several errors. Please post code that compiles and runs.
Also, post a wiring diagram (hand drawn is fine).
Vin must be between 7V and 12V
I will try it.
Vin must be 7V or greater.
You could try connecting 4.5V to the 5V pin (which won't damage the Arduino, if it is not connected to the PC), but fix the errors in the code first.
6 AA batteries would be good. A 9V battery would be OK but it may only last a few hours
A 5V power bank connected to the USB connector would also work
