Arduino SWC Interface Troubleshooting
Hi, installed a arduino uno with a mcp 2512 in my car. Using it to control extra functions the canbus line. Now I want to control my aftermarket stereo from the steering wheel buttons, using a kenwood stereo. I had successful write the code so a button push get registered in arduino ide terminal log, but I now want to take it longer and send the commands to my stereo.
Analysed the signals from my old SWC interface with a oscilloscope, verified the signals I snapped up with from a website I found and build a separately test arduino with basic "volume up" code. Using a uno and a n24401 transistor to this. But no success and when compared the signals from my test unit with the right signals something get corrupt.
Test code
  pinMode(3, OUTPUT);
  digitalWrite(3, HIGH);
  delay(9);
  digitalWrite(3, LOW);
  delay(4.5);
  //1
  delayMicroseconds(562.5);
  delay(1.6875);
  delay(1.6875);
  delay(1.6875);
  delay(1.6875);
  delay(1.6875);
  //1
  //2
  delay(1.6875);
  delay(1.6875);
  delay(1.6875);
  //2
  //3
  delay(1.6875);
  delay(1.6875);
  //3
  //4
  delay(1.6875);
  delay(1.6875);
  delay(1.6875);
  delay(1.6875);
  delay(1.6875);
  delay(1.6875);
  //4
  delay(2000);
Many hours I had spent to reading, reading, more reading and some tests but im stuck. Some one who can help me fix this. My old SWC interface is crap and why don't make a better version with arduino, it already installed and all I need is a extra cable and some extra code.
Past in my originally code I already using below here, the code I want to put this function in to. Hope I write this right and in right category, im not good neither to write code or english.
Thanks :smiley:
Setup part code
//Taklucka
//I-Bus
#include <mcp_can.h>
#include <SPI.h>
long unsigned int rxId;
unsigned char len = 0;
unsigned char rxBuf[8];
//SID - BEEP//
//const byte Pattern5[] = {0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00}; //
//const byte Pattern6[] = {0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00}; //
const byte Pattern7[] = { 0x80, 0x04, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 };  //Sid High Beep
//SPA//
const byte Pattern1[] = { 0x80, 0x00, 0x43, 0x00, 0x00, 0x00, 0x00, 0x00 };  //SPA Dist
const byte Pattern2[] = { 0x00, 0x00, 0x43, 0x00, 0x00, 0x00, 0x00, 0x00 };  //SPA Dist
const byte Pattern3[] = { 0x80, 0x00, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00 };  //SPA Dist
const byte Pattern4[] = { 0x00, 0x00, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00 };  //SPA Dist
const byte Pattern8[] = { 0x80, 0x00, 0x50, 0x00, 0x00, 0x00, 0x00, 0x00 };   //SPA Dist
const byte Pattern9[] = { 0x00, 0x00, 0x50, 0x00, 0x00, 0x00, 0x00, 0x00 };   //SPA Dist
const byte Pattern10[] = { 0x80, 0x00, 0x49, 0x00, 0x00, 0x00, 0x00, 0x00 };  //SPA Dist
const byte Pattern11[] = { 0x00, 0x00, 0x49, 0x00, 0x00, 0x00, 0x00, 0x00 };  //SPA Dist
const byte Pattern12[] = { 0x80, 0x00, 0x47, 0x00, 0x00, 0x00, 0x00, 0x00 };  //SPA Dist
const byte Pattern13[] = { 0x00, 0x00, 0x47, 0x00, 0x00, 0x00, 0x00, 0x00 };  //SPA Dist
const byte Pattern14[] = { 0x80, 0x00, 0x46, 0x00, 0x00, 0x00, 0x00, 0x00 };  //SPA Dist
