I have two Arduinos connected via SPI and am using the SPI.h library. I want to turn on an LED on the slave Arduino but using the master Arduino's Serial Terminal. That is, if I type a "1" in the Master Terminal, the slave LED is turned on.
My SPI connection seems to be working okay, because the slave Serial Terminal responds with the appropriate "Slave receive = " message. The problem is that the slave LED doesn't turn on when the data is received from the master Arduino.
Suggestions?
Master Arduino Code:
#include<SPI.h>
byte byteRead;
void setup(void)
Serial.begin (9600);
digitalWrite(SS,HIGH);//turn Slave Select OFF
// Put SCK, MOSI, SS pins into output mode
// also put SCK, MOSI into LOW state, and SS into HIGH state.
// Then put SPI hardware into Master mode and turn SPI on...
SPI.begin();
// slow down the Master's clock speed
SPI.setClockDivider(SPI_CLOCK_DIV8);
void loop(void)
// Send byte entered in Serial Terminal
/* check if data has been sent from Serial Terminal: */
while (Serial.available() > 0) {
/* read the most recent byte */
byteRead = Serial.read(); //Read Serial Terminal output
digitalWrite(SS, LOW); //turn Slave Select ON
Serial.println(byteRead); //Send ASCII equivalent of byteRead to Master terminal
Serial.write(byteRead); //Send binart equivalent of byteRead to Master terminal
SPI.transfer(byteRead);
// disable Select Slave
digitalWrite(SS, HIGH); //turn Slave Select OFF
delay (1000); // 1 second delay between transmissions
Slave Arduino Code:
#include<SPI.h>
byte c = 0;
volatile boolean process_it;
int ledPin = 2;
void setup(void)
Serial.begin (115200); // debugging
pinMode(ledPin,OUTPUT);
digitalWrite(ledPin,LOW);
Serial.println("Start");
//Set MISO pin as output
pinMode(MISO, OUTPUT);
// turn on SPI in slave mode
SPCR |= _BV(SPE);//set the SPI Control Register Enable Bit (bit 6) using bitwise OR (|=)
//and the _BV (Bit Value) macro.The Enable bit enable SPI operation as a whole
// get ready for an interrupt
process_it = false;
// now turn on interrupts
SPI.attachInterrupt();
// ***SPI interrupt service routine *****
ISR (SPI_STC_vect)
byte c = SPDR; //grab byte from SPI Data Register
process_it = true;
} // end of interrupt routine SPI_STC_vect
void loop(void)
//only do something if a complete transmission occurs.
if(process_it)
Serial.print("Slave Receive = ");//Print received byte to Slave terminal...
Serial.println(c);
if(c == 1) //If received byte = "1", turn on LED
digitalWrite(ledPin,HIGH);
delay(2000);
process_it = false;
