Hey Forum,
I have been trying to get my Arduino working with Pure Data via Serial for the last couple Days but so far no success ![]()
My Goal is to connect a couple sensors to my Arduino (Poti, Lightsensor, touch,...) and to control various parameters in Pure Data (i.e. Volume, Pitch,...).
First I simply connected a Poti to my Arduino UNO to do a analog.Read and to then send that value with serial.write. Then I wanted to read that data with the 'comport' message box in Pure Data. That didn't work. After a bit of research I found out that there was a Problem with Windows 10, where the comport command doesn't work properly (I also heard it has been fixed recently but couldn't figure out how)
Next I tried to use the PDuino 0.5
I used the StandardFirmata example
Here I got stuck compiling the Code. First I had to change the WProgram.h to Arduino.h in the libraries (Firmata.h and so on) since Wprogram.h is apparently out of use now.
Now I get an ERROR that BYTE was not declared in this scope. I'll post the error message below.
How can I fix this? OR does anyone have a tip or a better/easier way to communicate from arduino to Pure Data?
The Error:
Arduino: 1.6.9 (Windows 10), Board: "Arduino/Genuino Uno"
C:\Program Files (x86)\Arduino\libraries\Firmata\Firmata.cpp: In function 'void sendValueAsTwo7bitBytes(int)':
C:\Program Files (x86)\Arduino\libraries\Firmata\Firmata.cpp:32:35: error: 'BYTE' was not declared in this scope
Serial.print(value & B01111111, BYTE); // LSB
C:\Program Files (x86)\Arduino\libraries\Firmata\Firmata.cpp: In function 'void startSysex()':
C:\Program Files (x86)\Arduino\libraries\Firmata\Firmata.cpp:38:29: error: 'BYTE' was not declared in this scope
Serial.print(START_SYSEX, BYTE);
C:\Program Files (x86)\Arduino\libraries\Firmata\Firmata.cpp: In function 'void endSysex()':
C:\Program Files (x86)\Arduino\libraries\Firmata\Firmata.cpp:43:27: error: 'BYTE' was not declared in this scope
Serial.print(END_SYSEX, BYTE);
C:\Program Files (x86)\Arduino\libraries\Firmata\Firmata.cpp: In member function 'void FirmataClass::printVersion()':
C:\Program Files (x86)\Arduino\libraries\Firmata\Firmata.cpp:82:32: error: 'BYTE' was not declared in this scope
Serial.print(REPORT_VERSION, BYTE);
C:\Program Files (x86)\Arduino\libraries\Firmata\Firmata.cpp: In member function 'void FirmataClass::printFirmwareVersion()':
C:\Program Files (x86)\Arduino\libraries\Firmata\Firmata.cpp:104:35: error: 'BYTE' was not declared in this scope
Serial.print(REPORT_FIRMWARE, BYTE);
C:\Program Files (x86)\Arduino\libraries\Firmata\Firmata.cpp: In member function 'void FirmataClass::sendAnalog(byte, int)':
C:\Program Files (x86)\Arduino\libraries\Firmata\Firmata.cpp:270:46: error: 'BYTE' was not declared in this scope
Serial.print(ANALOG_MESSAGE | (pin & 0xF), BYTE);
C:\Program Files (x86)\Arduino\libraries\Firmata\Firmata.cpp: In member function 'void FirmataClass::sendDigitalPort(byte, int)':
C:\Program Files (x86)\Arduino\libraries\Firmata\Firmata.cpp:301:53: error: 'BYTE' was not declared in this scope
Serial.print(DIGITAL_MESSAGE | (portNumber & 0xF),BYTE);
C:\Program Files (x86)\Arduino\libraries\Firmata\Firmata.cpp: In member function 'void FirmataClass::sendSysex(byte, byte, byte*)':
C:\Program Files (x86)\Arduino\libraries\Firmata\Firmata.cpp:311:25: error: 'BYTE' was not declared in this scope
Serial.print(command, BYTE);
exit status 1
Thanks for your replies in Advance!