const byte Pattern15[] = { 0x00, 0x00, 0x46, 0x00, 0x00, 0x00, 0x00, 0x00 };  //SPA Dist
const byte Pattern16[] = { 0x80, 0x00, 0x44, 0x00, 0x00, 0x00, 0x00, 0x00 };  //SPA Dist
const byte Pattern17[] = { 0x00, 0x00, 0x44, 0x00, 0x00, 0x00, 0x00, 0x00 };  //SPA Dist
const byte Pattern18[] = { 0x00, 0x00, 0x58, 0x00, 0x00, 0x00, 0x00, 0x00 };  //SPA Dist
//STEREO - NORMAL MODE//
const byte Pattern19[] = { 0x80, 0x00, 0x80, 0x00, 0x80, 0x00, 0x00, 0x00 };  //vol down
const byte Pattern20[] = { 0x80, 0x00, 0x40, 0x00, 0x40, 0x00, 0x00, 0x00 };  //vol up
const byte Pattern21[] = { 0x80, 0x00, 0x20, 0x00, 0x20, 0x00, 0x00, 0x00 };  //src
const byte Pattern22[] = { 0x80, 0x00, 0x08, 0x00, 0x08, 0x00, 0x00, 0x00 };  //track back
const byte Pattern23[] = { 0x80, 0x00, 0x10, 0x00, 0x10, 0x00, 0x00, 0x00 };  //track next
const byte Pattern24[] = { 0x80, 0x00, 0x04, 0x00, 0x04, 0x00, 0x00, 0x00 };  //nxt
const byte Pattern25[] = { 0x00, 0x00, 0x00, 0x00, 0x80, 0x00, 0x00, 0x00 };  //LONG vol down
const byte Pattern26[] = { 0x00, 0x00, 0x00, 0x00, 0x40, 0x00, 0x00, 0x00 };  //LONG vol up
const byte Pattern27[] = { 0x00, 0x00, 0x00, 0x00, 0x20, 0x00, 0x00, 0x00 };  //LONG src
const byte Pattern28[] = { 0x00, 0x00, 0x00, 0x00, 0x08, 0x00, 0x00, 0x00 };  //LONG track back
const byte Pattern29[] = { 0x00, 0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00 };  //LONG track next
const byte Pattern30[] = { 0x00, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00 };  //LONG nxt
//STEREO - STANDBY MODE//
const byte Pattern31[] = { 0xB0, 0x00, 0x80, 0x00, 0x80, 0x00, 0x00, 0x00 };  //vol down
const byte Pattern32[] = { 0xB0, 0x00, 0x40, 0x00, 0x40, 0x00, 0x00, 0x00 };  //vol up
const byte Pattern33[] = { 0xB0, 0x00, 0x20, 0x00, 0x20, 0x00, 0x00, 0x00 };  //src
const byte Pattern34[] = { 0xB0, 0x00, 0x08, 0x00, 0x08, 0x00, 0x00, 0x00 };  //track back
const byte Pattern35[] = { 0xB0, 0x00, 0x10, 0x00, 0x10, 0x00, 0x00, 0x00 };  //track next
const byte Pattern36[] = { 0xB0, 0x00, 0x04, 0x00, 0x04, 0x00, 0x00, 0x00 };  //nxt
const byte Pattern37[] = { 0x30, 0x00, 0x00, 0x00, 0x80, 0x00, 0x00, 0x00 };  //LONG vol down
const byte Pattern38[] = { 0x30, 0x00, 0x00, 0x00, 0x40, 0x00, 0x00, 0x00 };  //LONG vol up
const byte Pattern39[] = { 0x30, 0x00, 0x00, 0x00, 0x20, 0x00, 0x00, 0x00 };  //LONG src
const byte Pattern40[] = { 0x30, 0x00, 0x00, 0x00, 0x08, 0x00, 0x00, 0x00 };  //LONG track back
const byte Pattern41[] = { 0x30, 0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00 };  //LONG track next
const byte Pattern42[] = { 0x30, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00 };  //LONG nxt
MCP_CAN CAN0(10);  // Set CS to pin 10
//Blinkers
//Oljevarnare
//Backvarnare
int beep = 8;
//Stereo
  //Taklucka
  Serial.println("Push Button Counter");
  pinMode(lock, INPUT);
  pinMode(alock, INPUT);
  pinMode(unlock, INPUT);
  pinMode(aunlock, INPUT);
  pinMode(unlock_output, OUTPUT);
  pinMode(lock_output, OUTPUT);
  pinMode(fuel_in, INPUT);
  pinMode(fuel_out, OUTPUT);
  pinMode(relay_fuel, OUTPUT);
  pinMode(LED_BUILTIN, OUTPUT);
  //I-Bus
  if (CAN0.begin(MCP_STDEXT, CAN_47KBPS, MCP_8MHZ) == CAN_OK) Serial.print("MCP2515 Init Okay!!\r\n");
  else Serial.print("MCP2515 Init Failed!!\r\n");
  pinMode(2, INPUT);  // Setting pin 2 for /INT input
  CAN0.init_Mask(4, 0, 0x07FFFF00);
  CAN0.init_Filt(4, 0, 0x02908000);
  CAN0.init_Mask(5, 0, 0x07FFFF00);
  CAN0.init_Filt(5, 0, 0x02908000);
  CAN0.init_Mask(2, 0, 0x07FFFF00);
  CAN0.init_Filt(2, 0, 0x04390000);
  CAN0.init_Mask(3, 0, 0x07FFFF00);
  CAN0.init_Filt(3, 0, 0x04390000);
  CAN0.init_Mask(0, 0, 0x07F00000);
  CAN0.init_Filt(0, 0, 0x04330000);
  CAN0.init_Mask(1, 0, 0x07F00000);
  CAN0.init_Filt(1, 0, 0x04330000);
  Serial.println("MCP2515 Library Mask & Filter Example...");
  CAN0.setMode(MCP_NORMAL);
  //Blinkers
  //Oljevarnare
  //Backvarnare
  pinMode(beep, OUTPUT);
  //Stereo
  // loop_blinkers();
  loop_taklucka();
  loop_stereo();
  //loop_ibus();
  //loop_oljevarnare();
  loop_backvarnare();
  loop_bensinvarmare();
Stereo SWC part code
void loop_stereo() {
  CAN0.readMsgBuf(&rxId, &len, rxBuf);  // Read data: len = data length, buf = data byte(s)
  if (len == sizeof Pattern19 && memcmp(Pattern19, rxBuf, len) == 0) {
    // Matches patern
    Serial.print("vol down");
    Serial.print(" ");
    digitalWrite(5, 50);
    delay(50);
    digitalWrite(5, 0);
    delay(250);
  if (len == sizeof Pattern20 && memcmp(Pattern20, rxBuf, len) == 0) {
    // Matches patern
    Serial.print("Vol up");
    Serial.print(" ");
    digitalWrite(5, 100);
    delay(50);
    digitalWrite(5, 0);
    delay(250);
  if (len == sizeof Pattern21 && memcmp(Pattern21, rxBuf, len) == 0) {
    // Matches patern
    Serial.print("src");
    Serial.print(" ");
    digitalWrite(5, 125);
    delay(50);
    digitalWrite(5, 0);
    delay(250);
  if (len == sizeof Pattern22 && memcmp(Pattern22, rxBuf, len) == 0) {
    // Matches patern
    Serial.print("track back");
    Serial.print(" ");
    digitalWrite(5, 150);
    delay(50);
    digitalWrite(5, 0);
    delay(250);
  if (len == sizeof Pattern23 && memcmp(Pattern23, rxBuf, len) == 0) {
    // Matches patern
    Serial.print("track next");
    Serial.print(" ");
    digitalWrite(5, 175);
    delay(50);
    digitalWrite(5, 0);
    delay(250);
  if (len == sizeof Pattern24 && memcmp(Pattern24, rxBuf, len) == 0) {
    // Matches patern
    Serial.print("nxt");
    Serial.print(" ");
    digitalWrite(5, 200);
    delay(50);
    digitalWrite(5, 0);
    delay(250);
  if (len == sizeof Pattern25 && memcmp(Pattern25, rxBuf, len) == 0) {
    // Matches patern
    Serial.print("vol down_long");
    Serial.print(" ");
    delay(100);
  if (len == sizeof Pattern26 && memcmp(Pattern26, rxBuf, len) == 0) {
    // Matches patern
    Serial.print("Vol up_long");
    Serial.print(" ");
    delay(100);
  if (len == sizeof Pattern27 && memcmp(Pattern27, rxBuf, len) == 0) {
    // Matches patern
    Serial.print("src_long");
    Serial.print(" ");
    delay(100);
  if (len == sizeof Pattern28 && memcmp(Pattern28, rxBuf, len) == 0) {
    // Matches patern
    Serial.print("track back_long");
    Serial.print(" ");
    delay(100);
  if (len == sizeof Pattern29 && memcmp(Pattern29, rxBuf, len) == 0) {
    // Matches patern
    Serial.print("track next_long");
    Serial.print(" ");
    delay(100);
  if (len == sizeof Pattern30 && memcmp(Pattern30, rxBuf, len) == 0) {
    // Matches patern
    Serial.print("nxt_long");
    Serial.print(" ");
    delay(100);
  if (len == sizeof Pattern31 && memcmp(Pattern31, rxBuf, len) == 0) {
    // Matches patern
    Serial.print(" ");
    delay(50);
    digitalWrite(5, 0);
    delay(250);
  if (len == sizeof Pattern32 && memcmp(Pattern32, rxBuf, len) == 0) {
    // Matches patern
    Serial.print(" ");
    delay(50);
    digitalWrite(5, 0);
    delay(250);
  if (len == sizeof Pattern33 && memcmp(Pattern33, rxBuf, len) == 0) {
    // Matches patern
    Serial.print(" ");
    delay(50);
    digitalWrite(5, 0);
    delay(250);
  if (len == sizeof Pattern34 && memcmp(Pattern34, rxBuf, len) == 0) {
    // Matches patern
    Serial.print(" ");
    delay(50);
    digitalWrite(5, 0);
    delay(250);
  if (len == sizeof Pattern35 && memcmp(Pattern35, rxBuf, len) == 0) {
    // Matches patern
    Serial.print(" ");
    delay(50);
    digitalWrite(5, 0);
    delay(250);
  if (len == sizeof Pattern36 && memcmp(Pattern36, rxBuf, len) == 0) {
    // Matches patern
    Serial.print(" ");
    delay(50);
    digitalWrite(5, 0);
    delay(250);
  if (len == sizeof Pattern37 && memcmp(Pattern37, rxBuf, len) == 0) {
    // Matches patern
    Serial.print(" ");
    delay(100);
    // Matches patern
    Serial.print(" ");
    delay(100);
  if (len == sizeof Pattern38 && memcmp(Pattern38, rxBuf, len) == 0) {
    // Matches patern
    Serial.print(" ");
    delay(100);
  if (len == sizeof Pattern39 && memcmp(Pattern39, rxBuf, len) == 0) {
    // Matches patern
    Serial.print(" ");
    delay(100);
  if (len == sizeof Pattern40 && memcmp(Pattern40, rxBuf, len) == 0) {
    // Matches patern
    Serial.print(" ");
    delay(100);
  if (len == sizeof Pattern41 && memcmp(Pattern41, rxBuf, len) == 0) {
    // Matches patern
    Serial.print(" ");
    delay(100);
  delay(1.6875);
Syntax
delayMicroseconds(us)
Parameters
us: the number of microseconds to pause. Allowed data types: unsigned int.
Returns
Nothing
Syntax
delay(ms)
Parameters
ms: the number of milliseconds to pause. Allowed data types: unsigned long.
Returns
Nothing
Wouldn't it make more sense to read the message once and then check if it matches one of the patterns?
    // Matches patern
    Serial.print(" ");
    delay(100);
  else if (len == sizeof Pattern41 && memcmp(Pattern41, rxBuf, len) == 0) {
    // Matches patern
    Serial.print(" ");
    delay(100);
Sorry John, im not sure I understand. I am not good at write code and copied much from things I read. Found these working very well, the code filtered the canbus signals and create commands from specific parts in the signals. Like the part you reposted who the code send a serial print, it will in same code part even send a command to the stereo. A example the volume up button is pressed on steering wheel one time, it send a serial print message to tell it is pressed and at same time even send a command to the stereo who turn up the sound.
Every stereo brand has a own code language, I want to get this and turn it to commands in my code so a transistor or something can send a signal at the stereos language to the stereo.
